ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  1
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 41
Thread: Future V-8 build questions.
  1. #21
    Quote Originally Posted by vw driver View Post
    Not the same........those are honkers.
    Thought those were noses .... I'm so confused .... again ..
  2. #22
    5+ Posts shameless's Avatar
    Jul 2014
    Lowell OH
    so the way I understand it, the more trail, the harder it is to steer a trike, but too little trail and you get front end wobble?
    also just for grins is it possible to do a double fork set up, or is it just a bad idea all around? I know someone with a water jet that maybe I could build the mounts and spacers to make this happen, as long as its not dangerous or just too costly comparably
    Name:  double forks.png
Size:  28.8 KB<---side view, top view of fork mounts at tree-->Name:  double fork mount.png
  3. #23
    Jul 2014
    Lowell OH
    Why not save yourself all the hassle and buy one of these. You'll probably end up spending about the same money.
    Attachment 26066
    actually I love that, but cant afford it all in one shot lol
  4. #24
    300+ Posts vw driver's Avatar
    Jan 2014
    Tacoma, WA USA
    So how is your credit? Make payments, people with the $40,000 trikes aren't paying cash, they're making payments, it's just like buying a car. As you are probably realizing, building a safe, reliable trike is a complicated process, not for the faint of heart.
  5. #25
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by shameless View Post
    that is correct again i find 1.5 - 2.5 works for me
    yup seen that done as well as side by side doubles but unless you want to be "different" i wouldnt go through all the work... if you do you will need a way to keep the rocker at the bottom from moving at all .. if it does the distance between the sliders will vary and bind.. i dont think dollar wise there is any comparing leading link ...to the double forks and as a bonus if you put several pivot holes in the swing arm on the leading link you can change the trail in a blink if you need to
    a bunch of different LLs here
    https://images.search.yahoo.com/yhs/...&hsimp=yhs-002
    some pretty nice others ... wouldnt want to ride them
    i think one think a lot of guys miss it the part that ties the rockers together behind the wheel.. thus the leading "LINK" the springer style with just the rockers an no link will have a considerable amount of flex compared to the LL
  6. #26
    Jan 2014
    Tacoma, WA USA
    Easy to understand rake and trail.
Size:  25.6 KBName:  imagesb.jpg
  7. #27
    350+ Posts
    Feb 2013
    Houston,Ms 38851
    nice picture, extend frame line to ground make mark ,square up from center of axel make mark measure distance. axel mark should be toward tike.
  8. #28
    Jan 2014
    Tacoma, WA USA
    Yes, if shopping carts had more rake they wouldn't wobble so bad.
  9. #29
    Jul 2014
    Lowell OH
    so, basically, as I understand it, I can chop the front end out as far as I want, as long as it'll hold the weight, and I can get my Trail down to a max of 1-2 inches, keep my steering, comfort, and stability?
  10. #30
    Jan 2014
    Tacoma, WA USA
    Sure.
  11. #31
    350+ Posts
    Feb 2013
    Houston,Ms 38851
    I don't think this will work, front
    left compress , left rear stays put creates pivot point ,right front stays put, right rear compress creates oppiset pivot point ,makes big wollbble not good.
  12. #32
    750+ Posts
    Jan 2010
    east windsor ct
    actually shopping carts have no rake at all
    i believe usually the reason for their wobble is that wheel is barely touching the ground
    keep in mind if you use a slider type front end, at some point they stop sliding freely.. have no idea what that angle is
    and the more rake you have the more stress on the neck, tree, and tube as you mention " as long as it'll hold the weight",
  13. #33
    Jan 2014
    Tacoma, WA USA
    Here is something I found on Graig's List in Seattle. It's from a '97 Cadillac Catera. Something like this would be a great start for a trike, disc brakes, IRS. He only wants $150 for it.
  14. #34
    100+ Posts rrunner's Avatar
    Oct 2010
    Zuni, New Mexico, USA
    That is one nice setup for a trike
  15. #35
    Jan 2014
    Tacoma, WA USA
    Quote Originally Posted by rrunner View Post
    I thought so too. If I was building a V8 trike I'd go buy it.
  16. #36
    40+ Posts Marty's Avatar
    Jan 2012
    Williams Lake British Columbia Canada
    independent rear is the best way period. no vibration, no torque over problems and rides like a dream. I built the black bike in your pics, it had a 45 degree rake in that picture. It now has a 40 degree rake and steers big time easier. I've had it way past 100 mph it handles great and now is pulling a trailer.
  17. #37
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Default Future V8 build questions
    Take a look at this trike. http://www.k-jentrikes.com/phobos.html Apart from the exotic metal and frame design, the driveline / suspension is probably the cleanest you can get. I'm using the C5 A-arms for my mid-engine VW trike and using a steel frame duplicating the C5 geometry. I found a complete C5 upper frame section, suspension, and transaxle on eBay for $500.00. It only took about a year of looking before it showed up. If you're in the planning stage, I'd think it's a good place to start. It is an electronic trans but there is a lot of info on how to control it on the Internet just takes some surf time. I'll be starting a build thread on VW trike forum soon. Good luck on your build!
  18. #38
    200+ Posts
    May 2011
    Orlando,Fl--USA
    Default Future V8 Builfd
    Shameless,
    I have built 1 V8 trike and modified another.
    I have spent many hours searching the web, talking with professional trike builders and talking to other V8 trike owners
    to learn about these beasts.
    Here are the things that I found out:
    1--Air Ride suspension is the best ride.
    Whether it is air shocks or air bags.
    2--The standard type of hydraulic forks from the bigger bikes-Harley, Honda, Yamaha,etc...
    Cannot handle the weight of a V8 trike.
    All that weight on the front end will blow out the fork seals.
    There are some heavy duty springer type front ends out there with a large center spring.
    Some of these also have an air bag instead of the spring.
    A leading link front end is also a great ride- if it is heavy enough.
    You can also switch out the coil -over shocks for air shocks.
    I have a monster front end for sale.
    It has an air bag for suspension.
    It is built from 2 inch DOM and is wider than normal.
    Contact me at drumdoctor@live.com if you are interested.
    Mike
    Ride safe!!! Lots of idiots out there!!!
  19. #39
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    hi shameless
    I am using a 180x65x16 for front tire on 5 inch wide wheel on my trike build, you may want to consider a leading link front end. you can use coil over adjustable shocks that are for front end of car/street rod. build your trike then weigh it on all three corners and come up with springs you need for shocks. I am considering QA1 shocks for my front end...
    just food for thought.
    magoo
  20. #40
    Aug 2015
    Great Falls
    Default v8 trike
    Does anyone know if the boyz from v8trikes are still around? They had adecent frame. Originally they where from oregon, but they moved to texas after awhile. They always advertised on btw... Thanx
  1. Future Triker
    By mcridernj in forum New Member Introductions
    Last Post: 05-13-2011, 10:35 AM
  2. future triker here
    By jerry in forum New Member Introductions
    Last Post: 05-04-2011, 10:10 AM
  3. Got my future trike
    By Sacred Steel in forum Harley Trike Conversions
    Last Post: 12-17-2010, 05:14 PM
  4. Car of the future?
    By Nana in forum General Discussion
    Last Post: 07-06-2009, 06:08 AM
