BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  4
Results 1 to 12 of 12
Thread: Can someone please help this guy
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Default Can someone please help this guy
    Anyone else able to spot what is wrong ???
Size:  42.8 KBName:  DSCN8350.JPG
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Dry reservoir and no pad material left?
    5250+ Posts Pegasus1300's Avatar
    Oct 2011
    Spring City,Utah, USA
    Looks like it needs new pads and probably a new rotor and a new bleeder screw. Caliper may be messed up too but can't tell from these pictures.
    Happy TRAils/NSD
    Paul
    JustWings.com
    Tech Contributor
    May 2016
    Anyone else ... the problems are in the center of each picture ???
    70+ Posts
    Shortstop's Avatar
    Aug 2015
    JACKSONVILLE NC
    O.K. I will bite. What is wrong with the pictures. I have a thought for the right one but nothing for the left one.
  6. #6
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Top- don't know what it is
    Bottom- looks like the caliper not squeezing properly
  7. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    If you send the OP 4 dollars in stamps, With a Self address envelope. You'll then receive the answer....
    2019 Tri-Glide.......
  8. #8
    JustWings.com
    Tech Contributor
    May 2016
    This bike was recently sold by a dealer. It looks like it left with new pads and SB-23 being completed.
    In the top picture, the reflection shows in best. The protector (or fluid deflector) in the center is upside down. The one in the clutch m/c is so tight against the bottom of the m/c, my guess would be that someone was thinking it was an 1 way reed valve . Possibly when they took Basic Brakes and Hydraulics 101, they were absent that day.
    The other picture shows brake pads in the RF caliper. It has Honda pads with the silencing pads against the pistons. It looks like left pads are on the right side and the right pad set is on the left.
  9. #9
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Don't know anyting about goldwings. But lookin at the picture that little doodad looks like it fits pretty good in that slot. But then you mention the clutch and now I'm wonderin what the problem was that you would take all that stuff apart? Just curious don't know much about it, but there's guys here that could maybe help out if they knew the problem. If this is totally irrelevant never mind.
  10. #10
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by Sidecarbill View Post
    This Wing is in for a major service which includes many inspections of various systems, as well as inspecting the brakes, and changing the brake and clutch fluid.
  11. #11
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Greg, good information and pics, thanks for posting. Could you maybe post an after picture with the problem corrected?
  12. #12
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by Bazooka View Post
    Below is the same m/c with the deflector installed correctly. Under the deflector are 2 ports. One is not visible. The purpose of the deflector is to keep fluid from aerating. If it where not there, fluid exiting out the exhaust port would squirt upwards and splash diaphragm under the cover.
    Here is a picture from another Wing with the RF pad set installed correctly.
