Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  4
Results 1 to 19 of 19
Thread: Tank lift and gas capacity.
    60+ Posts
    Jun 2015
    Tickfaw, LA, United States
    Default Tank lift and gas capacity.
    Thinking of putting a DK Customs 1 1/2" lift kit on the FW (front only). Would like to know from someone who's done this if it affects the tank's capacity?
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Default Will a Tank Lift Affect My Usable Fuel Capacity?
    Depending on the size of your tank ( 2.1 gallons-6 gallons) and the size tank lift, ( 1.5”, 2”, 2.5”, or 3”), it could possibly reduce your usable capacity by ⅛ to ⅓ of a gallon
    However, in the real world, most people do NOT run their tanks until they are dry. Since that is the case, there is no practical difference in usable capacity 99% of the time.
    With a tank lift, your fuel light may come on a bit sooner, but the fuel light acts as a type of “electronic reserve”. Generally there is still a gallon or more of fuel left in the tank when the fuel light comes on.
    Now, down to what tank lifts do to the usable mileage. A tank lift could cause your fuel light to come on a little sooner than it did without one, and it could show you have less fuel than what you actually do. This is due to where the fuel pickup is located at on your tank. It is already in a sort of odd place, and leaves fuel at the rear of the tank that does not reach the fuel pickup. When you create a higher angle on the tank with a tank lift, it can leave more gas that will not reach the fuel pickup.
    The fact of the matter is, for most, this possible loss won’t even be noticeable. This is because the only way you will notice that small of a loss of usable fuel, is if you drain your tank dry before you fill up each time.
    Clint
    www.DKCustom.com
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by FleshWound View Post
    No- raise the rear as well, deluxe kit, and it's like being stock. I have a gallon left when the LOW indicator light comes on.
    900+ Posts
    Apr 2011
    Bellville, Texas, USA
    I installed the Deluxe Kit which raises both the front and the rear of the tank. When I first installed the kit I did not install the rear spacer and I did notice that the fuel light came on earlier than when the tank was in the stock position. After adding the rear spacer the fuel light now comes on pretty much the same as when the tank was in the stock position. Normally I fill up before 150 miles as I don't like to run the tank too low because the fuel keeps the fuel pump cool.
    Sunman
    200+ Posts scuba1954's Avatar
    Sep 2013
    Monroe, Ohio
    I have the 2" kit on my 2014 trike and when my low fuel light come on I have exactly 2 gallons left.
    Hi, I'm Mike and I'm a Chromahualic!http://www.hdforums.com/forum/images.../icon_bike.gif
  6. #6
    10+ Posts
    Jul 2016
    Goose Creek, SC
    Quote Originally Posted by 1dn5up View Post
    I did the 2" deluxe lift and today the fuel light came on and I topped it off with 4.2 gallons. So I actually had 1.8 gallons remaining.
    My my gauge said I only had 23 miles in fuel remaining.
  7. #7
    60+ Posts cigarman's Avatar
    May 2016
    Hershey, PA and Cave Creek, AZ
    Quote Originally Posted by scuba1954 View Post
    Same with me. I recommend the deluxe lift. You can find my pic posts on the forum.
    Yesterday I filled up and got 4.2 gallons when it was showing empty, so there was 1.8 gallons left.
    I rode it a while and then went back to the same pump and refilled it. The amount added up to the 4.2 gallons, so I know it was full. This is the same as it was prior to the lift.
    BTW, no HD that I have owned had an accurate fuel gauge, all were either high or low.
    '16 Freewheeler "Blackie" Vivid Black, 103; FP3; Cobra 900s; K&N; Windshield; Dual-bulb Halogens; CD LED turn signals; Mustang Wide Vintage***'09 Softail Custom "Baron Von" Sunglow; 96; FP3; Python Staggered Duals; High-Flo air intake***'08 Heritage Softail Custom "Ferdinand"; Sunglow; 96; HD Tuner; SE Mufflers; cams; K&N
  8. #8
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    I put the 2" w/rear tank spacers on my Tri-Glide. Just got in last night from Sturgis. Noticed when ever the "reserve" icon came on I'd fill up with around 4.8gals, meaning I had approx 1.2gals left in the tank. Now I don't know exactly where the fuel pickup is located in relationship to the 1.2gals. I never ran it totally out to see just how much was left when I filled up. Might be something I ought to do, in a more controlled situation, just to see for sure.
    Sure got a lot of comments while in Sturgis about the look of the trike with the tank lifted. Most were Wow, what did you do that I can see the whole front cylinder? Gave DK Products a lot of advertising over the past 10 days. Ha!!! One negative was dang, now I would have to clean the tops of both cylinders....more work !!!
    Love the product and DK's customer service !!!
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  9. #9
    5+ Posts
    Mar 2013
    sussex wi
    Default Tank lift
    When lifting the tank shouldn't the front and and back and be lifted at the same height
  10. #10
    Jun 2013
    Texas
    Quote Originally Posted by toy1ton View Post
    Talked to the guys at DK, who I bought it from, about this very thing, raising the front and back the same distance. They assured me the difference would make little or no difference. Oh, and while I had them on the phone I swapped out the 2" for the 2 1/2". Love the look.
    8~\0
  11. #11
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Here is an '11 with a 1.5" lift and Deluxe Option. I was able to use all 6 gallons, no issue. If it had a taller lift in the back, it would look funny, push the seat up too much, and make the fuel pick-up (which is in the center) not be able to get all the fuel out.
    Here is a bike with a 2" lift, and No deluxe option. Still looks good, and good air flow over engine, but loses about 1/8 gallon of usable fuel.
    Here is a photo of me filling up with fuel...this is on a TG with a 1.5" lift and a deluxe option...as you can see, I got full use of the entire 6 gallons.
    www.DKCustom.com
  12. #12
    100+ Posts Red59's Avatar
    Apr 2014
    Walled Lake, MI US
    I have a 2015 Freewheeler that I installed DK's 1 1/2" tank lift with the deluxe option. Rode it out to Sturgis this year and the guy I rode with rides more aggressively than I do and being weighted down more than usual I ended up running out of gas just as we pulled in to fuel up, had to push it about 100'. I topped off my tank with 5.73 gallons, I believe that if there wasn't an incline at the entrance of the gas station I would have made it to the pump.
    Red
  13. #13
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Looking at the condition of that pump, I would be highly suspicious of its accuracy...
    Just thinking out loud....
    2019 Tri-Glide.......
  14. #14
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    All pumps MUST be certified ( most states call for pump and tank tests EVERY 2 years) others follow different guides BUT ALL do have to be cerified by State Weight and Measures
  15. #15
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    And like my Old Man would say... If the Dog didn't stop to take a pee he would of caught the Cat.....Theres a violation right there....Illegible face plate....
  16. #16
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    I would agree with you, except I've filled up several times putting in a tad over 6 gallons.
    Here's a pic of another time, different year, different State...this is at a gas station just outside of Meridian, ID.
    The first one I posted above was at a station in Arkansas or Texas...I know it was on the second day of a long trip we made when we first got the '14 TG...at the time I did not how accurate the gas gauge was. The time right outside of Meridian was just poor planning on my part.
    A few other times when I've put in a bit over 6 gallons were locally, when I was just messing around to see how far I could go.
    www.DKCustom.com
  17. #17
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    I was just tweeting Jack a little...
    I've lived dangerously once or twice with my 11 Tri, And once got 5.9 in...
    But i was only that brave when i had my Gal.and a 1/2 tank squirreled away in the trunk...
  18. #18
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Good eye
    Too bad the overweight inspector was choking on a Big Mac and passed that pump
  19. #19
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Good eye
    So many pumps to inspect, And so few inspectors to inspect the so many pumps that need inspecting.....
  1. Fuel tank capacity
    By Trk Ldy in forum General Discussion
    Last Post: 08-08-2016, 09:01 PM
  2. installed DK Lift kit and tank lift
    By uppercaseJC in forum Harley Trike Conversions
    Last Post: 10-25-2015, 12:35 AM
  3. question, fuel tank capacity
    By dirtdobber in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-04-2015, 01:41 PM
  4. Gas Tank Lift Kit?
    By GoSlo in forum Harley Trike Conversions
    Last Post: 12-16-2013, 11:36 PM
  5. Gas tank fuel capacity
    By haawg in forum BMW Trikes
    Last Post: 05-21-2013, 09:21 PM
