Likes Likes:  2
Results 1 to 10 of 10
Thread: fuel mpg
    Mar 2015
    pierre sd usa
    Default fuel mpg
    Has anybody with a 2017 checked there mpg stock and then with a stage 1 ?
    Quote Originally Posted by ruger View Post
    Apples to Oranges here... With my 11 Tri-Glide, The MPG was a little better with the Stage 1...If driven the same way...But with almost 8 hundred more rpm's to play with, If you start playing with them, And you will at first' Then the MPG's will be lower...
    Mar 2015
    pierre sd usa
    I have a 2017 thinking about a stage 1 didn't want to mess up the mileage it gets pretty good now around 35. I had a 15 that i did a stage 1 on and the mileage went down don't want to do that again
    30+ Posts Bigiron's Avatar
    May 2016
    Nashville, TN USA
    36.5mpg last fill-up on 2017 Triglide. Still breaking it in.
    70+ Posts Hogdoc's Avatar
    Snellville. GA USA
    All I'm gettin' are "smiles to the gallon"!
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    On the one M8 Freewheeler we tested, the MPG are a bit better with the DK Custom Stage I.
    We'll be posting some charts soon, that will include the AFR, stock and Stage I, which has a lot to do with mpg.
    You can see a little info that we have already posted on the subject in this thread-
    http://www.triketalk.com/forum/threa...ht-Freewheeler
    www.DKCustom.com
    Mar 2015
    pierre sd usa
    Thanks Kevin I will check it out
    There are too many Variances in filling a gas tank with exactly the same amount of gas to get a really actuate MPG figure...Example;
    6gal 180 miles 30
    5.6 180 miles 32
    5.3 180 34....
    The only way to tell is run completely dry, Then put in a known 5 gal then run it dry ...
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    I keep a mileage log on all my cars and bikes. Have for 50 years since leaving the Marines where I had to do that with my radio jeep. Divide the miles (trip milage) by the amount of gas you put in. Gives pretty fare figures. May vary by 1 or 2 mpg. Close enough for government work.
    IBA#61162
    PATRIOT GUARD
    USMC
  11. #10
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    6gal 180 miles 30
    5.6 180 miles 32
    5.3 180 34....
    True that. Which is why I use the Power Vision for MPG. The computer knows how much fuel was actually used (regardless of how full the tank was/is), it also knows how many miles were traveled...from there it is an easy calculation for it to spit out the MPG.
    www.DKCustom.com
  1. What fuel? Anyone ever use Aviation fuel?
    By hazel in forum Harley Trike Conversions
    Last Post: 09-06-2023, 10:14 PM
  2. Fuel cap
    By M2102 in forum Honda Trikes
    Last Post: 10-23-2016, 07:04 AM
  3. Fuel Moto
    By plumberdoug in forum Harley Trike Conversions
    Last Post: 05-22-2015, 05:43 AM
  4. Fuel Pac vs TTS
    By VaThumper in forum Harley Trike Conversions
    Last Post: 02-26-2012, 04:15 AM
  5. fuel
    By ronchi in forum General Discussion
    Last Post: 12-30-2011, 08:30 AM
