14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  15
Results 1 to 14 of 14
Thread: New Triker with 3 questions
    70+ Posts Hogdoc's Avatar
    Snellville. GA USA
    Thumbs up New Triker with 3 questions
    Hi All,
    I am a new Tri Glide owner/rider. I have adapted well to three wheels coming from 2 wheels. I understand the push/pull concept of steering and that I don't lean into a curve like I did on 2 wheels. With that said, I have three questions concerning going through curves with my trike that I hope to gain some insight from you all.
    1. What body position do you maintain going through the curve, upright, slight lean to outside/inside?
    2. Going normal speeds through the curve, can the trike tip over?
    3. What do you do about the sensation of being thrown to the outside of the curve, since I do not lean like a 2-wheeler?
    Thank you for your insight and if a question is not clear, I will try to clarify.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Until ya feel comfortable in the turns , remember to brake before it, if goin too fast into it and locking up the rears, by by.
    I counter shift my tail acording to how I feel. Then power out of the turns. Find a good twisty road and practice at different speeds. It will come to you , and follow your eyes, very important issue, can't stress enough.⚠️
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Hogdoc View Post
    Hi All,
    1. Inside lean if riding curve aggressively.
    2. No
    3. Push down on outside foot.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    250+ Posts G.W. Viper's Avatar
    May 2016
    Rancho Belago, Ca, USA
    When I start to go into a curve / turn I say to myself Left Turn.....Then I just push down with the opposite leg,so I push down with right foot. You just tell your self which way you are turning, then push down with opposite foot. This will keep your body more straight up. If I don't tell my self right turn or left turn, I find myself thinking and trying to remember what to do.
    And of course just like on 2 wheels, slow down before the turn, and just roll on throttle thru the turn.
    2015 Goldwing 1800 W/ 2016 C.S.C. Viper Trike Conversion
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I drive my trike just like I have always been taught with any vehicle. Brake before the turn and power out of the turn.
    I'm pretty aggressive at times and have never lifted a rear tire. I sit pretty much straight up and grip the tank with my knees when required. Pushing down on floorboards .... like suggested .... also helps with stability.
    Almost at 24k miles with my 2014 and riding is second nature. I switch back and forth with my 2 wheeler ZRX 1200R effortlessly.
    Enjoy your new ride.
    Bob
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    [QUOTE=Hogdoc;391895]Hi All,
    My answers:
    1. Depends on how fast you are traveling, if I'm going through a curve at at a slow speed I'm upright, if I'm taking the curves faster I do a slight lean into the curve.
    2. I've had a rear wheel to lift on me but it was my fault going a little crazy, I didn't feel the trike even try to tip so at normal speed I would say no.
    3. I lean a little and hang on with my knees!
    and power on through the curve.
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    1 Depends on the speed. The faster I go the more I lean to the inside....though not nearly as much as if I was on 2 wheels.
    2 Almost Impossible
    3 I do nothing - I don't notice any sensation of being thrown around. I just do what comes naturally.
    I'm a very aggressive rider. Always have been and always will be, so I have to be aware of everything around me and ride accordingly. Whether on 2 wheels or 3, riding comes as second nature - I don't have to think about it.
    Sometimes I will power completely through a really sharp corner - just to see what my limit is.
    After 5 years and over 60K miles under my belt, I can really push it hard - had a ball on the Dragon this year.
    IBA#61162
    PATRIOT GUARD
    USMC
    10+ Posts blksheep54's Avatar
    Starke, Florida USA
    Default Curves
    I too am a new trike rider. I obviously slow down for curves but, I still feel as though I'm going to slide off of the seat. I'm trying to figure out how to easily and properly counteract that problem. I'll attempt some of these measures and see what works best for me.
    Dec 2013
    Clarion PA USA
    Default Great advise
    I have over 3years in the seat and can add nothing to what has been said power through the turns makes a world of difference. ride it like you stole it when you can. Fred
    Quote Originally Posted by blksheep54 View Post
  11. #10
    450+ Posts tbear's Avatar
    Sep 2013
    Carleton, Michigan
    Hi All,
    If you get a set of 2+2 10" handlebars, you will find turning a breeze. No leaning, no sensations, but still have to slow it down and downshift for safety sake!
    TBEAR
    2010 Triglide Harley Davidson
    V&H Exhaust,True Duals, Big Sucker Ac,,557 S&S Cam,SE Compensator 2014, oil cooler,EBC r.brakes,Progressive air-shocks,Floorboard extensions,rear fender bras, Dynoed,krome-werks 2+2 bars, and a sheep wool butt protector....
  12. #11
    650+ Posts
    Sep 2015
    Sheboygan, WI
    +1 on the comments above!
    Just ride at speeds you are comfortable with, as your miles pile up, your comfort level (& speed) will increase. Good luck to you.
    It is what it is.
    16 Tri Glide vivid black
  13. #12
    Jul 2015
    Hendersonville
    Hi All,
    1 upright
    2. No
    3. Slow down , ride in your conform zone. When I started riding the trike I tried to ride like I did on the roadking 10 miles over the posted corner speed limit it was more work then fun so I slowed to 5 miles under the posted corner speed limit.
    The ride became enjoyable.
    After 1 1/2 years with the freewheeler I do the corner speed limit.
    The main thing be safe and have fun and ride your own ride where you are comfortable .
    Jim
  14. #13
    GLEN ELLYN, IL. USA
    Quote Originally Posted by Fearless View Post
    Keep to the speed limits until you get more comfortable, then = LET 'ER LOOSE. I have more fun going to the edge as much as possible. My normal speed
    is 5 to 10 above the limit - more so on curves and twisties. I love the look on the faces of riders behind me as I pull away from them and they drop down to the limit or even lower.
    The BRP, Pigs Trail and the Dragon are my favorite playgrounds. You'll get a fantastic workout on either one.
    Everyone has their own limits - that's good - don't try to ride someone else's ride.
    IBA#61162
    PATRIOT GUARD
    USMC
  15. #14
    Oct 2010
    USA
    Take your time and get use to the new ride. Once you ride it more and more that sensation will lead to excitement
  1. I got questions
    By Taylor in forum Harley Tri Glide
    Last Post: 09-14-2016, 12:52 PM
  2. 2 questions....
    By Backdraft in forum Stallion Trikes
    Last Post: 07-15-2014, 08:01 PM
  3. New guy questions
    By Dennis Murawski in forum Enabled Trikers
    Last Post: 08-01-2013, 08:03 AM
  4. Questions about TG
    By Skeet7373 in forum Harley Tri Glide
    Last Post: 02-21-2012, 05:56 PM
  5. New here. Have questions please....
    By ParrotLady3 in forum Harley Trike Conversions
    Last Post: 09-02-2011, 01:34 AM
