Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  0
Results 1 to 11 of 11
Thread: need help ASAP on head lights
    10+ Posts
    Jun 2011
    Monroe, NC
    Default need help ASAP on head lights
    Got a problem that Throughbred cannot fix. I have a 2008 Stallion and a burned out low-beam light. This light has not been used since late 2008, they do not stock this light and they have changed computers and do not know who supplied this light. Does anyone know what the light was made for and possibly the part #?
    Thanks in advance
    Rick
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by jdrooster View Post
    Thanks in advance
    Rick
    Is it a light or a bulb....If its a bulb.. Any auto store' Auto-zone' Napa, etc can mach it...
    2019 Tri-Glide.......
    10+ Posts
    Jun 2011
    Monroe, NC
    Not sure at this time. Got the reply from from Richard at TMS after I got to work today, will ck tonight. Suppose to carry it to Tenn Saturday so it it urgent.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    My 09 lights are the same for high and low beam, the glass reflector is what is different. go to any parts store and they will have it. I used the Sylvania H9 and replaced both bulbs, just take one into the store and match it.
    Tomg
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Thanks in advance
    Rick
    should be an H 9 bulb it takes two of them both the same Number
  6. #6
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    The early Stallions did have a different setup. It looked similar but was not very bright. We had one on our 175 Stallion. TBMS changed it at the Daytona dealer shortly after we purchased it at no cost. They should have new housings available. It is a bit of a job to change out. Now that being said the original still had replaceable bulbs I believe. Remove the bulb and see if you can get a replacement.
  7. #7
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    I changed mine to HID's. Big difference. Bottom is the OEM, middle is low beam HID and top is everything except the bright on. If I had that on, you wouldn't be able to see anything in the picture.
    If you got to ride, ride in style
    Stallion #378
    Suzuki Burgman 650
  8. #8
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Changing out the bulb can be a little difficult to get to. The H9 bulb can be picked up at most part stores the you will need to sodder the wire. It can be done but you need to be a little flexible.
  9. #9
    10+ Posts
    Jun 2011
    Monroe, NC
    I will try just the H9 bulbs. TMS does not have any entire kits for the old 08 models. I was told that I could not buy just one, I had to get both as a set which i did ($278). The problem with them they are 1/2 inch bigger in diameter that the old ones. TMS sent me a 6 page instruction sheet on how to change it out by enlargeing the hole by grinding and other modifications. Talked to one body shop, they don't want to touch it. Was hoping to find out what year and make of car these lights were manufactured for.
    Rick
  10. #10
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Ed Hobgood View Post
    Ed you are referring to the original driving lights on each side of the cowl that has to be soldered. That is a H-3 bulb I believe. The H-9 bulb plugs into the wiring harness on the headlights.
  11. #11
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    You got the correct part if we are talking about the main lights in the middle of the nose. Like I said before it was a change and it was quite a bit of work. Took the factory dealer in Daytona 6 hours to due ours. I was not there watching so I can not help on how it was done. What you describe is what was told to me by Russell who did the work. The out come was very good the lights are much better.
  1. 1989 GL1500 Head Lights QUIT
    By chris vickers in forum Honda Trikes
    Last Post: 08-19-2015, 08:07 PM
  2. driving lights and head lights
    By Dragon in forum Stallion Trikes
    Last Post: 10-05-2014, 09:25 PM
  3. Need help ASAP
    By Onestone in forum Harley Trike Conversions
    Last Post: 08-07-2012, 09:39 PM
  4. better head lights
    By kookie in forum Stallion Trikes
    Last Post: 12-18-2010, 11:35 AM
  5. Head lights
    By molinoman in forum Stallion Trikes
    Last Post: 07-19-2010, 11:53 PM
