dthorn4dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
Cut N Shoot Customs2miaboboCut N Shoot CustomsGL1800 & GL1500 Fork Tube Exten...
LD-Ordie7ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie7trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie7SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16LD-OrdieHarley Tri Glide2024 Tri glide
LD-Ordie7LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
SSpoon14hardwickbvNew Member Introduct...Hello from VA
dthorn4nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Likes Likes:  3
Page 2 of 2 FirstFirst 1 2
Results 21 to 35 of 35
Thread: Winter Riding Gear
  1. #21
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Default Re: Winter Riding Gear
    Wondering why you want step less versus stepped controller?
  2. #22
    5250+ Posts Pegasus1300's Avatar
    Oct 2011
    Spring City,Utah, USA
    Quote Originally Posted by trikermutha View Post
    Sorry to take so long to answer this. I had forgotten about the post and I just saw you question. Anyway with a stepped controller you have to use the settings they give you. One step might be too high and the next lower one too low. Step less,you get what you want. I now have a step-less (Rheostat really) and I really like the way it adjusts. I ended up with a Gerbing because a friend of mine gave me a great deal on his used one.
    Happy TRAils/NSD
    Paul
  3. #23
    13000+ Posts FuzzyWuzHe's Avatar
    Dec 2014
    Grand Junction, Co. USA
    Quote Originally Posted by Pegasus1300 View Post
    I like the step less too ... I have my pants and socks on one control... jacket and gloves on the other control
  4. #24
    200+ Posts
    Nov 2015
    palm bay
    Default winter
    Just tried the electric vest with my leather jacket and seems that combo works good..The heated grips still amaze me keeping my hands warm..
    Electric is the only way to go. No matter how many layers one piles on eventually a draft come in, then another, then .. until you are cold. Electric vest feels like the warm sun on a summer day. Grips are good year round. But after 50 years I found the final solution and moved to Florida. Now if I can figure out air conditioning for the trike ....
  5. #25
    Oct 2010
    USA
    Quote Originally Posted by vito View Post
    I have seen someone put fans on his bike..No AC yet..
  6. #26
    2500+ Posts Ozarkryder's Avatar
    Feb 2008
    Anderson, Missouri
    Electric... snip part of quote...But after 50 years I found the final solution and moved to Florida. Now if I can figure out air conditioning for the trike ....
    Well, there's the Stallion with A/C...
    Don - 2004 GL1800 Champion trike, 2018 Can Am Spyder RT Limited
    2 wheeler: 2013 Triumph Bonneville T100
    FORR Local 11, AMA, MRF, Mid-South MILE Committee
  7. #27
    Oct 2011
    I layered up for years and it worked well when I was younger,but now it is really nice to plug in and turn on. If you are an AMA member Warm and Safe will give you an 18% discount on your purchase. They make the liners for First Gear and sell under their own name also.
    Happy TRAils/NSD
    Paul
  8. #28
    Oct 2010
    USA
    Check out Baja Ron he sells heated gear at good prices..The heated gear does work well when you get older.. I crank mine up and drive..
  9. #29
    Oct 2011
    I did check with Ron and his price was better the Warm and Safe direct,so I got my wife a liner and gloves and a controller for Christmas. She doesn't read here so no worries. I am also having it delivered to the office so she wont see it. I just finished wiring the Spyder for both our clothing sets so she will be set to go. We are going to San Diego in Feb and I want her to enjoy the trip. Her first real trip on the Spyder.
    Happy TRAils/NSD
    Paul
  10. #30
    Oct 2010
    USA
    well good luck sounds like you are all set enjoy the ride!
  11. #31
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    We use Gerbins with inline potentiometers to control the heat needed.
    Liner jackets and gloves work very well. Keep your "trunk" warm and your blood flow is warmer to other parts of the body.
    Rosy
  12. #32
    10+ Posts
    Apr 2013
    So Cal
    I use http://www.cyclegear.com/lp/freeze-out does a great job of blocking all the cold air that goes through your normal clothes and the prices are right.
  13. #33
    Dec 2014
    A last thought ... what ever you wear to keep warm, you have to be comfortable as well as warm. When you get "too much" on, at the bulky stage, riding becomes labored and no fun, not too mention you don't want to be the guy that takes 20 minutes to gear up and down at a 10 minute gas stop.
  14. #34
    Oct 2010
    USA
    As long as you are warm and comfortable its all good.. My limitations on cold weather riding have changed since I am not in my 20's anymore
  15. #35
    2500+ Posts GARYD's Avatar
    Oct 2011
    GLEN ELLYN, IL. USA
    Who wears anything other then normal riding gear at those temps??? 45*~50* that's regular riding temps.....for me anyway.
    Jan. 1st I did our FYAO ride - temps = 24* that's when the heated gear comes out.
  1. Riding gear on 2 wheels vs 3 wheels
    By Doctoss in forum General Discussion
    Last Post: 10-05-2015, 09:12 AM
  2. Winter(snow country) riding
    By sparky1597 in forum General Discussion
    Last Post: 10-22-2013, 12:47 PM
  3. starter gear teeth 12v 1600 vw of the gear
    By bluedog in forum VW Powered Trikes
    Last Post: 07-24-2013, 04:22 PM
  4. Riding gear paid dividends
    By Teal in forum General Discussion
    Last Post: 06-28-2013, 08:42 PM
