SSpoon5trike ladyNew Member Introduct...Hello from VA
gfaltersack1gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon5SullyNew Member Introduct...Hello from VA
SSpoon5Jack KlarichNew Member Introduct...Hello from VA
SSpoon5GorillaNew Member Introduct...Hello from VA
SSpoon5SSpoonNew Member Introduct...Hello from VA
Likes Likes:  2
Results 1 to 20 of 20
Thread: Reverse trike
    Default Reverse trike
    my first attempt at a reverse trike using a vw front beam . It has worked out well and it fun to ride.
    The bike is a 78 goldwing gl 1000 i put a 70 vw bug front beam on it
    1+ Posts
    Mar 2010
    Hooper, Utah
    Default Re: Reverse trike
    Got anymore pics?
    150+ Posts Bob Witte's Avatar
    Jan 2010
    Hudson, FL (near Tampa)
    Quote Originally Posted by Dennis Elliott View Post
    Although not a lightweight, the stock VW front end is an inexpensive, excellent choice for a Tadpole conversion and uncomplicated to attach to a Goldwing as you have proven. It's an easy thing to center the steering by changing the length of the connecting rods. Were I to attempt it (and I'll lay down until the feeling goes away), I would narrow the tract width a bit and use narrow tires (i.e. 155's or even less). JSYK, there are lots of inexpensive disk brake conversions for those fronts available.
    I'm amazed that more folks haven't done it already (maybe you've started a trend!)
    Take a look........
    As I said, the OEM front ends are quite heavy, but if you are serious, our desert rat friends have developed a solution. There are any number of aluminum front ends available (aftermarket VW parts are endless, let your google do the walking!). Here's just one example: http://www.cbperformance.com/catalog.asp?ProductID=1218
    Bob Witte
    The Ghost of Trinity Trike Past
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Why not do as others have done and use the same frontend off with A arms design.
    Contributing Member lzski326's Avatar
    Nov 2008
    Mark, Illinios 61340
    Here's one a saw in sturgis this year. kinda neat.
  6. #6
    There are a arm front ends that could ne used the miata had a bolt on a-arm front. i just prefered the vw for simplicity. i am in the process of narrowing one 6 inches to install as a bolt on unit to my goldwing gl1800. having an aluminim frame i dont want to weld to it
  7. #7
    1+ Posts
    Oct 2012
    Chula Vista Ca
    Hey Dennis,
    this looks like a good project for my GL1500 got any building it pictures. and I'm interested in the 1800 as well.
  8. #8
    Quote Originally Posted by Troublemaker View Post
    Hey Dennis,
    Ill see what i can find . as for the 1800 im trying to make it an all bolt on ,because of the alum frame. I plan to come out from the foot pegs for mounting like the voyager kit.(which i have on it now). im in the pricess of narrowing a 70 vw front beam. they are 60 inches and most trikes are 54 to 56, so debating on 4 or 6 inches.
    denniselliott@hotmail.com
  9. #9
    5+ Posts
    Mar 2010
    Central Point, Oregon, Jackson
    Hey Dennis,
    I like the simplicity of this, the sway a way adjusters allow you to lower and firm or soften the ride.
    How does it move out?
    Have you weighed it?
    Do you Have any more Pictures????
    I have a 88' GL1500 that needs a conversion,
    My thought was to build a frame that the VW front end can bolt to, then mount the GL1500 engine/trans as far forward behind the beam front end as possible and still be able to do Maintenance.
    Then take the stock Goldwing Drive shaft and lengthen it, so that i can sit on a Low seat right behind the Transmission, and the wheel behind me.
    Seating position Like the Roadstercycle has
  10. #10
    5+ Posts
    Mar 2010
    One other thing is i would leave the VW front beam the Stock width.
    I would just add a sway-a-way adjusters, and a Swaybar, disc Brake's S.S. brake lines
    Gas shocks, front and Rear.
    Then play around with dressing up the front end, to look something like the RoadsterCycle
  11. #11
    90+ Posts Mr Orange's Avatar
    Aug 2010
    McHenry, IL
    So is this project still ongoing? Would love to see more photos of the build! Tell us more.
  12. #12
    Quote Originally Posted by Westgl View Post
    I havent weigheed it but it doesnt seem to notice any difference in weight i have about 1200 miles on it now. i attempted to put a power steering unit from and atv but ht unit didnt work and i got tired of dealing if you email me ill send you some build picswith a tech so i went back to casically go cart steerin. if you email me ill send some build pics and any ive taken. denniselliott@hotmail.com
  13. #13
    Quote Originally Posted by Mr Orange View Post
    shoot me an email i have some pps pics. denniselliott@hotmail.com
  14. #14
    i wanted to keep it where i could put it all back to stock if it didnt work out,but it did
  15. #15
    5+ Posts
    Jul 2013
    North Carolina
    Thank You, Dennis, for sending me the PPT about the set up of your trike!! You gave me a lot of food for thought as I try to figure out how I want my trike-to-be built...
  16. #16
    50+ Posts
    Aug 2013
    San Diego, CA
    Very cool.
  17. #17
    200+ Posts RTwing's Avatar
    Mar 2014
    Minnesota
    I have received communications from several guys who have used the VW crossbeams for RT conversions. They are a bit heavy and overbuilt for this type of vehicle but the theory behind the product is good. They offer a fairly stiff ride with minimal pitch and roll. I had thought about trying one myself however I would build my own light design rather than use the stock VW setup.
    A-arms are more conventional and offer a more adjustable ride however do require a stiff sway bar to control pitch and roll.
    I am on my 5th build right now which is a 96 HD classic which rear ended a car. I am rebuilding this bike for the owner but decided as long as it's on the lift I would fab up a RT frame for it.
    #1 back in 2009 - ST1100 (stealth11)
    #2 was in 2011 - 99 Valkyrie Interstate (Valk3)
    #3 2013 - 2001 GL1800 (prototype 3)
    #4 total rebuild on the Valk3 - (Prototype 2)
    I have it down to a science right now but there is much to know and much to learn regarding 3 wheel geometry.
  18. #18
    Default steeris a little hard but working on thta
    i now have 33000 miles on the conversion.
    I still get about 40 mpg and i dont have to put my feet down
  19. #19
    Mar 2014
    Minnesota
    Thats good Dennis - I get 34mpg and that is what I got before the conversion. In the mountains I would get over 40 but at our elevation 34 is about it.
    I am at 129k on 7 different forward trikes and every day I learn something new. I will say the GL is the hardest bike to tune in as the aerodynamics on this machine are not good. Getting them to handle is easy getting them to handle in the wind requires a fully adjustable suspension design.
  20. #20
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Dennis good job. Would be nice if you posted some pictures of the build. Time has shown that it is a good one.
  1. Reverse trike
    By Dennis Elliott in forum Home Built Trikes
    Last Post: 10-15-2014, 01:38 PM
  2. New reverse trike...
    By yassert in forum Home Built Trikes
    Last Post: 03-30-2012, 02:24 PM
  3. Reverse trike
    By redneckray in forum Home Built Trikes
    Last Post: 09-02-2010, 04:35 PM
  4. T-Rex reverse trike
    By Papa Zook in forum Other Brands Trikes
    Last Post: 09-05-2008, 07:39 PM
