ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  0
Results 1 to 12 of 12
Thread: Trailering a Trike
    1500+ Posts
    Oct 2011
    salt lake city, ut
    Default Trailering a Trike
    OK-I know there have probably been volumes written on this subject, but just wanted to double check before I advise my friend on this suject. He needs to trailer his new Victory Pitboss A few hundred miles. He has access to a flat trailer that is 8'L X 6'W, and has a 2200 lb weight capacity. I suggested that he use a four point tie down system. Pinch the front wheel down-tie downs on each side of the handle bars, pulling wheel to the stop. On the rear wheels< I am thinking that he could use one tie down strap per ewheel-through the wheel and attached toward the rear of the trailer. THe trike does have an E brake, I suggested he put it in neutral and pull the brake full on. Any suggestion about not screwing this transport up would be greatly appreciated- I know he is stressing a lot about this, since he has never done this-and I have only done 2 wheel trailering.
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    Default Re: Trailering a Trike
    Here is what I did when I went to NC to trailer my trike to NH:
    Use a wheel chock on the front wheel. Strap the front down using the crash bars around the engine to keep it steady in the front.
    I chocked the rear wheels so as not to move forward or reaward. I used the trailer hitch to stop it from going side to side.
    If you can, run a strap over the rear wheels to strap them down, just like the car hualers do when the tow a car on a flat bed. You may have to put eyes on the floor of the trailer to hold the wheel strap down.
    If you have an open trailer, you may want to cover the trike with a heavy soft cover. Remember, never use a plastic cover that will flap in the wind because it will wear your paint from the rubbing as the wind whips it around.
    Tie the cover down real good as not to flap.
    Stop here and there to check your tie downs to make sure they are tight and holding. NEVER ASSUME!
    Good luck!
    Regards,
    Rosy
    From NH
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Probably Apples to oranges here But when i had to trailer my 11 T/G 160 miles , I put it in 1 first gear parking brake on, One ratchet strap though the front wheel, One ratchet strap under the tie down loop on each side bottom of the rear shocks.
    Tie the ends of the straps to something for two reasons, Stop them from flapping and in case one comes lose you don't lose the strap, and also Take extra straps just in case you do lose one.
    Side thought, When was the last time you checked the air in the trailer tires , And greased the trailer hubs.??
    100+ Posts HDHoggly's Avatar
    May 2012
    Helena, MO, USA
    Isn't the Pitboss built by Lehman? If so my Lehman has some anchor points close to the rear wheels for tying down to trailer. You may want to check
    My ride is a 2008 Harley FXD with Lehman conversion dubbed "Trilogy".
    30+ Posts BladeRunner's Avatar
    Aug 2012
    Innisfil Ontario Canada
    Using the handle bars is probably not a good idea,the best is to secure in a way that allows the bike to "ride" on it's own suspension to a point. I use a Condor wheel chock on my trailer...it's the same one I use on my lift table.
    It's very secure holding the front wheel and I can sit on the bike and no matter how you try..the bike stays put.
    Strapping through the front wheel then I also use the rear wheel (s) to keep the load from shifting forward / sideways.
    Every bump and pot hole in the road will be transferred through the bikes frame if the center stand is used..that is not an issue with a trike of coarse.
    If no wheel chocks are used, then the crash bars or frame are a good option as long as they are not too tight.
    Stopping in a hurry in an emergency is the concern, so the greatest care is securing the load from forward movement, pulling away from stops not so much.
  6. #6
    400+ Posts
    Feb 2008
    RADCLIFF, KY
    DO NOT USE THE HANDELBARS FOR A TIE DOWNPOINT!
    Get a set of soft ties, loop them above the lower triple trees, then attach you straps to the soft tie loop....as for the rear, just tight enough to keep the trike from moving side too side...use a wheel chock...I've used the one from harbor fright and it works very good...about 50.00....leave the trike/bike in first gear.
    2017 Tri Glide, Bonnieville Blue / Fathom Blue
    2005 Bushtec Roadstar Trailer
    BLUE KNIGHTS, KY II
    AMA, HOG, Iron Butt Member
  7. #7
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by BladeRunner View Post
    I agree. Do not pull down on the front suspension but secure the wheel. Allow the motorcycle suspension or trike suspension to absorb the trailer ride. I use soft-ties on front wheel or lower fork legs and soft-ties on rear axle or rear wheels. This keeps things from falling off on a long haul.
    Jim Murphy
    Iron Butt Rider 2001
  8. #8
    350+ Posts bayoudave's Avatar
    Jul 2012
    Jena, LA, USA
    I may be the only one to ever have this problem but I learned from experience. I always tie (just hauled the trike yesterday to the shop) the wheels. First time I ever hauled mine I tied to the frame and after the ride I had two busted shocks. Putting restriction on the shock movement and then hitting the MANY pot holes and bumps blew the seals in both shocks. I do as Rhino 2 suggests, tie the wheels not the trike since you don't have to worry about it tipping over. Just MHO based on experience.
    2002 Goldwing Motortrike Spider - 2007 PiggyBacker Trailer - 2009 Time Out Deluxe Camper - 2005 Desert Fox 17SV Toy Hauler --- CMA, PGR --- SaddleSore 1000/Bun Burner 1500
  9. #9
    200+ Posts patriot's Avatar
    Jun 2008
    Hampton, GA
    Very simple for the TG; use a chalk, run strap through front wheel ans secure to tie-down rings. the rear end on the TG has tie-down loops welded to the axel. cris-cross sraps to tie-down rings. Thats it. I've made 2 round trips GA to AR and have not had any problems.
    Great people are common people who have committed themselves to uncommon goals.
    Dr. Robert Schuler
    2012 Tri Glide Ultra Red SunGlo/Marlot
    tGlide Wind Deflectors, Lift Kit, Tour Box Kit
  10. #10
    1500+ Posts
    Sep 2009
    North East Ohio
    Quote Originally Posted by patriot View Post
    +1. You are spot on. It don't get any easier.
    http://imageshack.us/a/img155/9918/trigld1.jpg
    2009 Triglide - Wood TW555 Cams, Suspension Lift By TglideStuff, Butter Smooth Clutch Pull by ClutchWIZ.
  11. #11
    750+ Posts
    Aug 2011
    Lake Murray, SC
    I have always used the handlebars plus the rear tiedowns and never had a problem, should I change?
  12. #12
    1500+ Posts
    Oct 2011
    salt lake city, ut
    Quote Originally Posted by Lakeman View Post
    Yea-I have always used the HB's for two wheelers. I think though-on threes the popular opinion is to anchor the front wheel-thus allowing for full frontal suspension.
  1. trailering trike
    By clo in forum Honda Trikes
    Last Post: 03-13-2013, 12:42 PM
  2. Where to tie front of trike when trailering?
    By air1gun in forum Honda Trikes
    Last Post: 08-22-2012, 04:03 PM
  3. Trailering
    By 87GWMomma in forum Honda Trikes
    Last Post: 11-17-2011, 02:11 PM
  4. Trailering behind a trike
    By Pup in forum Harley Trike Conversions
    Last Post: 07-15-2011, 07:24 AM
  5. Trailering a Trike
    By robandlyn in forum Trailers / Campers
    Last Post: 10-20-2009, 09:06 PM
