LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken15LD-OrdieHarley Tri Glide2024 Tri glide
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  7
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: Parking brake
  1. #21
    200+ Posts knob's Avatar
    Jan 2015
    Metropolis
    The parking brake is a great idea but I just wish I could remember to unset it. I'll bet someone could come up with a switch and light to remind guys like us that it's on. My truck does. I carry two small 2x4 blocks I cut with me to chock the rear tires when I'm concerned that it might roll.
  2. #22
    40+ Posts slug's Avatar
    May 2008
    Fayetteville, Ga.
    The Eurowing kit uses a separate cable operated caliper for the parking brake on each rear rotor. They mount(relocate) the side stand switch to the parking brake lever so the sidestand light comes on on the dash when the parking brake is engaged. The light being on is a helpful reminder to release the parking brake before you drive off.
  3. #23
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    IMO, the guys who say the parking brake isn't needed don't live where you need them. Two of the responders who said such live in Florida where the biggest hill is a bridge.
    Live and ride in Arkansas or Colorado type states and you will understand how handy it is to have plus added a great deal more safety than wheel chocks, bungees around front brake, etc.
    P.S. If you put the brake full on you will not go far if you try to drive away! I will agree that a reminder light would be nice. I've just been too lazy to add one.
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
  4. #24
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by bikerbillone View Post
    So bottom line, I would not go for that option, there are better ways to keep the machine from rolling away.
    Quote Originally Posted by GoldWingrGreg View Post
    I agree ... put in 1st gear, turn ignition off, let clutch out and allow the trike to roll till is stops rolling, and then get off.
    Pull brake, insert wedge, bike will stay put while warming up in front of room or in driveway .... mount up, squeeze brake, wedge drops, ready to ride.
  5. #25
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Quote Originally Posted by CrystalPistol View Post
    What did you use for a wedge?
    Can you take a close up picture of it?
    What are the dimensions of it?
    Thanks!
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
  6. #26
    80+ Posts
    Feb 2014
    Toledo,Ohio-USA
    Brethren,
    I have a parking brake on my Roadsmith 1500 & never had a problem riding off with it engaged. You'll know right away its on, when you go to shift from 1st to 2nd gear & have a notcicable loss in speed.
    I also purchased a couple of collapsible steel wheel chocks from Harbor Freight that fold down to the size of a deck of playing cards for the unavoidable steep inclines
  7. #27
    Apr 2010
    Quote Originally Posted by BrokenBackJack View Post
    Thanks!
  8. #28
    Apr 2010
    Works very well. I have even used it for longer than a few minutes like where parked on grade in gear. It doesn't needa hard squeeze on the lever to stop a roll away ... as you know from just using the frt brake to hold still at a light. Usually I use it when warming up and there's a grade of any sort, like the parking lot at Park Vista Motel on the Blue Ridge Parkway .... or my back yard outside the basement. Not a steep grade but just enough that there is a tendency for the trike to move if not held stopped.
    Also it let's me set the brake to check all my brake lights.
  9. #29
    3250+ Posts hogmemberisold's Avatar
    Nov 2016
    Shepherdsville, Ky, USA
    This is a good idea, so I used it to put together a short large diameter stainless steel cotter pin, held by a stainless steel bead chain.
    Thanks!
  1. Parking Brake Help
    By pioneer11 in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-17-2016, 06:58 PM
  2. Using a Parking Brake
    By mgwtrike in forum Honda Trikes
    Last Post: 04-25-2015, 10:32 PM
  3. Parking brake
    By 2006gold in forum Can Am Spyder Trikes
    Last Post: 10-13-2013, 08:07 PM
  4. Parking Brake
    By tubaman4 in forum General Discussion
    Last Post: 07-09-2008, 03:35 PM
