Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  62
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: 2009 Honda Goldwing/2016 CSC Viper Conversion
  1. #21
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Default 2009 Honda Goldwing/2016 CSC Viper Conversion
    Here It Is
    With the trike build completed, Gary performs a water test of the body, trunk and tour box for leaks.
    After the water test, he will ride for a long road test over both smoothly paved roads and rougher roads. He also rides slowly over cut lawn areas.
    He checks out the trike's performance and all electrical systems for proper operation. Gary is also listening for any rattling or other non-mechanical sounds. If there are any, he will begin to isolate and resolve the issue.
    Once Gary is 100% happy with all of the above, he and Barbara will wash/clean the trike carefully as per CSC recommendations. CSC recommends to only use mild soap and water and no waxing for the first 90 days. This process is to allow time for the new paint to properly cure.
    CSC painted the kit with Honda factory original paint.
    So much for the talk, here are pics of the finished trike built by Gary and Barbara.
  2. #22
    250+ Posts G.W. Viper's Avatar
    May 2016
    Rancho Belago, Ca, USA
    Looks great David ! Well done
    I noticed your rear brake lights on upper luggage compartment are a little different then mine. Did you special order them ? Have you thought about installing fender bras on the rear fender. They will help with bug stains and rock chips, just a idea.
    Congrats and Ride safe
    2015 Goldwing 1800 W/ 2016 C.S.C. Viper Trike Conversion
  3. #23
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Quote Originally Posted by G.W. Viper View Post
    Thanks Keith,
    The rear brake lights on the upper luggage compartment are not special order. They are stock lights. The difference you may be noticing may be the fact that my lights are from a 2009 model while yours are from a 2015 model. In addition, I purchased a CSC optional chrome tail light trim kit. CSC installs the lower brake light trims at the factory. The upper luggage compartment trims are field applied during the build.
    I have not taken delivery of the trike yet. Once I do, I have a 604 mile trip home with the trike loaded unto an Aluma TK-1 trailer.
    Prior to the trip, CSC technical support staff have indicated that it was OK to wrap any of the newly painted conversion kit pieces with the temporary "auto wraps" as used on new car transports. They recommended not leaving the temporary wrap on more than 2 days. I plan on wrapping the fenders and maybe the ground effects with the temporary wrap. The trailer does have a built-on rock shield also.
    Once I get home, the trike is headed for a local paint protection film shop who specializes in high end cars. I plan to have a paint protection film called "Expel" applied to selected areas of the rear fenders and the ground effects.
    I did not choose the CSC optional fender bra for a couple of reasons. First, the bra does leave an exposed edge vulnerable to rock chips. Second, one of the attachments, of the bra to the body, is tucked up underneath the ground effects and cannot be unsnapped without removing the ground effects. Third, the bra can always be added if all else fails on protecting the fenders.
  4. #24
    May 2016
    Quote Originally Posted by David357 View Post
    Thanks Keith,
    Looks like you have it all figured out
    Just a side note on the fender bras.....There are actually 2 styles of bras, one that fits under the ground affects. The other style which I have doesn't go under the ground effects. It comes off very easy for washing and waxing. The way you can tell them apart is the lettering on the bra. CSC, if you notice mine it has all capital letters. The other one that fits under the ground effects the letters look like their logo cSc.
    forgot to mention. I see you have the drivers floor boards and toe and heel shifter, I also ordered the same thing. When I finally got her home, I noticed that you can't fit your toes under the toe shifter. The gap is to narrow. You will have to use your heel to upshift. At first I didn't like the change. Always used my toes for up shifting. But now after a few rides I have grown to like using my heel to upshift. Don't know if you will have the same problem...but don't worry using your heel isn't bad, I'm even liking it better now.
    Keith
  5. #25
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Nice trike. Now get off the forum and go enjoy it. Just kidding about getting off the forum. Ride safe.
  6. #26
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Default 2009 Honda Goldwing/2016 CSC Conversion
    Keith
    Keith:
    Thanks for your input. The heel/toe shifter has been on the bike (now trike) for over 7 years now, so heel upshifting feels quite natural.
    When I have ridden friend's trikes and demo trikes without the heel/toe shifter, shifting would feel very awkward to me.
    It's all in what you get accustomed to.
  7. #27
    Just Killing Time...
    paws's Avatar
    Oct 2011
    Kerrville, TX U.S.A
    We have had the heel-toe shifters on various 2wheelers since 2007 and now our GL1800 trikes. I am used to it now but my preference is the old toe shifter. I was reminded of this when Goldrush (Jerry) so graciously let me drive his GL1800 Roadsmith a year ago which does not have the heel-toe shifter. De-ja-vue. I enjoyed that so much that I wanted to remove my trike's heel-toe shifter but Jim talked me out of it....for now...Carla
  8. #28
    May 2016
    Keith:
    Sorry for the bad pics. There was no part number, just said gold wing 1800.
Size:  419.1 KBName:  20160916_153703.jpg
  9. #29
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Default 2009 Honda Goldwing/ 2016 CSC Viper Conversion
    Quote Originally Posted by Gorilla View Post
    Now that right there is some great advice.
  10. #30
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    So you need your trike built fast?
    You want it when?
    The attached You Tube video, from seven years ago, show Gary and Barbara skillfully building a CSC trike conversion in record breaking time.
    Hold onto your seat and try not to blink.
    Enjoy!!
  11. #31
    4500+ Posts Catfish's Avatar
    Mar 2016
    Quincy, Ill.
    Awesome thread.
    If "Plan A" didn't work.
    The alphabet has 25 more letters!
    Stay Coo
  1. My New CSC Viper Conversion
    By pwhoever in forum California Sidecar Trikes
    Owners Forum
    Last Post: 12-13-2016, 08:12 PM
  2. 2012 Goldwing CSC Viper Squeaking ??
    By MrCement in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-18-2015, 03:41 PM
  3. 2012 CSC Viper Conversion - Oil Leak
    By kwputt in forum Honda Trikes
    Last Post: 06-21-2014, 06:29 AM
  4. Replies: 3
    Last Post: 01-09-2012, 12:37 PM
