Likes Likes:  7
Results 1 to 15 of 15
Thread: what plugs should I use
    200+ Posts
    Apr 2015
    pineville, la
    Default what plugs should I use
    Stock, dual port, 1600cc with 34ict's, dvda distributor. What plugs are yall running? Which plugs and what reach? Just wondering.
    I like NGK
    I still like NGK plugs
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Stock heads NGK B5HS (short threads)
    Heads with longer threads NGK B5ES
    since you brought up the subject of spark plugs I thought I would add this.
    Thank you
    Bob
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Excellent Post Fowler!!!!!
    200+ Posts
    Apr 2015
    pineville, la
    Default what plugs should i use
    Good post but what I am wondering is should I use short or long plugs or does it make any difference. This is what I was wondering. I have been using the short reach Bosch plugs. Thanks
    Quote Originally Posted by stinger608 View Post
    Sep 2014
    Moneta VA
    Quote Originally Posted by starrider1946 View Post
    That depends on the thread depth.
    If you have stock heads then it should be 1/2 if you have aftermarket heads it could be 1/2 or 3/4
    Maybe your heads have some marking on them you can look up?
    I have never tried it but I guess you could rig up something to measure the thread length.
    There may even be a tool for that. I don't know
    I cant rely take credit for the post. Its a combo of several other posts I read
    Thank you
    Bob
    200+ Posts
    Apr 2015
    pineville, la
    Default what plug should i use
    I don't know if they are aftermarket heads or not. Very well could be. I wonder how you could tell? I may try and get in touch with the guy I bought the trike from an see if he knows. I think he went completely through it. He was fixing it up for his wife. I'd just like to know. Also what octane gas do yall use in your motors?
    Quote Originally Posted by Fowler View Post
    Sep 2014
    Moneta VA
    Make a simple tool to measure the depth of the spark plug threads in the head. You just need a small stiff wire (paper clip) with the last 1/4" at one end bent at 90-deg. This is where we will measure from.
    Bend a loop in the other end 1" in diameter (you are trying to bend the other end of the wire so it CANNOT fall through the spark plug hole... no matter what -- tie a string to it if you are worried)
    The point to understand is that when the spark plug is the correct length, none of the threads will be exposed INSIDE the combustion chamber.
    You insert the the small end of the tool and try to hook the inside surface of the combustion chamber (chamber edge of the spark plug threads). This is the bottom of the spark plug threads in the head.
    Make a mark using a marker on the tool. A good spot is where the tool meets the spark plug hole in the head tin.
    Now pull the tool out so the small bent end is lined up with the upper end of the threaded spark plug hole.
    Make another mark on the tool where it meets the tin hole. Take your ruler and measure the difference in the two marks. This is the depth of the spark plug threaded hole.
    Stock VW heads used 1/2" deep spark plug holes.
    Newer heads use a long reach 3/4" deep plug hole.
    Which is closer to the length of your two marks? That is the proper length spark plugs for your heads.
    (got this from a post on another site)
    Thank you
    Bob
    100+ Posts
    Sep 2016
    Sitka, Alaska USA
    Stock 1600 air cooled is a short reach plug. Short or long depends on head thickness, as the others have pointed out. There is no advantage to a long reach, and long plugs could get contacted by a piston or valve.
    The easy way to determine length is to pull known good plug and measure it.
    Two permissible heat ranges -- W8 for normal running/cold temps and w7 for mayo problems/performance heat/tropical weather. Numbering may have changed; heat range has not. CAVEAT: going outside recommended heat ranges can cause severe running issues and catastrophic damage to engines. Be careful.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Pull the valve covers and look at the casting numbers on the heads.
    I'm guessing, though, from your posts and using short reach plugs, that the heads are stock VW type heads and just use the short reach plugs.
    Are they the larger threaded plugs? IE, 14mm thread diameter?
    Most of the aftermarket heads that do in fact use the long reach plugs, will use the smaller diameter 12mm plugs. These are commonly referred to as "peanut" plugs.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    If it is stock then run the stock plug.
    My favorite for stock head and aftermarket coil.
    Ngk bp6ht
    Or
    Bosch w7btc
    Finding them might be difficult.
    If caint find, then normal bosch copper plus in a 7 range.
    200+ Posts
    Apr 2015
    pineville, la
    I measured the thread depth and I should be running the 3/4 reach plugs so I put in the bosch 7904. I believe they are a heat range 8. Think that
    is what was in it when I got it. I guess it has aftermarket heads. Tried to call the guy I bought it from but couldn't get in touch with him to ask about the heads.Thanks for the suggestions.
    Ngk bp6ht
    Or
    Bosch w7btc
    Oct 2015
    Conway
    Default My plugs
    I am using Pulstar be1h10 plugs in my 1600 5mw spark 9 ft lbs extra torck 7 miles more to the gal these plugs produce 1 mil watts of spark compared to the regular 50 watts of regular plugs also burns super clean checkout pulstar.com
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    What more can be said? Extra torque, 7 mpg increase! My quick calculations tell me that about 10 tanks of gas would recoup the extra cost for a set of four of the new plugs, and the savings are gravy beyond that. Pick up one of the 300 mpg carburetors that are locked away, switch to hydrogen-based fuel and you'd be set for some long, inexpensive rides.
    Sorry, I couldn't resist.
    Meme Master
    Jan 2014
    Farmington, NH USA
    ...I guess if it sounds too good to be true...
  1. 12V Power plugs
    By TnTrikeRider in forum Stallion Trikes
    Last Post: 08-08-2015, 05:06 PM
  2. Stallion Plugs
    By Dean H in forum Stallion Trikes
    Last Post: 10-13-2014, 09:21 PM
  3. 120R plugs?
    By eighty80 in forum Harley Trike Conversions
    Last Post: 06-10-2013, 07:33 AM
  4. Body Plugs
    By Gunny_ in forum Yamaha Trikes
    Last Post: 07-09-2012, 12:30 PM
  5. spark plugs
    By DJS in forum Honda Trikes
    Last Post: 06-03-2012, 04:26 PM
