Likes Likes:  9
Results 1 to 11 of 11
Thread: This is a Lehman
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Default This is a Lehman
    Identify this !
    Jim Murphy
    Iron Butt Rider 2001
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    It's a red trike ........................ ................ (hides ....)
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
    Meme Master
    Jan 2014
    Farmington, NH USA
    Like he said, its RED...
    Valkrie or Triumph???
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    It is a Lehman Magnum used on Valkyrie non-Interstate models. At the time, Lehman was producing the same body for Harley's used by Police Departments and made them for Honda Shadow and Suzuki 1400 Intruder.
    Discontinued in 2001.
    YUGE Trunk
    Jim Murphy
    450+ Posts tbear's Avatar
    Sep 2013
    Carleton, Michigan
    Default crooked?
    Quote Originally Posted by Lee H. Mann View Post
    YUGE Trunk
    Kinda changing the subject. since you are a Leman Tech; is a 2010 Triglide bought at a Dealership, a Dealership done Conversion? the reason why I am asking, my Mechanic told me that my trike is cocked crooked, like it isn't totally square. It runs straight down the road but is there an adjustment that can be done to check? thx. for any info. back.
    tbear
    TBEAR
    2010 Triglide Harley Davidson
    V&H Exhaust,True Duals, Big Sucker Ac,,557 S&S Cam,SE Compensator 2014, oil cooler,EBC r.brakes,Progressive air-shocks,Floorboard extensions,rear fender bras, Dynoed,krome-werks 2+2 bars, and a sheep wool butt protector....
  6. #6
    May 2016
    If it says Tri Glide on the trunk door, it is a factory unit. The mo co owns that name. The body itself should be a dead give away. Or, run the serial number past customer service in Milwaukee.
    [SIGPIC][/SIGPIC]​
  7. #7
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by tbear View Post
    tbear
    The 2009 and 2010 Tri-Glide were made in partnership with Lehman. They are considered to be 100% Harley because the components used by Lehman were what either Harley designed and subed out to Lehman or approved parts supplied by Lehman. At least that is the just of it. The front 1/2 of the TRI was assembled in York Pa at the Harley plant.
    It was shipped out to Spearfish SD where Lehman USA added the trike portion with the Harley designed and approved trike assembly. The finished product was sent back to Harley for distribution. The finished product is considered a factory built trike not a conversion. A Harley Dealer had nothing to do with assembling the early TRI. The trike they received was finished except for items that needed fitting after shipping. In 2011 Harley started doing the complete assembly in York.
    Your running gear is probably square because it tracks fine, but the body maybe bolted on a little out of square. That doesn't hurt anything unless there is a visual problem looking at it that bothers you. The body can be squared up if you desire.
  8. #8
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Gorilla is absolutely correct !!
    Jim Murphy
  9. #9
    Sep 2013
    Carleton, Michigan
    Default body crooked?
    Quote Originally Posted by Gorilla View Post
    Thanks for clarifying that for me Gorilla. I gotta find out how to do the body bolts and try to straightened it up. It's a mind thing with me now since my Mechanic pointed it out to me. Trikes are kinda new to him also, since he has only been working on a few of them over the last 5 years. Small shop out here in the country side of Michigan.
    TBEAR
  10. #10
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Looks like there are 4 bolts that hold the body to the frame base. There might be some foam strip between the body and frame. You should be able to loosen the four bolts and move the body a little. The foam may attach itself to the body so you might have to free that up. Lehman had specs and maximum tolerances on body fitment.
    To see if it is your body, use a tape measure from the center of the tread on the tire to the front of each fender. If there is more than 1/8" difference it might be noticeable. I take a tape measure also against the top of the sidewall of the tire and measure the inset or distance from the side of the outer fender. Again you want it within a 1/16". That is how you check body to frame straightness. Check one side against the other.
    The tourpack could be crooked too, but that is another story.
    Check the above for body alignment but that is also after confirming that the rear axle is properly aligned too.
    Jim Murphy
  11. #11
    May 2016
    The tour pack could be crooked too, but that is another story.
    Nothing worse than a tour pack that thinks it's a politician ..................... ............
    [SIGPIC][/SIGPIC]​
  1. Lehman #1
    By joebear in forum Lehman Trike
    Last Post: 03-11-2015, 02:22 PM
  2. Lehman IRS
    By sportthedog in forum Lehman Trike
    Last Post: 09-15-2014, 08:19 AM
  3. Lehman
    By gwnut in forum Lehman Trike
    Last Post: 06-10-2012, 10:14 PM
  4. old lehman kit
    By rodeo1 in forum Honda Trikes
    Last Post: 09-09-2011, 09:03 AM
