Likes Likes:  3
Results 1 to 12 of 12
Thread: Renegade LLS belt adjustment
    30+ Posts
    Dec 2015
    Collie, Western Australia
    Default Renegade LLS belt adjustment
    Hey all..
    I have just had a look under my bike and realised the belt is way too loose and possibly off to one side.
    Is there and idiots guide to tensioning this belt? I have read the manual but the pictures are not very clear.
    Do I need to take the wheels off??
    Can I just jack the rear up a bit.. make the adjustment, roll the wheels to check ok?
    Any help appreciated.. I was hoping to have a look tonight once this 40DegC day buggers off.
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Yes to above. Wheels need to be removed and adjustment needs to be equal on both sides. Belt adjustment is not for the novice.
    Jim Murphy
    Iron Butt Rider 2001
    30+ Posts
    Dec 2015
    Cheers again mate..
    unfortunately living as far away from the bloke that did the conversion, it may have to become a task that I need to learn.
    I am getting the feeling I will need to do most of the work on this bike after some pretty ordinary discussions with the local mechanics. Most don't want to know anything about it.
    So any tips?
    I have downloaded the instruction sheet, and although it wasn't overly clear with the procedure, I think I will be able to sort it out.
    Main thing I see is the alignment more so than the tension. I think mine has moved across and I'm getting a rubbery squeaking sound when riding that has got increasingly worse over the last 60km. This I have to assume is the belt rubbing on the sides of the drive sprocket.
    I have a hoist at home and all the tools required. I even have access to precision measuring equipment if necessary.
    30+ Posts
    Dec 2015
    Well... got the wheels off and attempted to adjust the belt tension..
    I'm already at the max position!!
    Which means the belt needs changing..
    Noooooooooooooooooooooooooooooooo
    2011 Road King with Lehmann Renegade LLS
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Default LLS Belt Adjustment
    I doubt that you need a new belt. They don't stretch like the older belts do, they just break. It is really simple to do once you are set up. Study the assembly. The black plates with the slots are attached to the diff assembly. The lower and upper bolts allow the movement on the swingarm and upper frame.
    Quote Originally Posted by =Stangas= View Post
    Jim Murphy
  6. #6
    30+ Posts
    Dec 2015
    Yup.. that's exactly what we did.. and there is no more room in the slotted holes to move the diff section back any further
    We spent a fair bit of time mucking around and definitely came to the conclusion its at its end of adjustment
    Had to unbolt the rear fibreglass and hold it up while my brother undid all the top bolts.
    Physically it looks like it can go back as far as we need, but no cigar
    I have got a feeling that the bloke that installed this on dads bike knew all along that he was at the end.. and it looks like dad had a go at tightening the belt also, cause one of the adjustment screws was bent. Looks like a slightly shorter belt should have been used when built
  7. #7
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Does this help ? Or Hurt ??
    Jim Murphy
  8. #8
    30+ Posts
    Dec 2015
    I did see those holes.. will have another look when I get home.
    Cheers
  9. #9
    30+ Posts
    Dec 2015
    I am no longer scared to work on this trike.. LOL
    I had the whole rear end apart looking at this belt alignment. It is definitely easier when the body is off.
    I managed to get sufficient tension on the belt... but... the belt is stuffed!! It has a split both up and across the belt in the same spot.. as if a stone went in and pierced the belt.. The sideways split is about a 1/8 of the belt width. It is so bad that when aligning, the belt would move from one side of the rear sprocket to the other when the split comes around.
    I am running on borrowed time.
    My insurance includes road side assistance, so they will tow it home.. LOL
    I have bought a 139T belt, which should be here soon.. but now time to either schedule in the replacement or have a red hot go at it myself. I am becoming more confident in doing myself.
  10. #10
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    I know this is going to break your heart.
    You will have to remove the swingarm to install a new belt.
    You CANNOT twist the belt or you will break it. I learned the hard way.
    You might be able to slip it past the edge of the swingarm if you remove the bushing at the end of the pivot bolt but I suspect twisting would be involved.
    It is a PIA for sure. Get a Harley repair manual and download the Lehman LLS instructions. Make sure you get all the gaskets you will need. Depending on the mileage, you will probably want new seals too.
    Make sure you have jack stands and a roll around floor jack. You can jack the trike up and place blocks under the frame.
    Of course, you being in Australia makes it a little easier, everything is upside down there.
    Curiosity from America: When you flush the toilet down there, does the water rotate clockwise or counterclockwise, or does it just sit still like it does in Detroit ?
    Jim Murphy
  11. #11
    30+ Posts
    Dec 2015
    Yes I am seeing exactly how much work is involved. Its going to be a mammoth task.
    I have all the gear, and my brother being a mechanic, my mate being a fitter, and myself being a sparky.. we should be able to do it.
    My fitter mate is saying about 20hrs work.. I don't think he would be far off it.
    I can get all the body and accessories off in an hour now.
    I have had the primary cover off the bike, and see how the compensator and clutch needs removing, then the primary case needs to come off to get to the belt drive. I am led to believe that the belt can then be pulled forward and over the transmission shaft.
    The trike section.. I am thinking starting on the left wheel and moving inwards until I can reach the diff, meanwhile undoing all the swing arm pivot etc.
    AHHH!!
  12. #12
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    If you move the rear diff forward and support from the right side after dropping the swingarm, it should be fairly simple. Getting all the supports in the right place first is important. You can slip the new belt over everything to the drive pulley, but not onto the pulley yet, while at the same time getting the belt into position of the front pulley. Once you get the front pulley belted up it is all down hill (up hill in Australia) from there. Good luck.
    Jim Murphy
  1. Belt adjustment.
    By sandrooney in forum Harley Trike Conversions
    Last Post: 06-19-2014, 05:19 AM
  2. Torques for belt adjustment.
    Last Post: 06-17-2014, 07:55 PM
  3. Belt Adjustment on Road Star Trike
    By Roadie in forum Yamaha Trikes
    Last Post: 02-22-2014, 08:10 AM
  4. Lift brackets- drive belt adjustment
    By jimdog1356 in forum Harley Tri Glide
    Last Post: 03-22-2012, 09:16 AM
  5. Primary drive belt adjustment
    By jkchipster in forum General Discussion
    Last Post: 02-05-2012, 03:14 PM
