Cut N Shoot Customs2miaboboCut N Shoot CustomsGL1800 & GL1500 Fork Tube Exten...
LD-Ordie7ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie7trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie7SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16LD-OrdieHarley Tri Glide2024 Tri glide
LD-Ordie7LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  10
Results 1 to 16 of 16
Thread: High speed flutter
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Default High speed flutter
    This owner complained about an unusual flutter (or chatter) while in 4th or 5th at 70 mph. When I test road it, I immediately noticed a vibration that got worst with speed. I could feel it in my feet and see it in both mirrors. At 70, a flutter could be heard, and when throttling off, it lessoned, and increased when throttled on. The owner described it as "play cards in spoked wheels." However, it was not nearly that loud.
    To me it felt like a shaft not spinning true, and then spinning true. On this design, the shaft goes through the OEM swing arm. I wondered if the shaft was wallowing (no longer spinning centered causing a vibration) because of worn splines or a bad u-joint, and if so could the shaft be rubbing on the inside of the swing-arm tube (causing the flutter). After removing the shaft, a bad front u-joint was found and indeed there is evidence of the shaft rubbing inside the swing arm's tube.
    350+ Posts
    Jul 2016
    N Ky USA
    Although things are serious they look like they were about to get real serious.
    Is that yoke bent or did you open the joint area to make viewing the joint easier? A little hard to tell.
    Either way it's time to put a new card in the spokes!
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    Good catch Greg!! I'd always heard the inline driveshaft configuration was a big selling point for that kit. Food for thought with other owners to keep in mind.
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
    Apr 2010
    Shenandoah Valley of Virginia
    That one was shouting for attention and being ignored for awhile I think.
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Sure glad you found before it got worse. Wonder how common that problem is?
  6. #6
    200+ Posts
    Nov 2010
    CALHAN COL.
    Default Remember
    As the saying goes grease it every time you service it or you well pay the bill just a little goes along way.
  7. #7
    JustWings.com
    Tech Contributor
    May 2016
    Rule of thumb ... never assume what comes "new" out of the box, fits, is correct, assembled correctly, and is good Basically, never assume anything about it !!! Prove it to yourself that it fits, appears to be good, and that it is correct.
    Update ... getting ready to install new shaft assembly. But, when I checked for movement in the front u-joint, it has perceptible movement. I've contacted the trike manufacture and am now waiting for them to send a replacement shaft with good u-joints on both ends.
    It appears this trike company starts with a complete, but used, GL1800 shaft assembly. Then they modify the OEM shaft by welding a rear yoke (or shaft assembly) to the rear of the OEM assembly. The rear part comes with a new joint. But the front joint is used ... which is fine, so long as they start with a good, modifiable, core.
  8. #8
  9. #9
    JustWings.com
    Tech Contributor
    May 2016
    I believe the owner bought it used in 2004 from a trike dealer who was triking it at the time. If I recall the story correctly, the trike dealer bought it as a REPO. The Wing is a 2004 with 56k on the ODM.
  10. #10
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Quote Originally Posted by GoldWingrGreg View Post
    Thanks Greg,
    It's great to have you posting here again on Trike Talk
  11. #11
    90+ Posts fastfreddy2015's Avatar
    Nov 2015
    I live in Pasadena, Texas
    Great post, very good information, thanks for sharing.
  12. #12
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by David357 View Post
    Thanks Greg,
    Thanks Dave ... but you are probably referring to another forum that I used to post on ... I started posting here a short while ago. Fortunately for us all, it appears that the mods are very receptive to posters who post good information. If you know of other GL1800 owners who need assistance that I might be able help on, please direct them here. As always, I share my information/knowledge for free.
  13. #13
    Sep 2016
    Springfield, Mass. USA
    Thanks Gregg,
    I'm also on that "other board" although under a different name!
    I was always happy to see you post with true info...I just had my bike triked (although I have exactly one mile of experience under my belt with a trike- too cold/salty/icy/snowy) yea, yea i know being from Fla. you have no idea what I'm talking about..lol... BUT come this April i'll be out there hopefully riding again....
    Again thank you for everything and good helpful info!!
    Ronnie
    Springfield, Massachusetts
  14. #14
    JustWings.com
    Tech Contributor
    May 2016
    For me this also means to check Honda OEM parts right out of the box. If it appears correct, and it's an assembly, verify that the bolts are tight. Occasionally I find stuff that is not.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
  15. #15
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Greg we miss you on Prowler RTE's. Be nice to see you again on one sometime.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
  16. #16
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by Shimpy View Post
    Thanks ... Marie and I tried to make the "Welcome back snowbird" one, but once we got rolling, we knew we'd be late, and rode to 3 Banana's instead. We were camping that weekend in the Ocala NF. Possibly someday I'll show up at another one.
  1. High speed Tow-Pac tires?
    By 520fd in forum Outrigger Style Trikes
    Last Post: 10-29-2017, 06:52 AM
  2. High speed noise
    By Kentosh in forum Honda Trikes
    Last Post: 05-18-2016, 01:18 PM
  3. High Speed Turning Techniques
    By Jerry/MD in forum Harley Trike Conversions
    Last Post: 01-22-2016, 08:28 PM
  4. High Speed Shake
    By triker.mullins in forum Honda Trikes
    Last Post: 11-27-2015, 09:36 AM
  5. Front end wobbles at high speed.
    By JaysGone in forum Honda Trikes
    Last Post: 06-11-2015, 05:47 PM
