Results 1 to 14 of 14
Thread: Exhaust question
    Jan 2015
    Medina
    Default Exhaust question
    We have a 2014 Vulan 900 with a Storm trike. We love it. Its kind of loud compared to my other bikes. The exhaust leaks where it meets the header. I took the mufflers off, cut wider slits in the pipe and re clamped so everything was thight. We had to do all 4 connections, both mufflers and both ends of the crossover.
    It was all quiet and great for less than 1.000 miles. It now sounds like a harley again.
    Looking closely, the muffler moves with the body of the trike, yet has no flex coupeling to the head pipes.
    Its loud and when I coast, I get exhaust fumes. Yuck!
    I think I am looking for a flexible piece of pipe like in a car but the right size.
    Any help?
    Anybody else have a problem like this?
    David
    Quote Originally Posted by StudandSlick View Post
    Not sure that's a bad thing ...
    Seriously, if the pipe is not loosening, have you considered muffler tape, seals well.
    Jan 2015
    Medina
    Default I knew it
    I should have not used the H word. Sorry. This is the loudest bike I owned in a long time. We got the wind noise down, but the exhaust leak is down right annoying.
    Are you talking about the asbestos tape I sometimes see on racers?
    The pipe is going to flex there, I was thinking maybe that asbestos tape and a wide strap clamp.
    Thanks for some help
    David
    David
    Yep that's the stuff ... should flex ... should seal ... worth a shot.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Default Vulcan 900
    Any help?
    David
    The body is attached firmly to the frame of the motorcycle. The engine is mounted firmly to the frame. Once they are all attached together the body, engine and chassis become one unit excepting for the front and rear suspension. The mufflers attach to the body because the exhaust pipes attach to the engine, which like the body are firmly attached to the frame.
    A flexpipe would not change anything in the design of the trike. If you have an exhaust leak, that is a different problem. There were gaskets on those mufflers and s-pipes, might they be missing ?
    Jim Murphy
    Iron Butt Rider 2001
    Jan 2015
    Medina
    There were no gaskets on the pipes.
    It leaks where the header meets the muffler. Engine to header is fine.
    When I first got it, I tightened the crossover pipes a couple times because they were rattling.
    Then my son and I took the mufflers off and started over. Everything was tight and quiet for a short while.
    Do I need gaskets?
    Long trip through the wineries in the finger lakes this weekend.
    David
    Is there a parts picture some where?
    Jan 2015
    Medina
    OK, I looked for gaskets. None shown where the pipes meet, just at the port on the head.
    Still open to suggestions, I would like this quiet and no smell.
    I found a pipe wrap kit for $64.95. If this would fix it, I will order it.
    David
    David
    You can probably get some asbestos wrap from Wally world or auto zone ... you won't need much, just enough to cover joints.
    Jan 2015
    Medina
    I got under the bike. I had her bounce the bike. Then she let the air out of the shock and bounced again. Yes the mufflers move with the bike and not the suspension.
    Taking the chrome off now to see what is loose.
    David
    Jan 2015
    Medina
    It is leaking by the clamps. I took off the clamp, lubed the pipe and clamp. I tightened the clamp, then tapped it with a hammer and dolly around the clamp and pipe. Then tightened the clamp a little more. Pound and tighten until it becomes too much. I did both pipes. Its now quiet.
    I measured the front lower or forward head pipe it is 1.375" OD. The rear pipe is 1.495" That leaves .12" gap split in half because its a circle minus the thickness of the pipe. .062"? That leaves .058 gap if its all on one side.
    Thanks for the help, I hope it stays quiet.
    David
    Jan 2015
    Medina
    Default Its still quiet
    Its been 1,000 miles, still quiet.
    Thanks a bunch.
    David
    Good deal ...
    Martinsburg, WV
    David
    That fitment is not very good and they don't list gaskets for it (see below). Page 17 & 18. Now what you could do is use the wrap mentioned above to fill the gap between the pipes and then tighten the clamps. Use an exhaust tube expander to change the size of the outside pipe if necessary once the wrap is installed.
    http://www.championsidecars.com/uplo...ke_install.pdf
    Jim Murphy
    Jan 2015
    Medina
    We went to Watkins glen for a couple days. It was quiet, the bike performed flawlessly until the ride home. It loosened up a little and the chrome cover is also rattling.
    I have the answer, maybe later this week.
    Loving the trike. 5,000 miles so far this year.
    David and Michele
  1. Exhaust
    By howardg in forum Honda Trikes
    Last Post: 05-17-2015, 08:01 PM
  2. Question on exhaust
    By Tazmanken in forum Harley Tri Glide
    Last Post: 12-25-2014, 06:13 AM
  3. Question About SUPERTRAPP Exhaust - Soliciting Opinions
    By M.A.T. in forum Harley Trike Conversions
    Last Post: 11-01-2011, 06:22 PM
  4. Question on Exhaust heat shields
    By Thomkm in forum Harley Trike Conversions
    Last Post: 08-31-2011, 10:26 PM
  5. Exhaust
    By Silver Eagle in forum Stallion Trikes
    Last Post: 07-22-2009, 12:53 PM
