14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  34
Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 101 to 115 of 115
Thread: 2016 Tri glide handlebars
  1. #101
    TOI - Idaho BinIdaho's Avatar
    May 2009
    Caldwell, Idaho
    Quote Originally Posted by Phu Cat View Post
    I bought the pull back bars from HD and also needed a new speaker switch and since the installation video recommended replacing the silicone risers I also got a set of those. The indy I called quoted me a price of $350 to install that which seems a little high to me. Didn't a lot of you get the bars installed for $150? That leaves $200 to install each of the other two components. I'm wondering if he looked up installing them individually rather than while he had everything else while he was right there to install the handle bars? I want to clear this up before I call the guy back and question him. TIA.
    PC
    Think my bars were $150.....almost $1K total for bars, labor, shorter clutch cable and iso grips!
    Barbara
    2020 HD Tri-Glide
    River Rock Gray/Black Accents
  2. #102
    Dec 2013
    Clarion PA USA
    Thumbs up Call him before he changes his mind
    That's a great price and give him a $50 for a tip when you pick it up. Providing he knows what he is doing! ride safely fearless
    PC
  3. #103
    5+ Posts
    Dec 2016
    Benton, Arkansas
    Quote Originally Posted by Fearless View Post
    I agree, that's a great price. I got two quotes of $1000-1100, one from the dealer and one from an independent. I did them myself this past weekend and it was tougher than I expected. It took about four hours for me and a friend to get it completed. Had a very difficult time getting the connector plugs threaded through the bars, that probably took at least half of the time I spent doing it. The video was a great help in getting it done.
  4. #104
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    The exact reason I let my dealer do mine. Those micro connectors and my arthritis don't mesh very good. Also, with my tri being brand new, everything was/is covered by the factory warranty
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
  5. #105
    20+ Posts 6bull's Avatar
    Jan 2014
    Kansas
    Default Re: 2016 Tri glide handlebars
    Quote Originally Posted by Waldo1 View Post
    Every thing fits perfect , but i'll tell you if it were an inch longer i would have been in trouble lol , ohhhhhh another important thing , the TBW plug on the Tri Glide didn't have to be torn apart it went right through the bars without taking all the wire loose from the plug.
    Waldo1
    Just came across this thread, I'm thinking of changing out my handle bars on my 2016 Tri Glide. I see you installed Khrome Werks 2+2 sweepers, I'm going with Khrome Werks 12" Bobber Bagger Apes. I'm not sure of the rise of your sweepers, but the rise on my bagger apes is 11.6 inches.
    You mentioned that you didn't need any wire extensions, clutch or brake line extensions? Did you change the throttle grip or replace the bushings? If you did I may of over looked that.
    After reading your post and looking at the photos you took, I'm going to give the handle bar a change as the dealer quoted me $800 for parts and labor.
    6bull (aka Jim)
    2016 Tri Glide, Cosmic Blue Pearl, Stage 1, Screamin' Eagle Ventilator Elite Air Cleaner, Power Vision, Rush 7017 HO Exhaust, Big Louie 4" Slip-On Mufflers, DK Custom 14" Pro Action Shocks, DK Custom Tour-Pak Relocator, Custom Dynamics LED Turn Signals, Custom Dynamics SMART Triple Play
    [/SIZE]
  6. DKCustoms postbit
  7. #106
    5+ Posts
    Dec 2016
    Benton, Arkansas
    Default Not Waldo but
    Quote Originally Posted by 6bull View Post
    Waldo1
    6bull (aka Jim)
    I installed the 2+2 Narrow Sweepers and I definitely needed the wire extensions. The throttle cable and clutch cable were not an issue but the wiring definitely was. I would suggest you pick up a set of wire extensions and return them if they are not needed in your application (just for the peace of mind). I had to stop in the middle of my install and run to the dealer to get a set. They were thirty dollars for both sides and the dealer had them in stock.
  8. #107
    200+ Posts bronxbill's Avatar
    Jan 2016
    Raleigh NC
    Quote Originally Posted by Alan2016 View Post
    I installed the 2+2 Wide Sweepers on mine. I could have made it without the extensions but it would have been a lot harder. You can get a set from Surdyke or Boardtracker for about $25. If I had to do it again, I'd still use the extensions
    2016 Tri Glide Black and Silver, VIEDS, LRS, DK Comfort Lift, DK 2" Tank Lift Kit, Road Zepplin Seat, Black CVO mirrors, K&N Air Filter, Wards Fans, Khrome Werks 2+2 Wide Sweepers.
  9. #108
    30+ Posts
    Oct 2016
    Louisiana
    I did it with out any extensions, and i did change the bushings from the rubber ones to polyurethane ones , i did it i would say go far it, i love it now so relaxed when riding
  10. #109
    Jan 2014
    Kansas
    Just a shout out to Waldo1 and others who replied. After reading this thread and asking questions, I changed out my stock handlebars with Khrome Werks 1x12 ape hangers #300201. It's a very simple job, just take your time, watch a couple of youtube videos and it helps to have a manual.
    Not trying to steal this thread, just wanted to say thanks to everyone in this thread.
Size:  640.9 KBName:  handlebars2.jpg
    [/SIZE]
  11. #110
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    Just a heads up......I am going take a chance and say you have changed bars on other motorcycles.......The cost of changing out to higher bars {especially if you go more than 2"} is a chunk of change. jc
  12. #111
    Dec 2013
    Clarion PA USA
    Default Nice work on the apes
    Those Apes look really good nice work should really make a difference riding keep us posted on result. ride safely Fred
  13. #112
    30+ Posts
    Oct 2016
    Louisiana
    Looks awsome , i never worked on a bike before that was my first, like all here ask and look and you will have the satisfaction on you did it and most of all ya still have ya cash in pocket for other things .
  14. #113
    60+ Posts 30glock's Avatar
    Jul 2016
    Somewhere in usa
    xxxx
  15. #114
    60+ Posts
    Mar 2010
    Western NY
    Default Added Comfort
    I just changed to LA choppers 12" Twin Peaks 1-1/4" Bars. They are a perfect fit as they added about 4" to height from stock. I am 5'10". Changed to Alloy Art HD-2 urethane bushings, (you will need to replace bolts with 1/2-20 x 2-1/4 Lg grade-5) and I chose to leave the wire harness intact and used Namz #486359, 8" wire extensions. These are plug and play so no splicing needed. Only frustration was pulling wires through handlebars. One of the U-Tube videos showed the guy using weed eater chord and this worked like a charm. You can push the chord through without weights. I found it easier to place the Throttle-By-Wire through first and leave it out about 6 inches then pull the switch wire through as it is more flexible. Used petroleum jelly (Vaseline) coating to help. Very happy with the quality of each of these components.Name:  100_2302.JPG
Size:  644.2 KBName:  100_2298.JPG
    '15 TG Red Sunglo/Cayenne, Chrome Forks & Wheels, LED's, TGlide Stuff Lift.
    Patriot Guard
    Previous HD's: '13 TriGlide, '13 Fat Bob, '05 Super Glide, '00 Heritage, '96 Heritage, '94 FLHTC, '77 FXR
  16. #115
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    thanks for the reply , im 5'10" and not a small fella , i have 550 miles on it so far but find that i make excuses not to ride as much cause i know ill be kinda miserable but im gonna give it a chance , i did read and please tell me if im wrong where when im in a cure not to let up but rather throttle up some is this correct????
    One thing that will help in curves,for example if going into a right hand curve press down on the left floor board and right board if going left.This will help with the sensation of falling off.Lock your elbow and push with your upper body.It took me over 2000 miles to get used to the trike,but now its great,I find I can ride more miles per day than I could on my two wheeler's.
  17. DKCustoms postbit
  1. New 2016 Tri Glide pricing
    By gandrea in forum Harley Tri Glide
    Last Post: 08-27-2016, 09:46 PM
  2. what first on a new 2016 tri glide
    By flhrc in forum Harley Tri Glide
    Last Post: 07-15-2016, 09:19 PM
  3. 2016 Tri Glide electrical problem
    By Ultra fred in forum Harley Tri Glide
    Last Post: 04-18-2016, 10:25 AM
  4. 2016 Tri Glide running boards
    Last Post: 03-21-2016, 01:50 AM
  5. New Handlebars on the 2011 Tri Glide
    By MontgomeryLittle in forum Harley Tri Glide
    Last Post: 08-15-2011, 08:48 AM
