Likes Likes:  0
Results 1 to 15 of 15
Thread: next one on the way
    750+ Posts
    Jan 2010
    east windsor ct
    Default next one on the way
    started my next trike on sat 1/4 off to a running start... but building a 4 cyl hd trike at the same time so gotta work on that on a bit 3 attemps to upload pics .... fail
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Default Re: next one on the way
    Wish you were closer, I could use something to do this winter.
    Enjoy life now!----------IT HAS AN EXPERATION DATE
    1989 HARLEY DAVIDSON TOUR GLIDE ULTRA CHAMPION- A WOLF IN SHEEP'S CLOTHING-(CUT YOUR WOLF LOOSE!)
    the difference between a good trike and a bad one depends entirely on the integrity of it's builder!
    750+ Posts
    Jan 2010
    east windsor ct
    couple more pics
    900+ Posts jtilmon's Avatar
    May 2011
    Collierville, TN USA
    Good looking welding and machine work.
    enjoy the build
    jtilmon
    GL 1800 / Roadsmith / Caliente Red
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by jtilmon View Post
    enjoy the build
    thanks.. actually only machining so far was the hole in the pulley and the drilled holes in the flanges... flanges were flame cut with the torch and the sheet gussets are all plasma cut
  6. #6
    750+ Posts
    Jan 2010
    east windsor ct
    roadie is on hold for a few days gotta move on the hd 4 cyl a bit
  7. #7
    1+ Posts
    Jan 2014
    Granite Falls, NC
    Very nice fab work. What was the donor vehicle for the trailing arm rear-end?
  8. #8
    550+ Posts
    Feb 2012
    tupelo MS
    Very nice work.
  9. #9
    750+ Posts
    Jan 2010
    east windsor ct
    thanx for the compliments... the arms with 2 struts are from a subaru and the 3 straust are from a mazda rx7
  10. #10
    750+ Posts
    Jan 2010
    east windsor ct
    a little progress on the hd
  11. #11
    750+ Posts
    Jan 2010
    east windsor ct
    motor mnt ready for machining
  12. #12
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    ,,,,,Nice work ,really curious about those two engines running together .
    we all have our faults .....others point them out to us......guess we know what theirs are
  13. #13
    750+ Posts
    Jan 2010
    east windsor ct
    me too no clue if they will get alone without killing each other !!! gonna find out
  14. #14
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Check this website if you think getting two engines to run together might be a problem. <a href="http://www.docshd.com/Docs_Creations/Timeline/creationstimeline.htm" target="_blank">http://www.docshd.com/Docs_Creations...nstimeline.htm</a><br />
    Doc also built a 4 engine 45 flathead five passenger that is on the same site.
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  15. #15
    750+ Posts
    Jan 2010
    east windsor ct
    saw that a few yrs ago<br />
    identical motor is one thing but different ones???
