Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  8
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 53
Thread: Trunk Lid Warning Light
  1. #21
    150+ Posts lah2420's Avatar
    Oct 2013
    Texarkana, AR
    I love this site. It's good for us dummies. Mine popped open once when I went across an uneven road that flexed the trike in every direction. The button was hard to push and had to have the key inserted to pull it out. The dealer said not to worry, that it would free up over time. After reading here I had a "duh" moment. I found some dry lube and squirted some on and in the latch. No more hard to push. Button pops out all the way. Can just push it closed instead of slamming it and hoping it latched.
    Thanks guys for helping this dummy out. I'm sure I will be gleaning more info from you.
  2. #22
    500+ Posts WindyOne's Avatar
    Dec 2009
    Va.
    I have had my trunk pop open twice now during rides. I keep it locked and I always pull on the lid to make sure it is solid. Something flexes the body and I think that is what makes mine open.
    I adjusted it this morning and found the edge dinged up so I turned it and adjusted it out just a little bit and sprayed some lube on it. While I agree a better latch would be the optimal way to go I would like to have a warning light until that happens is ever.
  3. #23
    Should be an easy light to rig with with push to off, and a light wired to the battery, maybe a fuse for safety.
  4. #24
    Iv'e been thinking of rigging a switch on the tail gate of my pick-up.. i've driven off a few times with it open.. The Tri should be easier to rig' what with a lot less wire to route..
  5. #25
    60+ Posts jackt's Avatar
    Great Bend, KS USA
    Default Trunk pops open FIX
    My 13 always come open on road had to have pin replaced because it broke.
    My 14 also popped open a lot until I started NOT SLAMMING I now push on both sides top right and left corners until it kind of snaps and the slightly pull to unsure catching then always lock.
    Have not had problem since.
  7. #26
    100+ Posts
    Sep 2015
    Lexington
    Default Refrigerator Door Switch
    would almost work. Mine popped open twice. At dealers suggestion I lubed thoroughly with a dri teflon spray called Tri Flo. Seemed to work, no more issues and I have been using the trunk quite a bit. I do give it that tug.
  8. #27
    40+ Posts
    Aug 2015
    Oklahoma City
    Not to belabor the point, but how about installing one of those small child-proof latches that let a door only open a bit before you have to release it to open fully. At least if it decides to open at 70 it will only open a bit.
    Just a thought.
  9. #28
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Small bungee cord around the 2 support cables will let it drop only enough to then pull down and release the bungee cords.
  10. #29
    Mar 2017
    Topeka, Kansas, United States
    Default Tri Glide Trunk door warning light
    Quote Originally Posted by joeychitwood View Post
    Thanks for the replies. Has anyone seen a trunk lid warning light that would alert the rider that the ID has opened? I can probably devise something, but if a kit already exists, I would rather use it.
    My trunk door did the same thing twice, I designed a setup for my bike that works great. when and IF the door pops open again unexpectedly, I have a red light on my right side accessory switch location that shines bright enough that I can see it during the day too.
    This Forum won't let me attach a photo
  11. #30
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Quote Originally Posted by Bigsteps View Post
    You should be able to attach a photo now. Welcome!
  12. #31
    Welcome to Trike-Talk...Bigsteps...
  13. #32
    welcome aboard
  14. #33
    60+ Posts 30glock's Avatar
    Jul 2016
    Somewhere in usa
    Simple solution would be to rig up some hooks and add a cargo net, this way If your trunk lid opens you lose nothing. Mine popped open once, since then I have been locking It and I have had no Issues.
  15. #34
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I must have a rabbits foot up my a$$. I have never had a problem with either on my TG's trunk door. And I have never lubed them either. Also I have never slammed them, maybe that's the reason.
    Now watch!! The next time I go for a ride the damn door is going to open.
    I like the idea of a warning light. Why H-D hasn't thought of that is beyond me. That would bring in a ton of money. I bet every owner would buy one, I would.
    Trunk Warning Light = $150. Their cost .79 cents.
    IBA#61162
    PATRIOT GUARD
    USMC
  16. #35
    I would buy two, and use one on the tailgate on my Pickup...
  17. DKCustoms postbit
  18. #36
    300+ Posts
    florissant
    my god ! what's wrong with HD ? the auot industry has been keeping the trunks closed on cars for years, why can't HD ? piss poor design is the problem. fire these nitwits and get someone who can design a fix.
    hardheaded
  19. #37
    40+ Posts
    Oct 2014
    West Liberty, Ohio
    My door fell open once, good nothing fell out, bad it was inside the trailer and chamfered the top against the ramp. I have a "new" beveled edge door for sale. I little lube has prevented a second time.
    2014 Tri-Glide
    2012 RKC Tequila Sunrise/HD Orange
    2009 Nightster, orange
    1999 Valkyrie, orange
    1980/82 CBX
  20. #38
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    I've had the issue a couple times but only when I had the door locked. Don't think I would want a warning light necessarily, but certainly would like a latch that holds the door closed.
    Dave
    14 HD Tri Glide
    H.O.G. Member
  21. #39
    100+ Posts jimgpayne's Avatar
    Oct 2012
    Nashville, TN
    So I've been thinking....
    I have the interior trunk lighting kit installed that automatically turns on whenever the trunk is open (a pressure switch by the hinges).
    So I bet I can tap in a small wire and run it out the trunk and under the gas tank to the front fairing and then simply use one of those small LED indicators to do the trick.
    Then overtime the trunk opens, the interior lights come on *and* a light I can mount in the fairing comes on.
    Should work right? The parts are less then $10 on Amazon. Has anyone actually tried this?
  22. #40
    Sep 2014
    Box Elder, SD
    Quote Originally Posted by jimgpayne View Post
    You just gave me the idea. I think I will give it a try. Years back I installed one of those fake blinking security lights in an old truck. I think the hardware would be great for this. If I do it I will let you know. Jim
  1. My lower trunk open warning does not show up on dash
    By SMSgt in forum Roadsmith Trikes
    Owners Forum
    Last Post: 08-24-2015, 03:20 PM
  2. trunk light conversion
    By chickie in forum Honda Trikes
    Last Post: 08-19-2012, 01:55 PM
  3. Head Light Warning Buzzer
    By Mattel in forum Stallion Trikes
    Last Post: 08-10-2011, 03:30 PM
  4. Stallion Trunk Light
    By victor in forum Stallion Trikes
    Last Post: 07-13-2011, 10:36 AM
