Well, was trying install the Love Jugs on my 16 Tri Glide. While trying to remove rubber damper from horn mount bracket, I completely ripped the rubber damper off the mount. The only recourse I see is to remove the tank and take the horn mount bracket off the heads. Unless some one else has a better idea. If not, I need the torque specs for the two bolts that hold the horn mount bracket.
Nuc
