Likes Likes:  3
Results 1 to 13 of 13
Thread: EMPI Quick Shift Kit, Cast Aluminum...
    150+ Posts CaveManDave's Avatar
    Apr 2016
    Spokane, WA USA
    Default EMPI Quick Shift Kit, Cast Aluminum...
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by CaveManDave View Post
    Wow blast from the past.... I put one on my 71 Beetle back in 71.. Got it from JC Witney,
    Absolutely loved it...
    2019 Tri-Glide.......
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    It does shorten the throw on a stock shifter.
    It does not turn a stock shifter into a better shifter.
    Apr 2016
    Spokane, WA USA
    That's a big No!
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Quote Originally Posted by DeathBySnuSnu View Post
    Dead on here! It really helps on the throw though.
  6. #6
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    Shorter throw is achieved by lowering the shifter ball on the bottom of the shifter in the socket on the end of the shifter rod. This cost-effective kit gives you not only a shim (top arrow) that sits on top of the conical bell on the shifter to lower it somewhat, but it also gives you a cast aluminum spacer to put under the shifter bell cover to raise the whole mechanism back up (so that the side stops/reverse stop tangs will be aligned and not give any sloppiness or binding). So yes, it giveth some and then it taketh away some.
    IMHO, it may provide some shortening of throw but I really doubt that it would be significant enough to really feel it and appreciate. But at the price, it would be worth a try.
    Again, just my 2 cents worth. I hope it does give you some good results if you try it. Keep us informed.
  7. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Like i said, I put it in my 71 beetle, And latter on when i got a 73 beetle put it in it also...
    Sometimes the little things work....
  8. #8
    10+ Posts
    Dec 2015
    Chubbuck
    I wanted a shorter shifter on a dune buggy that I had because it was hitting the dash. I had a friend of mine cut the shifter shorter and weld a bolt to the end with the same thread as my shift knob. The point of my story is that by shortening the length of the shifter itself, it shortened the throw. A shorter shift lever on a trike wouldn't be that bad. Something to think about.
  9. #9
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Maybe just purchasing a different 3rd party shifter would solve that problem?
    http://carcraftstore.com/t-handleshifterempi.aspx
  10. #10
    10+ Posts
    Dec 2015
    Chubbuck
    I know that they make some after market shifters that have a key lock built into them so you could lock it in reverse. Might be a pretty cool addition to a trike.
  11. #11
    Apr 2016
    Spokane, WA USA
    Jester, That is a good idea. I will look into it!
  12. #12
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Or...
    If you are feeling creative and want something specifically yours.
    Make your own.
  13. #13
    Apr 2016
    Spokane, WA USA
    Nice!
  1. 5/8 EMPI square Master CYL rebuilt kit
    By Fowler in forum VW Powered Trikes
    Last Post: 10-29-2015, 08:17 AM
  2. Empi 34 pct questions
    By starrider1946 in forum VW Powered Trikes
    Last Post: 07-04-2015, 02:03 PM
