Speed Bleeders
Likes Likes:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: Downtube bearing
  1. #21
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Everything is out and ready for the new bearings to arrive. I had to remove the center race on the left side to allow me to apply heat all around the outer race and let the candle wax help. As I have the new newer forks, I used a socket that fit inside the backside of the tube (13/16) which caught enough of the outer race to be driven out.
    Now the interesting part is that none of the automotive parts stores can cross reference the 5201RS bearings. Miller Bearing has 5 options that starts at $50 for the China bearing up to $136 , these are for each as I didn't have an account with them. I went to Locateballbearings.com (800-409-3632) and also had several options and they recommended bearings that are under $40 delivered for both. They said it was a common bearing and were surprised at the prices quoted from Miller Bearing.
    Hopefully I be back up and running within a week.
    Tomg
  2. #22
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    It is crazy how the bearing company's can put such a high price on their bearings. Yes I do know there are different bearings and the way they are made but when you read the details and they read the same it just makes you think why pay so much. Just saying...
  3. #23
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Quote Originally Posted by Ed Hobgood View Post
    Can anyone tell me what the part number is for the bearing on the bottom of the downtube? I'm thinking I've seen this before but I can't find it anywhere. I was out for a ride last week and started to notice when breaking the trike pulled to the left. When I got it back to the shop I found the bearing on the downtube was completely worn out. I'm trying to get the old race out but it is going to need to be cut out. Yes I will replace both when I get a good part number.
    Thanks for any help.
    Ed
    The quickest way to remove the old race is to use a spot weld on the race its self.
    Take steps to protect surfaces you don't want to strike an arc on with electrical tape, Put your ground as close as possible to where you are working ( to avoid arcing through any other bearings etc. ) put a spot weld on the race, let it cool and it will almost fall out. (due to warping ) Plus the spot weld gives you a place to put a punch.
    It doesn't matter what size race it is, its only a question of how much weld you use.
    I used this method on heavy equip repairs for years.
    Enjoy life now!----------IT HAS AN EXPERATION DATE
    1989 HARLEY DAVIDSON TOUR GLIDE ULTRA CHAMPION- A WOLF IN SHEEP'S CLOTHING-(CUT YOUR WOLF LOOSE!)
    the difference between a good trike and a bad one depends entirely on the integrity of it's builder!
  4. #24
    Oct 2009
    Titusville, Florida
    Actually my last post should have read that the auto parts store could "not" match up the part number as it is listed as a industrial bearing and not an automotive bearing. So I was told by the auto parts store and the bearing locator I used.
    The spot weld probably works great if you had a welder ! Lol
    Tomg
  5. #25
    Oct 2009
    Titusville, Florida
    The old bearings are out and the new ones are in. I didn't know those bearings at the end of the forks made that much difference. The front end feels tighter. As the end of the forks are slightly tapered, I had to drive out the old and drive in the new bearings. I also had to put a beveled edge on the bolts that go thru the swing arm/fork in order to get the bolt thru the spacers in the swing arm. All seems to be good now. Wish I had changed those bearings 20k ago.
    Tomg
  6. #26
    Jan 2011
    Dexter, MO, USA
    Glad to hear things worked out for you. I know they can be a real pain to change.
  1. Feedback on Hog Trough Downtube cup holder
    By cagless in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-24-2015, 12:03 PM
  2. Front Wheel Bearing??
    By delta in forum Harley Tri Glide
    Last Post: 07-11-2014, 03:48 PM
  3. Bad Front Wheel Bearing
    By Oldmsocko in forum Harley Trike Conversions
    Last Post: 08-29-2011, 09:24 AM
  4. v8 trike steering bearing
    By jasandbob 2 in forum General Discussion
    Last Post: 11-15-2010, 03:44 PM
