AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV13trike ladyNew Member Introduct...New to trike
AriNV13GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Grandpot9Papa ZookHonda TrikesFront tire?
Likes Likes:  0
Results 1 to 13 of 13
Thread: Trike with Goldwing front end wobble
    20+ Posts
    Jun 2012
    St. Augustine Florida, USA
    Default Trike with Goldwing front end wobble
    Trike is now 90% done, so I thought I would take it for an experimental ride. I used the front forks/triple tree assembly from my 1983 Goldwing Aspencade with air suspension. At about 25 to 35 mph you feel a wobble. It gets worse when you take one hand off the bars to shift gears. Seems to clear up at about 45 MPH. I have "old mock up tires" on the back and a new tire on the front and don't know how much affect this has. I know the dreaded "goldwing tank slapper" and this is pretty close to it. I understand it's a wide open question, but I could be missing the obvious so any help would be appreciated.
    550+ Posts
    Feb 2012
    tupelo MS
    Default Re: Trike with Goldwing front end wobble
    I use ballance beads in my front. It took that away. Road star champion trike
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    you might not have enough rake or the steering head nut is to loose.
    20+ Posts
    Jun 2012
    Forks have 47 degrees rake. I'll check the stem nut per the Honda procedure. Thanks for the suggestions.
    200+ Posts
    May 2011
    Orlando,Fl--USA
    1--Check the balance on ALL the wheels.&lt;br /&gt;<br />
    The rear tires can also affect the front end.&lt;br /&gt;<br />
    &lt;br /&gt;<br />
    2--Raise the front end off the ground--stand in front of the forks--grab the forks and try to &amp;quot;lift&amp;quot; them--this will tell you if there is any play in the neck bearings&lt;br /&gt;<br />
    &lt;br /&gt;<br />
    3--Add &amp;quot;Balance Beads&amp;quot;&lt;br /&gt;<br />
    &lt;br /&gt;<br />
    Gotta be safe!
    Ride safe!!! Lots of idiots out there!!!
  6. #6
    20+ Posts
    Jun 2012
    Update - Still using old &quot;mock&quot; up tires on rear and have ordered the steering stem bearings. Reduced air pressure in all 3 tires to 22 PSI and test rode. Not much change. Temporarily added the original gold wing inertia weight to the forks and it helped somewhat. I think most of the wobble is from the sterring stem bearings. What are &quot;balance beads, where can you get them and how do they attach to the trike? Thanks for the help.
  7. #7
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    <div class="bbcode_quote">
    <div class="quote_container">
    <div class="bbcode_postedby">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>usnavy8084</strong>
    <a href="showthread.php?p=137295#post137295" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">Update - Still using old &quot;mock&quot; up tires on rear and have ordered the steering stem bearings. Reduced air pressure in all 3 tires to 22 PSI and test rode. Not much change. Temporarily added the original gold wing inertia weight to the forks and it helped somewhat. I think most of the wobble is from the sterring stem bearings. What are &quot;balance beads, where can you get them and how do they attach to the trike? Thanks for the help.</div>
    </div>
    </div>
    </div>This link will tell you about balance beads. There may be other brands, but this is one well-known brand: <a href="http://www.innovativebalancing.com/index.php" target="_blank">Tire Balancing Products</a>
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
  8. #8
    550+ Posts
    Feb 2012
    tupelo MS
    Have found that, when first starting, sometimes a little wobble.
    Then after been at 45 -65 mph, then slow lown the wobble is gone, the beeds have found their place.
  9. #9
    40+ Posts classycustoms's Avatar
    Apr 2011
    Bald Knob,Ar. USA
    Any idea what your trail is? If it's not right, it will wobble. Think shopping cart front wheel.
  10. #10
    30+ Posts pastence's Avatar
    May 2012
    oregon city or
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>classycustoms</strong>
    <a href="showthread.php?p=137364#post137364" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">Any idea what your trail is? If it's not right, it will wobble. Think shopping cart front wheel.</div>
    </div>
    </div>
    </div>Yes reduce trail!!!! You must have some trail but should be somwhere between 1.5 and 3 inches check your geometry and run front tire at 40 psi and tighten head nut more than stock.
  11. #11
    20+ Posts
    Jun 2012
    I will use Triker Don's Calculator and get back with you on trail. Thanks
  12. #12
    20+ Posts
    Jun 2012
    Trail measures 3 3/4 inches. Thanks for the help.
  13. #13
    20+ Posts
    Jun 2012
    Default Re: Trike with Goldwing front end wobble - solved!
    Disassembled the front steering stem and removed the forks. Found damage to upper & lower steering stem bearings and the fork fluid was pink but smelled like 90W. Cleaned both forks and filled with new Dexron transmission Fluid. Replaced both steering stem bearings and torqued to 16 ft/lbs which is 5 ft/lbs higher than the spec. With 32 PSI in the front and rear tires, the trike handles like a dream. Problem solved.
    Old too soon, smart too late!
  1. Front End Wobble
    By SchubeCM in forum General Discussion
    Last Post: 11-03-2013, 06:53 AM
  2. Front End Wobble Solved
    By usnavy8084 in forum VW Powered Trikes
    Last Post: 01-14-2013, 11:13 AM
  3. wobble on front wheel
    By lbs12345 in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-12-2011, 09:13 PM
  4. Goldwing front wheel wobble
    By ssdyle in forum Honda Trikes
    Last Post: 04-19-2009, 10:32 AM
