Likes Likes:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: Stuck hazard button
  1. #21
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by Gold Rush View Post
    It is my experience that this style switch needs actual lubricant to stay working. There are moving parts that will ware if not properly lubed. Sprays of several types are temporary measures. Dielectric grease works very well in these switches but that requires removing and taking them apart.
    Dielectric grease is good for non arcing contacts like in plugs, connections ..... but it's silicone based and if used in a arcing contact situation, like switch contacts ....
    .... the high momentary temps will cause it to build a black coating on the contacts that will in time, need to be cleaned off.
    <div class="bbcode_container]
    <div class="bbcode_quote]
    <div class="quote_container]
    <div class="bbcode_quote_container][/QUOTE]
    I've had problems with window switches of my '07 FX4 PU and when opened up, found such a black coating on the contacts of the problem children.
    I cleaned it off and used some NO-OX-ID grease on them instead .... not silicone based, no build up either.
    This is a link for a big 8 oz tube, you can get smaller portions at Amazon or Ebay, and all over the net. Tube or tub or small envelopes. . https://www.amazon.com/gp/product/B0...A1EZ2V2AKS0VVR
    It's even available in spray .... search Amazon.
    "A little dab will do ya".
  2. #22
    500+ Posts Konrad's Avatar
    Nov 2010
    La Grange, KY
    Default NO silicone spray!
    Quote Originally Posted by 1dn5up View Post
    Load that button up with silicone spray- then work it
    Best forget the Silicone Spray! It probably contains acetone which can make a mess of plastic parts. Try CRC brand QD ele3ctroniuc cleaner at Walmart. Recommended by the best Honda Mechanic in the world: Stu Oltman.
  3. #23
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Quote Originally Posted by Konrad View Post
    CRC is all I use for cleaners. They're brake cleaner I buy 3 or 4 cans at a time. Anyone use the silicone on rubber boots of shafts? Read on CSC web its suppose to be done every 4k miles.
  4. #24
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    I have been using spray silicone (many different brands) for years now and not once have I seen any damage. In fact, on rubber it is the preferred method to keep squeaking noises away and the rubber protected. CRC makes many fine products so I sure would not doubt your recommendation. As a spray cleaner be sure when used on switches that there is a lube quality.
    On the switches is we have been discussing I'll repeat my recommendation.... Use sprays as a quick emergency fix but get it done correctly as soon as you can...
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
  1. Help, it is stuck!
    By Paperlady in forum Honda Trikes
    Last Post: 09-03-2014, 09:06 AM
  2. Hazard Flashers
    By Blueribbon in forum Honda Trikes
    Last Post: 11-03-2012, 11:16 AM
