14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  0
Results 1 to 15 of 15
Thread: Does anyone w/GL1800/Roadsmith have this rack?
    5+ Posts
    Jun 2013
    Brunswick OH
    Default Does anyone w/GL1800/Roadsmith have this rack?
    I wanted to place an order for one of these but I can't seem to get a response from the vendor. I asked the following question:
    "I'd like to place an order for this rack right away but need to know the following information
    What is the length from the center of the hitch locking pin to the rack edge. I have a Goldwing Roadsmith Trike with Nerf bumper and don't want to have any interference or trike body damage. Your prompt reply would be greatly appreciated. I need one for a planned trip. BTW: This is the third request for this information."
    It looks like a good rack with good size & features but if it doesn't fit, it's useless. Thanks, Art
    Quick Release Motorcycle Cooler Rack | eBay
    700+ Posts
    Jan 2012
    Cayce SC
    Default Re: Does anyone w/GL1800/Roadsmith have this rack?
    You should not have a issue mounting that.
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    ... I have a friend that runs one , just be careful going through a parking lot drain ditch his would drag a little on some that was a little steep . Now as far as being handy it's great to have ....
    we all have our faults .....others point them out to us......guess we know what theirs are
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    Chances are you won't be able to fully open trunck with cooler or other bag on rack. That's the case with my Roadsmith when I have the Packit Rak attached. Still worth having though.
    10+ Posts
    Mar 2012
    Coon Valley, WI, USA
    I have a RIVCO large rack that I used before I had the Roadsmith conversion done. When I got the trike home I purchased an auto hitch from Farm & Fleet that raises the rack 5 inches. This hitch peice was also a long one and I redrilled the pine hole in the shank to move the rack back. I have never since had a problem with rubbing the road and it is back far enough to allow access to the trunk. I use it alot. JerryD
  6. #6
    70+ Posts oldtimer1's Avatar
    Mar 2013
    Wesley Chapel,Fl. USA
    Mine works great on my Victory CSC. You should have plenty of room for any fudge factor adjustments.
  7. #7
    500+ Posts Konrad's Avatar
    Nov 2010
    La Grange, KY
    Quote Originally Posted by blkbrd View Post
    I have that exact setup! 2006 GL1800 with Roadsmith and nerf bumper and that exact rack. Took it on a 5,299 mile trip last year through 13 western states. Carried a fully loaded medium sized wheeled suitcase bungeed on.
    No problems - worked like a charm.
    The rack won't tilt.
    For extra tie-on points, drill a few holes around the perimeter of the lip and attach short eye-bolts facing out.
  8. #8
    we build them go to
    Motorcycle Hearse
    schroll down towards bottom of page
    Remember--It is never the issue but rather how we react to the issue is the issue.
    http://www.buggy.com/
    07 VTX 1800 w/Champion Trike Conversion
    [SIGPIC][/SIGPIC]
  9. #9
    5+ Posts
    Jun 2013
    Brunswick OH
    Quote Originally Posted by Konrad View Post
    I have that exact setup! 2006 GL1800 with Roadsmith and nerf bumper and that exact rack. Took it on a 5,299 mile trip last year through 13 western states. Carried a fully loaded medium sized wheeled suitcase bungeed on. No problems - worked like a charm. The rack won't tilt. For extra tie-on points, drill a few holes around the perimeter of the lip and attach short eye-bolts facing out.
    Thanks everyone for all your input and suggestions... it was greatly appreciated. I think Konrad's trike setup is what I was looking for and will place an order with them....
    even though they never responded to my inquiry.
    pepper
  10. #10
    we can size to your specs / just looked at the ebay piece--nice hitch setup---can do like that one
    [SIGPIC][/SIGPIC]
  11. #11
    5+ Posts
    Jun 2013
    Brunswick OH
    Thanks everyone for the help.... I should have one in the UPS truck for Tuesday delivery.
    Art
  12. #12
    3250+ Posts bikerbillone's Avatar
    Sep 2012
    Lakeland, FL
    Same RS set up here, so did the hitch fit the RS receiver without a mod?
  13. #13
    Nov 2010
    La Grange, KY
    Quote Originally Posted by bikerbillone View Post
    No mods, no problems. RS provides the industry-standard small tube receiver.
  14. #14
    100+ Posts DeerWrangler's Avatar
    Oct 2010
    La Vernia, Texas, USA
    I did some modifications to it.. Got a receiver that has a 3" rise, Then when i got the thing i cut the 1 1/4" solid bar off to where it fit more in line where i wanted it to be, Then redrilled the pin hole... Then i mounted the rack to the hitch i used a large bolt & nut so that it was more like a 1 piece assy. Drilled 2 holes on the forward siede but on the ends of the rack where i mounted I bolts facing down where i attached a couple of small tun buckles & chains to keep rack from rattling.... Then added some leds to the back side...... Sets high enough to never worry about bumping the ground even on speed bumps but still low enough that the lisc plate can be seen by the local law enforcement.... FYI... I now have that whole setup on the market... Hitch, rack pins etc
  15. #15
    Sep 2016
    Springfield, Mass. USA
    I had that same set up on my stock 2010 Goldwing (two wheels) and now that my bike is in the shop getting "triked out" as we speak, I plan on putting that same set up on my R/Smith trike...........
    I'm looking forward to a new adventure on three instead of two.........
    Ronnie
  1. How to jack a GL1800 with Roadsmith
    By SMSgt in forum Honda Trikes
    Last Post: 01-20-2013, 09:34 AM
  2. 2012 GL1800 ROADSMITH and CSC OWNERS
    By Chazzman in forum Honda Trikes
    Last Post: 11-22-2012, 09:01 AM
  3. Seat suggestions for gl1800 roadsmith
    By david1144 in forum Honda Trikes
    Last Post: 07-24-2011, 11:45 AM
  4. Fuel Consumption on GL1800 / Roadsmith Trikes...
    By mpolissky in forum General Discussion
    Last Post: 02-17-2011, 10:25 AM
