AriNV4Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV4AriNVRider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Results 1 to 5 of 5
Thread: Disc Brake problem
    Jul 2014
    Hudson
    Default Disc Brake problem
    i converted my rear disc brake suzuki s40 to a dual disc brake, two piston calipers on each wheel on my trike conversion. installed a proportioning valve, bled the system 3 times, spilled some fluid on the wheels and cleaned it off with brake cleaner. the problem is the rear brakes are only strong enough to hold bike in place at a red light or stop sign. will stop from an idling speed w/some effort. any ideas would be appreciated.
    500+ Posts wiredgeorge's Avatar
    Sep 2012
    Mico, TX.
    Default Re: Disc Brake problem
    Quote Originally Posted by nhbiker1 View Post
    You aught to know what type calipers it has. Brake pad material can make all the difference if the brakes are not spongy. If spongy, put speed bleeders on them and use a MityVac and suck out as much as possible then bleed the little remaining with just the speed bleeders. The two brakes off one m/c means there is a good possibility of air still int he system. Sometimes it seems almost impossible to get all the air bubbles out. If the pedal is firm, you have good pads, time to look at a m/c with larger diameter plunger. If you are using the original and it was intended to provide hydraulic pressure to one pot and you now have four, then it may not be large enough diameter.
    wiredgeorge Mico, TX.
    Jul 2014
    Hudson
    Quote Originally Posted by wiredgeorge View Post
    thanks,
    all parts are new to the bike. came w/the trike kit. master cylinder,calipers,pads,rotor,braided lines. we had to add a proportioning valve and a linkage from original pedal(which was a drum brake setup)
    300+ Posts vw driver's Avatar
    Jan 2014
    Tacoma, WA USA
    I've heard if the push rod is not adjusted correctly the brakes will do what you are describing. If the rod is not allowing the piston to return far enough fluid will not be sucked back into the chamber. At least that is something I have heard.
    Jul 2014
    Hudson
    Quote Originally Posted by vw driver View Post
    now that sounds possible. i'll have to check that out. thanks
  1. Disc Brake Conversion
    By joelin5386 in forum Harley Trike Conversions
    Last Post: 09-21-2013, 04:22 PM
  2. disc brake kit
    By Dragon in forum Yamaha Trikes
    Last Post: 08-29-2013, 01:21 PM
  3. Disc brake conversion?
    By Carbon_One in forum Harley Trike Conversions
    Last Post: 05-18-2013, 07:15 AM
  4. Rear disc brake kit
    By classicfins in forum VW Powered Trikes
    Last Post: 08-24-2012, 02:37 PM
  5. Disc Brake Conversion
    By mcdonaldroadcapt in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-30-2012, 12:38 AM
