Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  1
Results 1 to 13 of 13
Thread: Velcro
    20+ Posts
    Jun 2016
    Roanoke tx denton
    Default Velcro
    What would you use to clean the inside of the fender to stick Velcro to it. Thanks Dan
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by Dmdrone View Post
    If you are talking fiberglass, use soap and water. After drying I use brake-kleen on a towel and remove all residue where the velcro is being applied.
    Jim Murphy
    Iron Butt Rider 2001
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    3M Dual lock is far superior to velcro. You have 250 stems per sq inch (sj3870) and 400 (sj3871) to choose from.
    These are the outdoor adhesive units.
    https://www.itapestore.com/3mduallocksj3870.aspx
    Bob
    2500+ Posts GARYD's Avatar
    Oct 2011
    GLEN ELLYN, IL. USA
    That is better then Velcro, but my problem has always been the glue on the tape. So far I have not found anything that will stay stuck in very hot temps. Check out the tread here on trike saddlebag mounting. Someone is having great success with this type tape. I'm sure there is some great tape out there, but I'm not trusting anything but good old nuts and bolts for peace of mind security.
    IBA#61162
    PATRIOT GUARD
    USMC
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by GARYD View Post
    That is better then Velcro, but my problem has always been the glue on the tape. So far I have not found anything that will stay stuck in very hot temps. Check out the tread here on trike saddlebag mounting. Someone is having great success with 3M type tape like this. I'm sure there is some great tape out there, but I'm not trusting anything but good old nuts and bolts for peace of mind security.
    I agree, Nuts and bolts.. Talk to any road maintenance person and thell tell you that the roads are filled with un-guled pieces of plastic ...
    2019 Tri-Glide.......
  6. DKCustoms postbit
  7. #6
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I would use the nut and bolts IMHO, have talked to 3M about this, no velcro, no dual lock fastester, no double sided tape, they don't think it will hold that great for going down the road with the wind, the rain and everything else that are on the roads, they said you could lose a mud flap, mud flap could break or crack, now with the bolt and nut system you could replace it if lost or damaged, easier to replace instead of all these above or even automotive glue.
    All for now Trampas
  8. #7
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Tried to edit my post, not sure why you only have 10 minutes to do it, one other thing is the heat depending on where you are, 3M said heat can be a big factor on holding this stuff on, if it is not prep right even the glue. I know 67Wizard glued his on and been on for 2 years according to him, but if it breaks or get a crack in it, have fun trying to get it off, nuts and bolts is the way to do it.
    Now I don't like the idea of drilling in the fender myself, but when I get what I want, I will be drilling the holes for the nuts and bolts so I can replace it easy if any damage occurs to mud flap.
    All for now Trampas
  9. #8
    300+ Posts 67wizard's Avatar
    Aug 2015
    Nv.
    Quote Originally Posted by Trampas View Post
    All for now Trampas
    I still have mine just glued on and it get hot here in Las Vegas Nv.
    My mud flaps are rubber so no cracking to worry about. If I ever loose one just clean the area and glue on another one, only about $20.00. Keep ur fingers crossed.
    CMA member, VietNam 66-67
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  10. #9
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    If you use dual lock make sure it is "VHB" means very high bond.
  11. #10
    200+ Posts bronxbill's Avatar
    Jan 2016
    Raleigh NC
    I have had mine attached to the front fender on three different bikes/trikes. First I washed the area really well, then cleaned with alcohol and let it dry for about 15 min. Make sure you use industrial grade velcro
    2016 Tri Glide Black and Silver, VIEDS, LRS, DK Comfort Lift, DK 2" Tank Lift Kit, Road Zepplin Seat, Black CVO mirrors, K&N Air Filter, Wards Fans, Khrome Werks 2+2 Wide Sweepers.
  12. #11
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    The Velcro SeeThoughBraz furnishes with their various applications is very durable. Works great. I've had their stick on saddle bags on my trike now for over 2 years and has never hinted of coming loose. I've taken them off numerous times to clean the trike, no problems.
    I've tried over the years every body's commercial, heavy duty Velcro.....junk.
    Don't know if the gang at SeeThroughBraz will share their manufacture information but I'd contact them to check out their stuff.
    8~\o
    "Anybody can become an American but ya have to be born a TEXAN"
    "Ya know I haven't been everywhere but it's on my bucket list"
  13. #12
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Lacquer Thinner followed by lots of soapy water
  14. #13
    10+ Posts old soul's Avatar
    Dec 2014
    pollock, sd, usa
    Default Great stick!
    Quote Originally Posted by Lee H. Mann View Post
    ME two.
