rhino 212rhino 2General DiscussionRainey day thought's
rhino 2121dn5upGeneral DiscussionRainey day thought's
MDO101DK Custom ProductsHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg4Motorcycle MikeChampion TrikeChampion irs banging noise on bumps
Kneesinbreeze5My TurnHarley Freewheeler /...Hiway pegs without installing crash...
MDO101LD-OrdieHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg4difergChampion TrikeChampion irs banging noise on bumps
Rogue15Rogue1Harley Tri GlideOil pressure gauge.
dthorn7Dan SCHarley Tri Glide2024 Tri Glide front axle nut torqu...
Vin3Dan SCHarley Tri GlideCold Engine Revs High When Starting
Rogue15Dan SCHarley Tri GlideOil pressure gauge.
scuzzi4scuzziHarley Tri GlideTri Glide extended reach seat
Vin3rhino 2Harley Tri GlideCold Engine Revs High When Starting
diferg4Marc HChampion TrikeChampion irs banging noise on bumps
Vin3VinHarley Tri GlideCold Engine Revs High When Starting
Frisco5Marc HCalifornia Sidecar T...Side pod door open signal
ctdair2Jack KlarichHarley Tri GlideFixed Switch
diferg4Jack KlarichChampion TrikeChampion irs banging noise on bumps
jef_nik20002jef_nik2000Lehman TrikeMonarch 2 center cap removal proced...
jef_nik20002Papa ZookLehman TrikeMonarch 2 center cap removal proced...
Tritek5stancotreauLehman TrikeAvoid buying a Lehman?
gfaltersack8Jack KlarichHarley Tri GlideDK Customs remote oil filter kit in...
ctdair9Jack KlarichHarley Tri GlideHot Rotors After New Pads
Rogue15Jack KlarichHarley Tri GlideOil pressure gauge.
Tritek5Papa ZookLehman TrikeAvoid buying a Lehman?
gfaltersack8DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
Kneesinbreeze5Noodles107Harley Freewheeler /...Hiway pegs without installing crash...
Rogue15Old Road DogHarley Tri GlideOil pressure gauge.
Tritek5TritekLehman TrikeAvoid buying a Lehman?
Burnerboy11rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
ZZMACH114BrokenBackJackHarley Tri GlideNew Member Hello from NH
Frisco5FriscoCalifornia Sidecar T...Side pod door open signal
ZZMACH114SullyHarley Tri GlideNew Member Hello from NH
Kneesinbreeze5pigfoot63Harley Freewheeler /...Hiway pegs without installing crash...
Burnerboy11KneesinbreezeCan Am Spyder Trike...How many of you ride a Can Am spyde...
TXFIRE766BurnerboyHonda TrikesNew to Trikes and needing a convers...
smokey_mountain2BurnerboyAccessoriesJ&S Moto conversion to Trike Li...
Frisco5BurnerboyCalifornia Sidecar T...Side pod door open signal
Frisco5ol' schoolCalifornia Sidecar T...Side pod door open signal
ZZMACH114trike ladyHarley Tri GlideNew Member Hello from NH
ZZMACH114Marc HHarley Tri GlideNew Member Hello from NH
Kneesinbreeze5ZammyHarley Freewheeler /...Hiway pegs without installing crash...
Frisco5rhino 2California Sidecar T...Side pod door open signal
Rogue15rhino 2Harley Tri GlideOil pressure gauge.
ZZMACH114hardwickbvHarley Tri GlideNew Member Hello from NH
Kneesinbreeze5KneesinbreezeHarley Freewheeler /...Hiway pegs without installing crash...
ctdair2ctdairHarley Tri GlideFixed Switch
ZZMACH114GorillaHarley Tri GlideNew Member Hello from NH
Sunman7GoldWingrGregHonda TrikesF1 Warning Light
ZZMACH11ZZMACH1Harley Tri GlideRinehart VS Vance & Hines for M...
Zammy2Jack KlarichGeneral DiscussionHappy Birthday "prariepilot&qu...
hogmemberisold5BurnerboyGeneral DiscussionHow many carry spare headlight bulb...
Burnerboy11BurnerboyCan Am Spyder Trike...How many of you ride a Can Am spyde...
ZZMACH13Longbeard71Harley Tri GlideLooking for Dynajet Power Vision mo...
Papa Zook2Jack KlarichHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Tritek5Jack KlarichLehman TrikeAvoid buying a Lehman?
ZZMACH12Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
ZZMACH13Jack KlarichHarley Tri GlideLooking for Dynajet Power Vision mo...
Davep6Jack KlarichHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Zammy3Jack KlarichGeneral DiscussionHappy Birthday ultrafxr
Zammy3Marc HGeneral DiscussionHappy Birthday ultrafxr
Smitty9013Marc HSidecar ForumSmall crack down the rabbit hole
Oldman-TriGlide10ZammyHarley Tri GlideEnclosed Trailer Size
Smitty9013ZammySidecar ForumSmall crack down the rabbit hole
ZZMACH114Uncle FesterHarley Tri GlideNew Member Hello from NH
Zammy3ZammyGeneral DiscussionHappy Birthday ultrafxr
ZZMACH114stancotreauHarley Tri GlideNew Member Hello from NH
Davep6rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep6DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Smitty9013Smitty901Sidecar ForumSmall crack down the rabbit hole
ZZMACH114TrampasHarley Tri GlideNew Member Hello from NH
Oldman-TriGlide10CasperHarley Tri GlideEnclosed Trailer Size
ZZMACH114Jack KlarichHarley Tri GlideNew Member Hello from NH
ZZMACH114Bill J. from AustinHarley Tri GlideNew Member Hello from NH
Bill J. from Austin3Bill J. from AustinHarley Freewheeler /...16" front rim?
ZZMACH114rhino 2Harley Tri GlideNew Member Hello from NH
ZZMACH114DCR2013Harley Tri GlideNew Member Hello from NH
Bill J. from Austin3RKplus10Harley Freewheeler /...16" front rim?
Bill J. from Austin3Papa ZookHarley Freewheeler /...16" front rim?
ZZMACH13ZZMACH1Harley Tri GlideLooking for Dynajet Power Vision mo...
ZZMACH114ZZMACH1Harley Tri GlideNew Member Hello from NH
ZZMACH12ZZMACH1Harley Tri GlideElectric Fans on 2014 Tri Glide
MDO101JTJerseyHarley Freewheeler /...What Did You Do To Your Freewheeler...
chucktrue558My TurnHarley Freewheeler /...Rear shock adjustment
HDUSA12cycle7447Harley Trike Convers...Harley TPMS sensor and aftermarket ...
HDUSA12HDUSA1Harley Trike Convers...Harley TPMS sensor and aftermarket ...
chucktrue558Old Road DogHarley Freewheeler /...Rear shock adjustment
stancotreau3stancotreauLehman TrikeLehman Storm rear brake pads
Tritek5trike ladyLehman TrikeAvoid buying a Lehman?
ctdair9ctdairHarley Tri GlideHot Rotors After New Pads
ZZMACH14ZZMACH1Harley Tri GlideElectric Fans on 2014 Tri Glide
ctdair9ROAD DOGHarley Tri GlideHot Rotors After New Pads
Zammy2ZammyGeneral DiscussionHappy Birthday "prariepilot&qu...
Sunman7BowdenTrikeHonda TrikesF1 Warning Light
Jack Klarich3Jack KlarichGeneral DiscussionMY first guitar
hardwickbv4ctdairHarley Tri GlideGot a Code P0152 Engine Running Ric...
chucktrue558Jack KlarichHarley Freewheeler /...Rear shock adjustment
ZZMACH12Jack KlarichHarley Tri GlideSTOCK HARLEY ECM MAP with DynoJet
rhino 212Jack KlarichGeneral DiscussionRainey day thought's
ZZMACH12ZZMACH1Harley Tri GlideSTOCK HARLEY ECM MAP with DynoJet
rhino 212Phu CatGeneral DiscussionRainey day thought's
ZZMACH14ol' schoolHarley Tri GlideElectric Fans on 2014 Tri Glide
hardwickbv4KoolbreezeHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn7Jack KlarichHarley Tri Glide2024 Tri Glide front axle nut torqu...
Likes Likes:  0
Results 1 to 12 of 12
Thread: ASVE
    300+ Posts
    Apr 2010
    Sterling, Colorado USA
    Default ASVE
    I am purchasing a VW Trike which is titled as 2010 ASVE.
    I called progressive to check about insurance… and they will insure it but the trike itself won’t be covered per say. If I get into an accident ( I hit a vehicle or something) and damage the bike I won’t be able to recover the lost amount of the bike… They say its because a value cant be put on it since it is a ASVE… Anyone ever heard of this… Everything else is covered. .tow/ medical / other
    Does this sound right for a ASVE?
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: ASVE
    Sure they are saying that the vehicle was basicly assembled from parts and there for can not have a value from other sales of the same vehicle.
    300+ Posts
    Apr 2010
    Default Re: ASVE
    That’s basically what I hear... So that means it’s basically liability insurance right?
    1500+ Posts
    Oct 2011
    salt lake city, ut
    Default Re: ASVE
    Have you shopped around-seems to me if some ins companies insure ATV's, I cannot help but to think it can be done!!!
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: ASVE
    Yep liability, You might find an insurance company that insures special vehicles that is willing to except an appraisal then write a policy for that amount. Look at a company that insures show cars etc.
  6. #6
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Default Re: ASVE
    I've insured several "Homemade" Choppers, Custom Bikes, Street Rods, VW Trikes, Dune Buggies, etc. with State Farm. Never had an issue. They take Photos at the Agent's Office (They did this on both Honda Motor Trikes also), assess a declared value, and write Full Coverage...might try a State Farm Agent.....
    ..if it has WHEELS, I'm in...ThumbUp
  7. #7
    300+ Posts
    Apr 2010
    Default Re: ASVE
    Thanks for the info...
  8. #8
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Default Re: ASVE
    I have just went thru the same thing. Progressive is the only company that will insure my trike and it is liability only also. I have checked with every company and they all say no. Some said it's because it's a home built and others say it is because VW never made a trike. So for now, that is my only option also.
  9. #9
    2500+ Posts Ozarkryder's Avatar
    Feb 2008
    Anderson, Missouri
    Default Re: ASVE
    I'm thinking that ASVE stands for "ASsembled VEhicle. When we had the VW trike by the Trike Shop (nakers of Roadsmith now) Bikeline by Markel was happy to insure us, full coverage and a realatively reasonable price. Ap[parently they just go by Markel now.
    Low Cost Motorcycle Insurance & Discounts (BikeLine): Markel
    Not an endorsement per se, we are former customers and never had a complaint. They have experience with VW trikes. Shopped around and got a better rate with our current ride from a different company.
    Don - 2004 GL1800 Champion trike, 2018 Can Am Spyder RT Limited
    2 wheeler: 2013 Triumph Bonneville T100
    FORR Local 11, AMA, MRF, Mid-South MILE Committee
  10. #10
    550+ Posts
    Feb 2012
    tupelo MS
    Default Re: ASVE
    Quote Originally Posted by skuuter View Post
    It depend on the agent.
    Have been with state farm since 1969. Had to change to another state farm agent to change from bike to trike.
    Some agents are not very smart.
  11. #11
    550+ Posts
    Feb 2012
    tupelo MS
    Default Re: ASVE
    Have to change again, she can't find her notes. Story changed now it will not be insured as a trike, i need to keep all my papers just in case of an accident.
    Original notes was bring them, she will change policy and add the trike kit and other add one's to policy.
    Sometimes next week she will LET me meet the agent.
    That day will never happen.
    I will be with a different company
  12. #12
    Sep 2011
    Default Re: ASVE
    I sent a email to Low Cost Motorcycle Insurance & Discounts (BikeLine): Markel asking about insurance for a vw trike and here is their reply. If anyone wants a copy of their application, pm me your email and I will send it to you. It is in pdf and gives a quick test to see if your trike meets their apporval.
    Thank you for your email. We do offer liability and physical damage for trikes. We do have some requirements prior to issuing a trike policy with physical damage. We would require an application, appraisal and five color photos of the trike (front, back, both sides and engine). The application is attached. If you have any other questions or if you would like to obtain a quote, please contact our customer service center at 800-236-2453.
    Sincerely,
    LeAnn Jasinski, CISR
    Senior Customer Service Representative
