Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  2
Results 1 to 12 of 12
Thread: Drain plug
    200+ Posts
    May 2013
    Mackinaw Il usa
    Default Drain plug
    Can you use a drain plug with a magnetic end sticking out about a 1/4 in. in a 1800?
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    For what and where are you gonna use the drain plug that you are describing ???
    If it's for an oil drain plug on a GL1800, most will use the magnetic drain plug part number that's in the final drive. Also, if it's gonna be used on GL1800 for the oil, why do you think you need one ??? The only time I've seen metal on one is when an ADG was failing. Basically, finding metal on an oil drain plug for a GL1800 is rare. Keep in mind that I do lots of transmission repair on GL1800s. Often the owner has installed a magnetic drain plug, and I've not yet seen any cast-iron going through the oil that is full metal particles.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
    JustWings.com
    Tech Contributor
    May 2016
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Quote Originally Posted by howardg View Post
    Hey Howard, I put a drain plug in mine as you describe and have no problems........I've got to say though that I never picked up anything on the magnet. The reason I replaced my original drain plug was because the hex was getting rounded and I didn't want to have any problems. From now on I only use 6 point sockets and wrenches.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
    200+ Posts
    May 2013
    Mackinaw Il usa
    Shimpy, that is why I bought a replacement and it has the magnet that is why I ask.
  6. #6
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by GoldWingrGreg View Post
    Gregg after reading your return answer, it now sounds like I just wasted some money, I purchased a magnet, that fits around the oil filter, thinking I was holding metal on the side of the filter, and keeping it confined inside.... Thank you for all help, to (questions asked) posts
    Ronnie
    Springfield, Mass.
  7. #7
    JustWings.com
    Tech Contributor
    May 2016
    Quote Originally Posted by Burnerboy View Post
    Ronnie
    Springfield, Mass.
    A magnet around an oil filter maybe different. Possibly the flow slows down enough in the filter area for a magnet to work. I was sharing my experience with a magnetic drain plug. My guess is that the oil flow goes by the plug so fast that a magnetic field their attracts little to nothing. The only way to know is to try it with a new filter, and when it's time to change the filter, then cut the filter open to see.
  8. #8
    Sep 2016
    Interesting idea you have here..
    I just replaced my oil/filter last week for my spring riding (just triked it out also)
    I will cut filter open when I replace again..thank you
    Ronnie
  9. #9
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Years ago curiosity got the best of me, And i decided to cut open a oil filter ...But the cutting left a lot of medal filings..So it was a waste of time...
    2019 Tri-Glide.......
  10. #10
    200+ Posts alwrmcusn's Avatar
    Mar 2013
    Rockwood, TN
    Just curious: Isn't the oil filters job to filter out impurities that would include metallic bits? How would a magnet around the filter improve upon that?
    FRA Branch 294 Crossville, TN
    PGR Rider
  11. #11
    200+ Posts
    May 2013
    Mackinaw Il usa
    I might be wrong but the metal is heavy and will sink to the bottom and then the magnet would collect it.
  12. #12
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Years ago Cow Magnets were all the rage, They didn't work either...
  1. Harley oil drain plug !
    By Rollin Thunder in forum Harley Tri Glide
    Last Post: 02-17-2017, 12:56 AM
  2. 2014 tri Glide oil drain plug location ?
    Last Post: 02-12-2017, 12:13 PM
  3. magnetic drain plug on primary
    By ratty in forum Harley Trike Conversions
    Last Post: 07-19-2013, 09:37 AM
  4. CSC Gearbox Drain plug
    By pearlhawk in forum Honda Trikes
    Last Post: 10-27-2011, 08:55 AM
  5. taking out and reinstalling drain plug on Voyager
    By krazybob in forum Outrigger Style Trikes
    Last Post: 10-12-2011, 05:42 PM
