Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  1
Results 1 to 12 of 12
Thread: Horn
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Default Horn
    My 2015 Freewheeler horn is inoperable. Does it have a circuit breaker or connection that I should check?
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by LadyonaMission View Post
    Theres a Tread going in now ; Horn switch' Harley Forum.. Something about that it might be coved under the warranty ...
    2019 Tri-Glide.......
    4250+ Posts
    Feb 2015
    San Antonio
    Thanks. I will get the dealer to fix it since it is under warranty. I am bad about looking only at Freewheeler Specific posts.
    Lola
    20+ Posts kuri's Avatar
    Oct 2015
    Sacramento
    I had a similar issue a few weeks ago and it turned out to be a broken wire on the blade connector that went to the horn itself.
    I just cut it off and replaced it with a weatherproof one and went about my day.
    4250+ Posts
    Feb 2015
    San Antonio
    Mine was a wire also. I rode to the Harley shop, a mechanic took it in for a few minutes, fixed it, gave it back to me, no charge.
  6. #6
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    GOOD DEAL !!
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
  7. #7
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Gold Rush View Post
    GOOD DEAL !!
    Gm older style metal adjustable horn is the answer
    The cheap HD plastic horns are a joke IMO
  8. #8
    4250+ Posts
    Feb 2015
    San Antonio
    I realize this is an old post, but I have the same problem for the 3th time. Two weeks ago today I picked up my Freewheeler after having the horn fixed again so I could pass inspection. This time I had to leave it there so they should have been able to fix it properly. The paperwork stated it was the wire, just like last time.
    I haven't ridden in any rain or sprayed any water on it so if they tell me it's the wire again should I ask for proof that they did a diagnostic on the switch and horn or would that be asking for too much?
    It is under warranty, but starting to be annoying.
  9. #9
    May 2011
    San Angelo
    You might pose your concern as a comment that you had read about an issue and was wondering if that could possibly be contributing to your problem as well..... Who knows - Might jog someone's memory of the other issue.
  10. #10
    4250+ Posts
    Feb 2015
    San Antonio
    Thanks. I was just concerned that since the wire temporarily fixes it there would be no reason to check the switch or horn and I hate to be unreasonable.
    Actually, I don't want the service writer to know I don't have a clue.
  11. #11
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Let them know that you are concerned about this re-accruing problem and would like to be assured that they are seeking a permanent repair. Let them know you are uncomfortable having to bring it back the 3rd time for the same issue. Horns are generally not an item that needs a lot of attention. Good luck.
  12. #12
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I am in the same boat...have had my horn on the '14 repaired FOUR TIMES under warranty...and it just went out again a few days ago.
    HD has definitely changed the quality of the horn set up in the last few years. Prior to the '14 I've put hundreds of thousands of miles on bikes/trikes with the cowbell horn set up with nary a problem.
    www.DKCustom.com
  1. I need a louder horn
    By camacdonald78 in forum Harley Trike Conversions
    Last Post: 03-02-2016, 08:25 AM
  2. Air horn
    By usmc68 in forum Harley Trike Conversions
    Last Post: 04-16-2014, 06:40 AM
  3. H-d air horn
    By GARYD in forum Harley Trike Conversions
    Last Post: 03-05-2012, 12:01 PM
  4. Horn
    By robandlyn in forum Accessories
    Last Post: 07-11-2009, 10:55 PM
  5. Air horn
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 07-10-2009, 08:54 PM
