Likes Likes:  2
Results 1 to 14 of 14
Thread: 2ndchance having 2nd thoughts (a little humor)
    20+ Posts
    Aug 2015
    St. Louis
    Default 2ndchance having 2nd thoughts (a little humor)
    I just hate to chop my 2015 two-tone Chieftain in half to get a trike, so I been researching sidecars. Today I was looking at some rigs on-line when my wife walked by and started looking also, she said I would ride with you in that I just don't like riding behind you on two wheels. BANG! I can now see myself with a Hannigan sidecar rig.
    Question - I read conflicting info on tires motorcycle or car tires, and where do they go.
    Do you have to disconnect the sidecar to change the rear tire. I know the steer-lite is a must.
    250+ Posts Hannigan Motorsports's Avatar
    Jan 2012
    Murray, KY
    2ndchance,
    Thanks for your Post and questions.
    We take the Stance of continuing to run Motorcycle Tires on the Bike when used as a Tug for a Sidecar. UNLESS the Rig is specifically designed and produced to run Automotive style Tires (such as the HMS HP Sidecar). We advise running standard Bike Tires on your Chieftain when mating to the HMS Heritage Sidecar.
    It is not a "Requirement" to remove the Sidecar to change the rear Bike Tire. However, it is obviously easier to perform that swap with the Sidecar removed. Also most Bike/Tire Shops are not equipped with proper Lift(s) to accommodate the Rig intact and prefer to have the Sidecar removed prior to replacing a Bike Tire.
    Not an issue as with only 2 Combination Wrenches and about 10-12 minutes you can have the Car off and same to reinstall. You only have to remove 4 Bolts at the Bike Mount side of the connecting Struts, a Quick-Disconnect Brake Fitting (much akin to a high-pressure Air Chuck), and a Male-Female Electrical Connector and Ta-Da! It's Off or On without the need or necessity of adjusting or re-alignment. Simplicity at its finest.
    All the best in your decision and we appreciate the opportunity to earn your business and trust regardless of which direction you take.
    By the way,
    Most times a 2nd Guess prevents a 1st Mistake
    Murray, KY
    270-753-4256
    hannigan@apex.net
    www.hannigantrikes.com
    80+ Posts Trk Ldy's Avatar
    Apr 2015
    Pa
    Saw two different Hannigan sidecars this weekend and yes, they were on an Indian, they looked great. Terry spoke to one of the owners and they love it.
    20+ Posts
    Aug 2015
    St. Louis
    Quote Originally Posted by Trk Ldy View Post
    I have never seen a sidecar rig, but I am currently reading any info I come across concerning sidecars. In some of the forums I am looking at the participants kind of scare me about wanting a sidecar, but I plan on going ahead with my choice. Granddaughter need to do home work got to go, got a lot more to say I will be back.
    20+ Posts
    Aug 2015
    St. Louis
    Most of the info I'm reading refers to quite a bit of off-road riding, I will strictly be riding on the slab with what I see as a pretty big rig. It would be nice to hear from sidecarist that ride strictly on the slab. It would bolster my will to do this (gonna do it anyway).
  6. #6
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    Quote Originally Posted by 2ndchance View Post
    well I have been riding with my current sidecar for about 10 years we don't tour ride much anymore but use to no problem at all,,, a 300-350 mile run in a day is not uncommon even now if we are enjoying ourselves. wife loves the sidecar plenty of room for all her stuff!! when we stop for a break someone always has a question about the setup,,, and kids can't resist it so watch out for sticky hand prints in sidecar!!
    magoo
  7. #7
    150+ Posts 5x40's Avatar
    Oct 2013
    Land Between the Lakes, Tn
    can't speak for other models of hacks or bikes, but we owned/rode a GW for 7 yrs w/a Hannigan Astro Sport attached. we live 40 miles from the factory. we bought, order, and had it installed at the Murray business. it was a great combination and completely trouble free for those 7 yrs.
  8. #8
    Dec 2012
    washington il.
    hi 2edchance
    if hannigan has the option for handle bar mounted lean angle control for your sidecar I would buy it!! and raked trees,,,
    they will enhance your riding comfort for sure
    magoo
  9. #9
    Oct 2013
    Quote Originally Posted by irmagoo View Post
    hi 2edchance
    magoo
    we had them install the electric camber control, aka lean control on ours. worked like a charm. the control switch was handle bar mounted.
  10. #10
    Jan 2012
    Murray, KY
    2ndchance we have both options for the Indian on our Heritage Sidecar. The Electronic Camber Control (ECC) is available on them as well as the Steer Lite kit for increasing the rake on the front of the bike which can dramatically reduce steering input required as well as reduce head shake from rough/uneven terrain while on the road. Combined both make for a very compliant and solid feel while enjoying the open road.
    Please feel free to call or email us with any questions you may have.
    Murray, KY
    270-753-4256
    hannigan@apex.net
  11. #11
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Hannigan builds a beautiful sidecar rig specifically built to match the styling of your Indian and they've been building sidecars for many years and are masters of their craft. You wont go wrong with a Hannigan sidecar and if you decide at some point in the future to go with a Hannigan trike conversion, you can always sell the sidecar.
  12. #12
    Apr 2015
    Pa
    Someone just posted a picture of a willow and cream Vintage with a Hannigan sidecar on the Indian Owner Facebook page. All I can say, is..... it is beautiful and classic looking.
  13. #13
    20+ Posts
    Aug 2015
    St. Louis
    For those that have not bumped into a post I posted someplace else, I did it ... I did it ... I did it. I placed my order for the Heritage sidecar.
  14. #14
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Congrats on the hack and enjoy.
    Your original story of your wife lookin over your shoulder. My GF was doin the same when I was lookin into trikin. Showed her a few pix and that was all I needed . Had one a week later. And no guilt feeling
  1. more trike thoughts
    By caveman50 in forum General Discussion
    Last Post: 11-15-2016, 07:41 AM
  2. Hello from 2ndchance
    By 2ndchance in forum New Member Introductions
    Last Post: 09-01-2015, 06:59 PM
  3. Thoughts on my new TG
    By SC Blue in forum Harley Tri Glide
    Last Post: 09-03-2013, 06:47 AM
  4. Outside looking in - thoughts
    By T and S in forum Harley Trike Conversions
    Last Post: 09-08-2010, 11:42 PM
