Likes Likes:  0
Results 1 to 14 of 14
Thread: Rear brake master cylinder reservoir idea
    250+ Posts Dirtydan's Avatar
    Jul 2015
    San Tan Valley, AZ
    Default Rear brake master cylinder reservoir idea
    Does anyone have any ideas or any place they could point me to where I can find a rear brake master cylinder reservoir? I need a larger than stock one for the trike. Don't like the Wilwood that Champion supplied. I'm sure it will function fine but its damn ugly.
    Jul 2015
    San Tan Valley, AZ
    Ok, I guess no one wants to jump in here or has any ideas. Why do i need such a large reservoir? That's all it is, a reservoir. You're not using it for braking. You're using the fluid in the lines. See the pictures.
    thanks Dan
    Jul 2015
    San Tan Valley, AZ
    Wow, crickets.........
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    You scccared everyone
    Jul 2015
    San Tan Valley, AZ
    Wow, guess you all scare pretty easy. No worries. i found my answer on one of the custom sites.
  6. #6
    850+ Posts Rmitchell55's Avatar
    Dec 2012
    Santee
    That looks like the same one that I have on my Kawi Trike except the hose connection is on the bottom. Works for me. The only thing that I have is I need to move it higher on the trike. It sits lower that the brake lines.
    Ray
    2017 Harley Triglide
    Tijuana Border
  7. #7
    Jul 2015
    San Tan Valley, AZ
    You do mean the one on the right correct? That's the Wilwood one that Champion supplies. I'm sure it's fine and works great but it's butt ugly. I was just looking for a more aesthetically pleasing one.
  8. #8
    Jul 2015
    San Tan Valley, AZ
    So it looks like Motortrike uses the stock one. So that's the way I'll be going until I find something nicer looking that holds at least the same amount of fluid.
  9. #9
    12500+ Posts
    Nov 2013
    Huntington, Ct. USA
    If that is actually your only option...maybe a Witchdoctor reservoir cover and a little black paint on the urine specimen container might do the trick.
  10. #10
    Jul 2015
    San Tan Valley, AZ
    I don't know that its my only option but it's going to work. and once it's all set up I don't feel like redoing it with a different master. So that's what I will do. I have one on my other XCT and you cant tell that its a sleeve and a cover.
  11. #11
    1+ Posts
    Jul 2016
    hereford ,herefordshire.hr1 1lf.united kingdom
    Quote Originally Posted by Dirtydan View Post
    bazman. the guys in England fitted mine low down at front frame and fitted a metal holed ventilated guard on my hammer S trike if that helps
  12. #12
    Jul 2015
    San Tan Valley, AZ
    Got any pictures of it mate?
  13. #13
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Check ebay they have aluminum reservoirs that don't look bad.
  14. #14
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Sidecarbill View Post
    not to hijack... odd weve net met or may be we did... i am in sussex quite often friends on warrabase junction
    stace
  1. Master cylinder for rear brake
    By jimmib in forum Harley Trike Conversions
    Last Post: 07-15-2020, 12:49 PM
  2. Trike rear master cylinder problem ??
    By Pre-1898 in forum Home Built Trikes
    Last Post: 10-05-2018, 11:00 PM
  3. 14/15 Trike chrome clutch/brake master cylinder cover kit
    By Big Coup in forum Harley Trike Conversions
    Last Post: 02-19-2015, 09:00 PM
  4. rear brake master cylinder spec needed
    By lardarse in forum Harley Tri Glide
    Last Post: 12-31-2013, 03:18 AM
