Likes Likes:  11
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: 2002 Roadhawk questions
  1. #21
    10+ Posts
    Jul 2014
    Ocklawaha Florida USA
    Default brakes,,,
    Yes you can get some or barely ok braking power on VW drum rear brakes but man,,,they don't even come close to comparing to a disk brake conversion. In saying that the front VW wheel cylinders have been used on the rear I hear, as I guess they might have a bigger piston in them?
  2. #22
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Quote Originally Posted by 33trikes View Post
    Yep, the fronts are a larger wheel cylinder, but as you stated, "they don't even come close" to disk brakes.
  3. #23
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I don't know what barely ok is. But on my trike you can barely rest your foot on the pedal and you're gonna be stoppin. Its almost a pain the aze in traffic. I can smoke the tires at any speed. And effortlessly at that. I have the smallest master and the front brake cylinders. Of course my trikes made from a 68 bug with irs rear suspension,maybe others have different size shoes.
  4. #24
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default 45 mph vibration and brake issue
    Quote Originally Posted by Sidecarbill View Post
    This is MR TRIKE> I agree with the smallest master cylinder, 17mm bore single with remote fluid reservior. Last vw part numbers are 023B. With drums, remove and sand shoes and drums with coarse sandpaper, then adjust 1 shoe at a time by turning star wheel adjuster on backing plate till you can't rotate wheel, that centers the shoe in the drum, then back off 1 klick at a time so you have a slight drag. Do the same with other 3 shoes.
    With removing an glaze and adjusting like I said, you will have the best drum brakes possible. Also make sure you have Front Wheel cylinders from super beetle 22.8mm in place. Have said all that, the best brakes are gotten by going to EMPI on get a disk brake conversion. As for the mid speed vibration, 90% of the that is caused by out-of-round rear tires. Simple way to check is jack up 1 wheel at a time and hold a piece of white chalk lightly against the center tread and rotate by hand. If you leave a complete line on tire, your tire is round. Rest your hand on something steady. The only way to correct an egg shaped tire is the have them Shaved on the trike. Call around your area and find a shop that can true them on trike. That way the tire, rim, wheel adapter, if you have one is Trued to center of axle.
    That same shop should also balance tire on trike with a laser light. I have 40 plus years at this and it works. Good Luck Dick
  1. Roadhawk Trike
    By bigjoey38 in forum Other Brands Trikes
    Last Post: 10-05-2014, 06:03 AM
  2. 99 roadhawk rebuild
    By reno69694 in forum VW Powered Trikes
    Last Post: 06-17-2012, 12:20 AM
  3. roadhawk fender bra
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-23-2012, 11:41 PM
  4. Roadhawk upgrades done
    By 2blackbelts in forum General Discussion
    Last Post: 04-15-2012, 05:25 AM
  5. Roadhawk
    By jlberkey in forum VW Powered Trikes
    Last Post: 02-05-2010, 12:16 AM
