Hi, I am wondering where to buy the battery connectores that mount in the trunk so I do not have to remove the left tire in case I need a battery charge.
Thank you
Thank you
Here ya go. I got a set that included the bracket. Search around the site and I'm sure you'll find it, if you want it.
http://www.jegs.com/i/JEGS-Performan...0315K/10002/-1
I found the other one.
http://www.jegs.com/i/JEGS-Performan...0314K/10002/-1
Does anyone have a picture of where they mounted them in the trunk? I'm trying to figure a place for them where they won't interfere with anything with the trunk stuffed. I got the bracket to mount them to the trailer hitch, but I think in the trunk may be better. Thx Rick
If you're just looking for a charger lead, I have a set of leads hooked to the battery from a Battery Maintainer. The SAE plug sticks out from under the seat. You could also use this lead with an adapter to coax for heated gear.
Stallion #378
Suzuki Burgman 650
I came up with an alternative. I connected a #4 gauge wire to the positive battery terminal and routed it out the rear of the trike and caped it at the end. I can connect a ground any place on the frame. Just couldn't justify drilling holes in the trunk for something that may never be used.
I mounted mine above the gas tank through the trunk back right under the left side of the roll bar. Easy to get to from both sides. They do not stick out much into the trunk area and with the caps on shorting is not an issue.
I got mine from JEGS and mounted them it the trunk. Haven't needed them yet but it will come in handy if needed.
