Likes Likes:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
Thread: Throttle Lock
  1. #21
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Quote Originally Posted by hogcowboy View Post
    With your customization of the back side and using your finger, does that mean you are able to rotate the fat part down because you are taking the tension off? If so that's not a bad idea. I've not put one on because I wasn't sure I could get it out of the way quickly. That would sure do the trick.
    yes it can work that way as well as flipping it over the grip backward, its easier to flip it backward though.
    If you have fringed grips it will also not get hung up on the seams.
    Enjoy life now!----------IT HAS AN EXPERATION DATE
    1989 HARLEY DAVIDSON TOUR GLIDE ULTRA CHAMPION- A WOLF IN SHEEP'S CLOTHING-(CUT YOUR WOLF LOOSE!)
    the difference between a good trike and a bad one depends entirely on the integrity of it's builder!
  2. #22
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Be sure you are using it correctly. Thumb lever down is ON. but you can roll thru it. Thumb lever up is OFF and throttle should work freely. Do not lube it. It holds the throttle using friction. the nut and spring provide the friction.
    Ridin' three and free. Ain't never goin' back
    2003 1800 Gold Wing Trike w/Roadsmith kit. Northeast Region Trike Riders on F B.
  1. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  2. Do you use the 'Lock' key position?
    By rmrc51 in forum Honda Trikes
    Last Post: 03-31-2015, 02:57 AM
  3. Lock Jammed
    By biddlej in forum Honda Trikes
    Last Post: 08-29-2013, 11:03 PM
  4. Cannot Lock Handlebars
    Last Post: 11-18-2012, 02:08 PM
  5. What is the best way to lock my trailer up
    By Boscoporp in forum Trailers / Campers
    Last Post: 11-20-2011, 03:58 PM
