Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Results 1 to 13 of 13
Thread: rear tire on front of trike
    20+ Posts
    Nov 2010
    Graham, Tx. USA
    Default rear tire on front of trike
    I may have posted this before but my system crashed and I lost a lot
    of info. So will a rear tire fit on the front of my GL1800 trike if
    I can find one the same size as the original front tire? I am headed on a
    road trip and need to replace the front first.
    Thanks for your input.
    Dray
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Default Re: rear tire on front of trike
    BT 45 does well
    T.O.I. - Florida jfingalls's Avatar
    May 2010
    Ormond Beach, Florida USA
    Yes
    2021 Can-Am Spyder RT,
    TOI
    750+ Posts Bruce's Avatar
    Sep 2010
    NY, USA
    With the BT45 mounted in reverse do you get the handle bar buzz like with the Michelin
    70+ Posts riverrat's Avatar
    May 2010
    Knobel,Arkansas
    I ran one of these Kendas Kenda K671 Cruiser ST Rear Tire - Cruiser Motorcycle - Motorcycle Superstore
    on my old goldwing 1500 trike and it held up good but I traded trikes before I got to see how long it would last, only put around 10,000 miles on it and it looked like it still had a lot left. I am on my second BT 45 on my 1800 trike, the first one lasted 12,000 miles and this second one appears that it will be gone around the same mileage. my next tire will be the Kenda and I will see how long it will last this time.
    [SIGPIC][/SIGPIC]
    Larry - 2010 Goldwing/CSC
    Mar 2011
    mountain home,ar. USA
    The BT-45 and the Michelin MPA seem to be the favorites. I like the BT-45 best. Be sure to buy the rear BIAS ply tire in the same as the standard front; 130x70x18. Pressure should 41 psi and it work well.
    20+ Posts
    Nov 2010
    Graham, Tx. USA
    Thanks guys for all the input.
    Much appreciated.
    Dray
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Wow Larry ( river rat). You arre hard on tires. Is this a rear bias ply you have up front. Most people get in the mid 20,000 range. If you were running the OEM up front I bet you would be lucky to get 6 or 7,000 or of it..
    May 2010
    Knobel,Arkansas
    yes, I have the rear bias ply tire up front and run 41 psi in them. I wish I could get mid 20's out of a tire but it just hasn't happened for me.
    the OEM front tire at 8,000 miles
    [SIGPIC][/SIGPIC]
    350+ Posts bayoudave's Avatar
    Jul 2012
    Jena, LA, USA
    I just put a new Pilot Activ on last Friday. Took off the Pilot Activ that had almost 25,000 miles on it and the tire guy said I could get another 5,000 but I elected to go ahead and change it before then new season gets into full swing. J&P Cycles has them on sale right now for 112.99. Michelin Pilot Activ 130/70-18 Rear Tire | ZZ21978 | J&P Cycles
    2002 Goldwing Motortrike Spider - 2007 PiggyBacker Trailer - 2009 Time Out Deluxe Camper - 2005 Desert Fox 17SV Toy Hauler --- CMA, PGR --- SaddleSore 1000/Bun Burner 1500
    100+ Posts
    Sep 2012
    Sisters, Oregon USA
    Just purchased a Michelin Pilot Active Goldwing rear and have it mounted in reverse. I have a CSC '10 Cobra and went through the Dunlop 250 in 4000 miles and then went to the Bridgestone Excedra on the front and I got 9,000 miles out of that one no issues. Have read several posts and I can now understand why you need to have a bias ply tire on the front. They have much stronger sidewalls than radials. I hope I can get near 20K out of this new Michelin. I won't mind the buzzing because I can't hear anyway. I'll keep you posted on the performance. Cost was 104.00 from our local Honda Dealer in Bend Pro Caliber. Had to order it as there seems to be a run on these tires. Too much advertising on these forums. Best of luck with whatever tire you choose.
    10+ Posts thomocon's Avatar
    Jan 2012
    Bastrop Louisiana
    I just got my tire , it took two weeks by mail . I have a VTX 1300 trike I hope it fits .. I plan on putting on new brake pads too. Bridgestone broadaxe 140 80 17 rear ...reverse direction I think. As soon as I get the axle tool
    30+ Posts Richard. Wales UK's Avatar
    Apr 2013
    Wales, United Kingdom
    Hi
    I have just bought a Michelin Pilot Activ Rear 130/70-17 TT/TL 62H M/C to go on the front of mine, had to go up one size, the standard is a 120/70-17 but I have ran a 130/70 before but it was a standard front.
    Will report back how I get on
    Richard
  1. Rear Tire on Front
    By Dray in forum Tires, Wheels, Brakes, Front End
    Last Post: 04-04-2013, 08:06 AM
  2. Rear tire on front
    By Trike Rich in forum Tires, Wheels, Brakes, Front End
    Last Post: 10-30-2012, 05:06 PM
  3. Rear tire on front
    By minnleeboy in forum Honda Trikes
    Last Post: 11-16-2011, 10:30 PM
  4. Replies: 15
    Last Post: 12-22-2009, 11:19 PM
  5. 1500 what rear tire for front
    By jm93wing in forum Honda Trikes
    Last Post: 10-25-2009, 06:14 PM
