Likes Likes:  19
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Champion Trike rear wheel removal.
  1. #21
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Another idea.Raise the front up.Like on a car ramp. And tie the pedal down.Just throwing ideas at ya.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  2. Roadsmith banner
  3. #22
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    "Removing the body sounds more scary than it actually is but just takes patience and some wrenches. you will need some help reaching bolts and lifting the shell.
    I can have mine off in a hour or so.
    If you lift the shell plan to take time to adjust drive belt etc."
    A trick I learned for installing/removing body without help. I found a cheap stamped steel 9/16"
    wrench long enough that it wouldn't spin around in the tunnel and tack welded it to a bolt and fender washer. Just reach in and insert bolt wrench combo into the hole, install a nut and washer from below and tighten with air socket wrench. You wouldn't need someone to hold bolt from turning.
  4. #23
    20+ Posts Regwal's Avatar
    Jan 2017
    St. Marys, Georgia
    Quote Originally Posted by Marc H View Post
    Just for fun if you can find a way with the bleeders closed use a bungee to tie the pedal down.Leave it overnight and see what it does.I've used this method successfully on fronts before and I think I used it on the rear of my Champion but not 100% on that.
    I tried as you suggested again, since I had bled so much. Before the pedal would fade over time. Last night until this evening it didn't. Not sure what that indicates, more air and residual valve is ok????? I hope that to be the case. Tomorrow when help is plentiful I will continue bleeding.
  5. #24
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Quote Originally Posted by Regwal View Post
    I've used it also
    Enjoy life now!----------IT HAS AN EXPERATION DATE
    1989 HARLEY DAVIDSON TOUR GLIDE ULTRA CHAMPION- A WOLF IN SHEEP'S CLOTHING-(CUT YOUR WOLF LOOSE!)
    the difference between a good trike and a bad one depends entirely on the integrity of it's builder!
  6. #25
    Jan 2017
    St. Marys, Georgia
    Post
    Guys/Gals, this has become ridiculous now! I have used a lot of fluid bleeding these confounded brakes. At this advanced age I am thinking seriously of taking it in where my problem can be solved. If I don't get by this pm, in she goes. $$$$$ DW was correct when referring to residual valve replacement when she stated " it is going into the shop". Now I wish she had included "bleeding" as well!
  7. #26
    Jan 2017
    St. Marys, Georgia
    Finally! After today I have a strong 1/2 pedal. Easy to slide wheels on non-pavement surface. I read somewhere to tap pedal when rolling backward to keep brakes in adjustment. Also read to slide foot off pedal letting back pressure to head toward master cylinder after using brakes to help purge air back to master cylinder. Never heard of the latter before.
  8. #27
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Congrats on getting the brakes working.This hasn't been mentioned yet check the routing of the hose from the reservoir to the master. Mine wasn't quite right and when I changed it my pedal stays high.Before it wasn't always there and had to be pumped once to get the pedal up.May not have anything to do with your problem but worth a look.
    2006 GL1800 CSC
  9. #28
    Jan 2017
    St. Marys, Georgia
    Would you explain further? Even though I have good brakes the 1/2 pedal annoys me.
  10. #29
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    My pedal used to be low at different times.Its been awhile now and I don't remember specifics other than a few pumps would get me almost a full pedal.I was rerouting the line going to the rear and had the install instructions pulled up and noticed the hose from the reservoir to the master was routed differently than instructed and there was a slight kink if I remember correctly.Since I changed it my pedal stays up.Another thing to look at is the pedal adjustment just be careful if you get it to high it cause lockup but too low may keep you from getting enough pedal.I downloaded the install instructions from the Champion site.
    2006 GL1800 CSC
  11. Roadsmith banner
  12. #30
    Jan 2017
    St. Marys, Georgia
    I checked mine by assembly instruction and it appears to be correct, but thanks for mentioning this.
  13. #31
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    No problem. Sometimes when things just won't go right backing up checking fro. The beginning is a good idea.Tnhats sort of where I was headed with that.Just don't go after too many things at once.
    2006 GL1800 CSC
  1. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  2. Tool For Champion Trike Back Tire Removal
    By FRR in forum Honda Trikes
    Last Post: 07-02-2016, 04:32 AM
  3. Where can I find a reverse trike rear wheel?
    By Stryker in forum Tires, Wheels, Brakes, Front End
    Last Post: 02-17-2012, 07:46 AM
  4. champion trike rear tires
    By john in forum Honda Trikes
    Last Post: 07-26-2010, 08:25 AM
