Likes Likes:  4
Results 1 to 15 of 15
Thread: 2008 stallion
    50+ Posts
    Aug 2014
    Al. USA
    Default 2008 stallion
    Hi i have a 2008 stallion with about 9500 miles on it. The front valve stem is leaking air and i need a replacement. Does anyone know where I can get one to fit the Stallion?
    Thank You
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    I had to get mine through the company. It was a lot easier than drilling out the wheel and it didn't take very long to get them in the mail.
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    I had mine drilled out so I could put a 90deg valve stem in. Rick
    If you got to ride, ride in style
    Stallion #378
    Suzuki Burgman 650
    50+ Posts
    Aug 2014
    Al. USA
    Default stallion triks info
    Quote Originally Posted by Ed Hobgood View Post
    can you please respond with a number and name i can order the valve stem from?
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by larry j View Post
    The 90 degree valve stems are at all the parts stores as well as most motorcycle shops. If you are mechanically inclined, pull your front tire off and take it to a m/c shop and they will drill out the hole and install the 90 degree ($10 valve ). This valve will allow you to check or add air much easier. Just make sure that the valve stem is parallel with the wheel so it clears the brake caliper.
    Tomg
  6. #6
    Jan 2011
    Dexter, MO, USA
    Call Thoroughbred Motorsports at 903-842-5065 and let them know what you need. They sent mine out the same day but that was a year ago.
  7. #7
    50+ Posts
    Aug 2014
    Al. USA
    Default trike valve stem
    I called yesterday person said they did not have those in stock suggested I look up prestiage moter co as they were the ones who made them fot the trike
  8. #8
    Oct 2009
    Titusville, Florida
    The stock valve stem is a pain in the butt and it is worth the few bucks to get a standard valve stem (90degree) installed. Checking air and adding if necessary is much easier.
    Tomg
  9. #9
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I bought angled valve stems for my sport bike here: https://www.kurveygirl.com/shop/index.php?cPath=169
    Bob
  10. #10
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    Hey guys (rocket1lf / tomg), did anyone mention what the hole size was before it was reamed out by chance? Do you know what the reamed out hole size is?
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
  11. #11
    Dec 2013
    Hot Arizona, USA
    Quote Originally Posted by Dean H View Post
    I took mine into a wheel shop and they drilled it out to fit a standard 90deg stem.
    Stallion #378
    Suzuki Burgman 650
  12. #12
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Not a new thread I know. Unfortunately, those who have mentioned it are correct and Motor Trike does not have these valve stems in stock. We are working on getting an order placed with the vendor, but at this point in time we don't have a lead time estimate for them.
    In addition to the comments about modifying the rim to fit a standard valve stem (which is a great alternative); the most common cause for a leaking front valve stem is the rubber "seals" that sandwich the wheel to seal. With time they tend to dry rot a bit and cause air leaks. You can remove the valve stem, pull the seals off & have them matched with a comparable replacement through a local bearing/seal shop and in many times with a Napa/Carquest based parts store where the parts folks know how to find something without having to know a vehicle.
    Just putting the information out there to help a bit.
  13. #13
    Jan 2011
    Dexter, MO, USA
    Thank You
    larry j, If you order a new valve stem you might think about ordering two like I did so you have another replacement when needed the next time.
  14. #14
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by trike tech View Post
    Thanks Richard
  15. #15
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    I found the stems on the Prestige web site and they were listed at $1.95 each, the kicker was because the order was less than $50. they wanted to charge a $30. small order fee. I tried several years ago and also recently. Richard is right, the outer seal deterioates and causes it to leak. I ran a faucet washer for several years.
  1. 2008 stallion body ?
    By window in forum Stallion Trikes
    Last Post: 09-17-2014, 08:19 AM
