Likes Likes:  700
Thanks Thanks:  56
Page 7 of 33 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 121 to 140 of 651
Thread: 88 blazer trike
  1. #121
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    i will definitly agree with vw bug. that setup will work just fine.......i've noticed that when using smooth side w/p pulleys....they give more degrees of belt wrap....less traction than with grooves, l suppose.
  2. #122
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Great,
    Once I get the Trany cross-member done I can start on that
    This weekend is tied up with Honey do list and PM on my other trike
    Thank you
    Bob
  3. #123
    Sep 2014
    Moneta VA
    started mocking up the altenator
    The stock bracket puts it up to high
    if I make my own bracket I can lower it 2 inches
    Thank you
    Bob
  4. #124
    Sep 2014
    Moneta VA
    Not sure why all my pics got turned on their side
    Had issue uploading another pic also
    Thank you
    Bob
  5. #125
    Sep 2014
    Moneta VA
    fabricated the cross member yesterday
    for now it has 1 bolt on each side
    later it will have 2 on each side
    need to weld some gussets on the underside on the bracket that is actually welded to the frame
    Thank you
    Bob
  6. #126
    La Villa Strangiato MarkFL's Avatar
    Sep 2016
    St. Augustine, FL., U.S.
    Quote Originally Posted by Fowler View Post
    I've rotated them as requested.
    "I am against any nationalism, even in the guise of mere patriotism. Privileges based on position and property have always seemed to me unjust and pernicious, as did any exaggerated personality cult." — Albert Einstein
    "Living in the pools, They soon forget about the sea..."— Rush, "Natural Science" (1980)
  7. #127
    Sep 2014
    Moneta VA
    Quote Originally Posted by MarkFL View Post
    Thank you
    Bob
  8. #128
    Jun 2016
    milnor n.d. usa
    Default crossmember
    bob.....what are your plans for the humped up crossmember that is above your new rear trans.mount??? .....realize it was/is needed to keep frame in alignment. body mnt. seat mounting or what.....just curious.
  9. #129
    Sep 2014
    Moneta VA
    Quote Originally Posted by LarryA View Post
    In front of the cross member will be the front seat (above the trany)
    Behind that will be the back seat. (will have a plate over the drive shaft for Butt protection)
    Then the gas tank and at the end a truck bed with a nice wood floor inlay
    My wife wants a dash panel so attached to that cross member will be some type of stand with a platform on top. Not sure what will go in her dash yet
    Thank you
    Bob
  10. #130
    750+ Posts
    Jan 2010
    east windsor ct
    you are moving right along, more than i can say for my projects...no idea if its been mentioned or not...but it looks like your pinion may be up a tad... should be within a couple degrees of the trans..if not it will vibrate...i think you can buy wedges to help or cut n re-weld the saddles....
    this a great explanation
  11. #131
    Sep 2014
    Moneta VA
    Quote Originally Posted by stacebg View Post
    Not for a Double Cardan/CV shaft.
    The Pinion angle is different when setting them up
    Thank you
    Bob
  12. #132
    750+ Posts
    Jan 2010
    east windsor ct
    ah i figured you probably had if covered.. but thought i would mention it
  13. #133
    Sep 2014
    Moneta VA
    I appreciate that. The more advice the better.
    I try to take it all in and then make as informed of a decision as I can
    Thank you
    Bob
  14. #134
    Jun 2016
    milnor n.d. usa
    Default reply
    good info on drive shafts.....sounds like that crossmember will be put to good use! i like that idea of a dash for the passenger, could be a backrest for the driver and used for a hand hold for the passenger to get into the their seat. speakers mountings ,electronics etc. also a partial windbreak for the passenger. i am enjoying the build !!
  15. #135
    Sep 2014
    Moneta VA
    I think I have my rake and trail wrong
    Did not have a lot of time this weekend but put this front wheel on just for I could roll it around the shop
    Thank you
    Bob
  16. #136
    Jun 2016
    milnor n.d. usa
    Default reply
    yes, rake and trail do not look good! lol!! however necessity is the mother of invention!
  17. #137
    750+ Posts
    Jan 2010
    east windsor ct
    just about right.....
    put a riser in the stem, turn the bars around, add some heim joints and rods u should be good to go ... looks like about 1-1/2" of trail... perfect!!
  18. #138
    Sep 2014
    Moneta VA
    I got the bottom part on the alternator bracket made. Now need to make the adjustable arm
    Its made out of 1/4 flat and 1/2 rebar support
    I like the look but wish I had justification to put another one on the other side to balance the look out
    Instead I will put a dummy pulley on the other side
    Thank you
    Bob
  19. #139
    Sep 2014
    Moneta VA
    set an old seat on it.
    I may have to rethink my seat design
    I was going to have front seat, back seat, gas tank, truck bed
    Basically I will have to move the front and back seats back some and move the gas tank to a different location and/or lengthen the rear for the truck bed
    Thank you
    Bob
  20. #140
    Jun 2016
    milnor n.d. usa
    yeah....maybe move back 18" or so. gotta have room for legs and feet. if headers go straight out and then down over frame, your feet could be between headers and block , but could get warm.....other wise either side of tranny or bellhousing.....you may have to decide on your exhaust system before the seat location, just saying.
  1. Happy Birthday Trail Blazer
    By Papa Zook in forum General Discussion
    Last Post: 12-07-2016, 02:39 PM
