14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Page 2 of 2 FirstFirst 1 2
Results 21 to 34 of 34
Thread: To Damper or not to Damper
  1. #21
    Default Re: To Damper or not to Damper
    Pingel has a good line of steering dampers. They are highly recommended on 2000-2006 Boss Hoss trikes. The Pingel unit I ran on our trike cost $132.
    Withe the Kewlmetal trees,our trike doesn't need a damper now.
  2. #22
    20+ Posts Harley Ultra's Avatar
    Mar 2012
    Greeley, CO USA
    Everything here that you guys have installed are considerably shorter over all length than the TG damper. TG is a total length of 16" or 406mm. There are a lot of 400mm on Ebay that computes to just 1/4 in short of 16". TG body is 6" or 152mm, and Ebay's 400mm's has a 7 1/8" body 200mm. Comparing the 2 does, anyone see a problem with the 400mm over Harleys. I have an 09 UC with a Lehman conversion. Raked a 5 and I have had the dealership check everything, no problems other than shaking.
  3. #23
    1500+ Posts
    salt lake city, ut
    Quote Originally Posted by Harley Ultra View Post
    I used a 400mm on my victory, and I think a 300mm on my roadking (flh). On my hd I mounted it similar to the way the TG's are mounted. If it would help out, I could snap some pics tomorrow and post them for ideas on your install. If you mounted one like I did on my Vic you could use the 400mm easily.
  4. #24
    Mar 2012
    Greeley, CO USA
    I have the Harley mounting brackets and am comfortable with an install, just wondering if I need to come as close as possible to match the TG damper. If I go smaller won't I loose turning radius?
  5. #25
    Mar 2012
    Greeley, CO USA
    americanbadas did the 300 give you lock to lock turning? I plan on mounting them just the way the TG is too since I have the HD brackets.
  6. #26
    1500+ Posts
    salt lake city, ut
    I made my own brackets so the 300mm worked out fine on my RK. The way I set it up, there is full range of motion and about 1 inch of play on either end of the damper shaft. Since you have the HD brackets you may want to go to your nearest dealer, to look at one and even take some measurements. It is better to get a slightly longer damper, than too short-you could just adjust the play on either end.
  7. #27
    Mar 2012
    Greeley, CO USA
    I am going to install it the same way they do on the tri glide since I have the Harley brackets. My question is can I get lock lock turning with a shorter damper than the 16" (406mm) 1 on the Triglide?
  8. #28
    Mar 2012
    Greeley, CO USA
    I went over to Thunder Mountain and they had a triglide. That's where I got the figures off 16 inches total length in the body 9 inches. It would probably be best if I used the 400 that's closest to the 16 inchesI can get. Especially sense I will be using Harleys tri glide brackets.
  9. #29
    1500+ Posts
    salt lake city, ut
    It should work fine (the 400mm)-just make sure you adjust it so the full range of steering is balanced. Sounds like you have it covered-good luck!
  10. #30
    Mar 2012
    Greeley, CO USA
    Hey americanbadass your bad ass and I appreciate all your help. Head to Co. let me know.
  11. #31
    Mar 2012
    Greeley, CO USA
    I'm just full of questions, here's another one. I know that the damper used as standard on the new Harley trikes is PN 83808-09A. I would like to know, if possible, the PN of Ohlins damper Harley uses?
  12. #32
    Mar 2012
    Greeley, CO USA
    I have found an alternative to the $500 Harley Davidson TriGlide steering damper. Very similar measurements. It's only $165+shipping. www.astfromthepast.com if anyone is looking for one shipped from the good ole USA.
  13. #33
    20+ Posts
    Dec 2010
    Grand Island NE USA
    A steering damper was the best thing I have added since the trike conversion.
  14. #34
    750+ Posts
    Jan 2010
    east windsor ct
    if they set that 30k trike up right to start with it wouldnt need a damper!!!
    flames on
    have built an worked on enought trike to know it can be done!!
    your opinions will varry
  1. Steering damper with lowers on
    By gfdgary in forum Harley Trike Conversions
    Last Post: 08-04-2013, 12:07 AM
  2. Seeley Shimmy Damper
    By Jim Smyth in forum Honda Trikes
    Last Post: 07-21-2013, 03:35 PM
  3. Seeley Steering Damper
    By garyallenbrown in forum Honda Trikes
    Last Post: 11-16-2012, 05:26 PM
  4. steering damper pro/con ?
    By krazybob in forum Outrigger Style Trikes
    Last Post: 10-04-2011, 12:24 PM
  5. Tri-Glide Steering Damper
    By Tonyd in forum Harley Tri Glide
    Last Post: 03-15-2010, 12:47 PM
