ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  3
Results 1 to 12 of 12
Thread: Hood latch
    5+ Posts
    Aug 2016
    Longview, TX, USA
    Default Hood latch
    I believe my hood latch has come unhooked or broken. Cant get hood open. Any suggestions on getting hood open?
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to Trike Talk Johnnyu.
    Can you see the latch from underneath somehow? Maybe jacking it up or rolling up onto a car ramp?
    If so it might be possible to release it carefully using a long screwdriver or prybay without causing any "collateral damage".
    Others may have the answer you need, so you might wait for a better solution than what I posted.
    Best of luck on this one...
    800+ Posts Trikindan's Avatar
    Dec 2014
    Lexington.SC USA
    Cloths hanger and patience !!!!
    JUST ME ON THREE
    1998 GW 1500 MotorTrike
    Saddle up boys...we're burning daylight!!
    "The Duke"
    Thank You Vets
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    The only option is to go at it from the bottom. It is a bear to do. Just try different thing til you get one to work. Good Luck
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Johnnyu View Post
    I looked at mine. It seems that you could remove the panel that houses the headlight switch and gain access to it. Just a thought.
  6. #6
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by trikervet View Post
    Good thought but the top of that panel is held in place by 2 bolts that have to be accessed with the hood up.
  7. #7
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Gorilla View Post
    Mine has U-Nuts on all three screws. I think on later models there are no screws, the panel just pops out.
  8. #8
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    I have an "08" so I was not aware the new ones with the plastic body the panels popped out. That would make that easier. I do know the new ones they moved the latch down where it should be easier to get to.
  9. #9
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Taking out the light switch /radio control leaves you with a backing and besides, there is a latch on both sides so it may be the right side hanging up? Go at it from the bottom and try to pull the latch open. I know it can be done as I watched the guy who sold me my Stallion do it to show me if there was a hang up.
    Tom
  10. #10
    5+ Posts
    Aug 2016
    Longview, TX, USA
    Default Hood latch
    Contacted Motortrike, company that builds the Stallion. Talked with Richard and he worked me into their busy schedule for next Wednesday. Beneficial living 40 minutes from Troup, Tx.
    i do appreciate all of your suggestions.
  11. #11
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    Please let us know what Motor Trike did to unlatch. May save us a lot of headaches down the line.
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
  12. #12
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    I second that!
  1. fire under the hood
    By ODDOMAN in forum Stallion Trikes
    Last Post: 07-03-2015, 08:05 PM
  2. 2010 stallion hood
    Last Post: 05-26-2014, 07:37 PM
  3. Lockaable Gas Cap and Hood
    By Switchback in forum Stallion Trikes
    Last Post: 10-22-2010, 12:31 AM
  4. Hood Adjustment
    By Silver Eagle in forum Stallion Trikes
    Last Post: 06-08-2010, 09:29 PM
