Speed Bleeders
Likes Likes:  14
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 80 of 80
Thread: flrt running lights
  1. #61
    70+ Posts topsgt75's Avatar
    Jul 2015
    Lexington, Ky
    Quote Originally Posted by Springman2007 View Post
    Yes Please!
    Thanks Springman
    I think this is the part number for the kit I used for my lights: 69289-05. I did a search on eBay and found a used set the was from a 2010-2012 Road King. The used set came with hardware and lens/lights. If you get a kit from Harley, the lens/lights will be additional. The ground wire attaches to the light housing and grounds through the frame. I just had to run one wire from each light to the wiring harness/accessory wiring connector I used. Mine stay on all the time, I did not wire them through a switch. They are even on with high beam.
    Pics to follow.
    Quote Originally Posted by cigarman View Post
    Yes please post the part number and the pics. Did you do your own switch and wiring also? Any help would be appreciated.
    See my post above to Springman2007.
    I did not use a switch for the lights, I ran the hot wire to an Accessory connector(I think it is the running light connector in the main harness, I can give you the location for it!) because I wanted the lights on all the time.
    Pics to follow!!!
    PM me if you have more questions.
Size:  651.6 KBName:  image.jpg
  2. #62
    350+ Posts Springman2007's Avatar
    Sep 2014
    Grafton, OH, USA
    Quote Originally Posted by topsgt75 View Post
    MANY THANKS!
    Best Wishes,
    Springman
  3. #63
    30+ Posts
    Jul 2016
    Roselle, Illinois
    Thanks for the info.
  4. #64
    Jul 2015
    Lexington, Ky
    Got a deal on Amazon from Eaglelites!! Upgraded from LED bulbs to straight LEDs!!!
    Hate it when a pic turns!!! Oh well, you get the idea!!!
  5. #65
    Sep 2014
    Grafton, OH, USA
    They look great! I have been holding off going with LED heads and tails. I like that the conventional bulbs are/were commonly available.......but, as time goes on, LEDs seem to be becoming the mainstream - and the price of them is starting to fall. In time I will probably convert; but, not now.
    Best Wishes,
    Springman
  6. #66
    100+ Posts Hrolfr's Avatar
    Aug 2015
    Holiday
    Best Wishes,
    Springman
    The cool thing about Custom Dynamics LEDs, lifetime warranty on the LEDs so there isn't the worry of then burning out. The other thing is that on the FLRT they are a drop in replacement in most cases (I replaced the whole headlight assembly so more than a drop in) so if something does happen you can still just plug in a regular bulb. Something to think about
    Has anyone added the passing lights while using the clearview shields extended windshield? and/or the JES fangs???
  7. #67
    10+ Posts
    Jul 2016
    Goose Creek, SC
    Default Day Running Lights
    I was at the HD Dealer today looking at lights. They have White LED Lights that can go in the two bullet turn signal lights. The are white when running but blink Amber when using turn signal. They are a simple install by just replacing the bulbs and the cap from Amber to Clear. Cost for bulbs is $89 and the new clear lenses are $10.
    They also have a LED Bulb to replace the Head Lamp and its only $70. Again, its just plug and play.
    Thinking about trying them on my FW. I road the other night for the first time and having the two bullet lights white vice amber will make a big difference.
  8. #68
    Aug 2015
    Holiday
    Quote Originally Posted by Charlestpm SC Freewheeler View Post
    The turn signals are what I have. They are awesome, Custom Dynamics makes them. The headlight bulb for $70 is what I had at first, the light pattern is not directed properly with the factory reflector, and it gave me an electrical fault light if I went from low to high and back a couple times.
  9. #69
    Jul 2015
    Lexington, Ky
    Quote Originally Posted by Hrolfr View Post
    Hrolf....look above at my last post with my LEDs from Eaglelites.....I have a 2" wider Clearview windshield, and you can see the top half of my JEG fangs!!!! If you want I can get a better pic!!
  10. #70
    Aug 2015
    Holiday
    I missed the fangs, and thought that was a clearview shield! Just didn't want to ASSume LOL
  11. #71
    5+ Posts
    Aug 2016
    Cogan Station, Pa USA
    Default Light bar
    Quote Originally Posted by 0pini0nated View Post
    How about conventional H-D auxiliary lights? Beside halogen bulbs (which I use 'cause I'm frugal), H-D has a LED bulb set too (for more $).
    What light bar did you use?
  12. #72
    5+ Posts
    Apr 2016
    No where, CO, USA
    Cool Easy fix and love them....
    I solved this problem with the LED set up from Custom Dynamics and love them. I really like the way the clear bright outer ring comes on again when the orange signals go off. So much more visibility in the day time and more light at night. For plug and play, these jewels can't be beat and are worth every penny. I do suggest the clear lenses so they shine brighter and do what you would expect of them. Good luck.
  13. #73
    50+ Posts foundryratjim's Avatar
    Aug 2015
    Burt
    Quote Originally Posted by ChuckC64 View Post
    I did the same,but i used smoke lenses. If they diminish the brightness its not enough to worry about. I have cd led brake lights with smoked lenses also and they work great.
  14. #74
    900+ Posts
    Apr 2011
    Bellville, Texas, USA
    Same here except I went with smoked lens. They are plenty bright and very quick and simple plug and play.
    Sunman
  15. #75
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I find my M8 Freight Train plenty bright, tho I do miss my FLHT passing lamps some times
  16. #76
    5+ Posts
    Feb 2016
    El Paso, Texas, USA
    Has anyone added passing lamps and relocated the turn signals to the added passing lamp bar? If so send pics and parts info please.
  17. #77
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Road King light bar works on FLRT. I bought an '02 Electra Glide Police light bar off Ebay. It came with the turn signals but I removed them. # 109 ( 4 pin)connector is located l/h side under tank in the caddy.R/Y wire is power,Blk is ground,Be/Gy, is BCM.Remove l/h signal light nacelle panel for the signal light connector(31A&B) which is a 6 place Tyco 70 multilock.Position 5&6( empty) are for Auxiliary lamp power.I just crimped pins onto wire and inserted them. The riser cover has two plastic plugs so you can mount a toggle switch. I cant post pics.
  18. #78
    30+ Posts
    Jun 2018
    South africa
    Freewheelers outside the US (EU & SA) are sold with running lights that also double as the headlight. The traditional 7” headlight is blanked out, I have no idea why.
    Point is: HD makes the running light cluster for the FW. You can google the Harley Europe or Africa website to see these.
  19. #79
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Last time I priced out those Euro lamps they were $236.00 for each bracket alone.They are not fog or running lamps but actual headlamps. All told I think it was like over $700.00.They do look cool though.
  20. #80
    30+ Posts
    Jun 2018
    South africa
    Wow, that’s Harley pricing for you....
  1. Running lights
    By poppajim in forum General Discussion
    Last Post: 08-31-2015, 06:28 PM
  2. motor trike running lights
    By dano309 in forum Honda Trikes
    Last Post: 05-29-2015, 05:22 AM
  3. Running Lights
    By Dean H in forum Stallion Trikes
    Last Post: 01-15-2012, 10:49 PM
  4. Safety Running lights
    By deanone98 in forum Stallion Trikes
    Last Post: 10-15-2010, 07:34 PM
