Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  12
Results 1 to 14 of 14
Thread: Motor trike razor or Roadsmith HTS
    1+ Posts
    Apr 2017
    Scott Louisiana USA
    Default Motor trike razor or Roadsmith HTS
    I am considering triking my 2012 Honda and not really sure as to whether i want the Motor trike Razor or the Roadsmith HTS ??? any help here would be appreciated thanks
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by toothfairy1948 View Post
    I have a Roadsmith (although I'm new to triking/maybe 300 miles under my belt) I love it
    Ronnie
    300+ Posts
    Jun 2014
    S.E. Ohio,Close to the triple nickel
    I chose Roadsmith. Customer service is great. I did my own conversion,and no air bags to mess with. Each has there own features. You have to pick what fits your needs.
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    I have the MT Adventure, same underneath as the Razor. My only complaint is the way MT designed their IRS, with the "cage" around the differential, that part sits too low to the ground. I travel some farm roads (dirt) to kinfolks, and it will drag on a couple inches of stone or ruts. I've seen other better designs but don't remember if RS is one of them.
    Other than that, the MT has been bullet proof for the 40k miles I've ridden it.
    ​2007 Goldwing w/MT Adventure conversion
    IBA: 65855 SS1000, National Parks Tour, Master Traveler Award
    https://www.dosgreengoes.blogspot.com
    300+ Posts
    Jun 2014
    Quote Originally Posted by keepinon View Post
    Can you add more preload( increase air pressure) to raise the ride height for more ground clearance,when on those kind of roads.
  6. #6
    Dec 2011
    New Caney, Tx
    Quote Originally Posted by Fabricater View Post
    In short, no. Increasing the preload, air pressure to the upper bags, only firms up the ride. It does not increase ground clearance.
    At the bottom of this page, you can view the MT IRS. Click the pic for an enlarged view. The anti-roll bar shown in red circles the entire bottom of the unit, this is what drags on mine on some unimproved roads. Increasing preload will keep you from bottoming out on swales in asphalt/improved roads, (in spirited riding) but no increase in actual ground clearance when moving slow. I have learned to closely watch the surface for irregularities. As I said, it is comfortable & about bullet proof, otherwise.
  7. #7
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    You don't state that you have driven either one. DO it! No matter what we say here, it is your butt co-riders', if applicable, that must be happy. There are many differences between these so compare the specs, how they're built, what parts they use, wheelbase (longer is smoother ride just like a car), suspension type and adjustments.
    Also consider how you're doing to use it. Is one or the other prevalent in your area. This has bearing on how many "friends" can share info and help when you need. It also affects resale value. In our area RS outnumbers MT 8:1. Have no idea why.
    No matter your choice, one of the most important decisions is who your installer is. A bad one can screw up the best trike out there and also make any service requirements painful. Spend some time researching your installer as it will pay off in the end.
    Good luck. All the major brands are good. It's like choosing Chevy, Ford, or Chrysler.
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
  8. #8
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    I have a Razor and bought it because of the looks.... I like it!
    All other brands of trikes, well, all look the same. Kind of bland.
    Brother Mike
  9. #9
    Dec 2014
    Grand Junction, Co. USA
    +1 on doing your own test rides ... everyone has a different feel ... you know ... in the seat area ... go with what speaks to you after your rides.
  10. #10
    Jun 2010
    Indianapolis, In.
    I'll give you more food for thought!
    Have you considered a Hannigan?
    Longer wheel base and IRS for a much smoother ride.
    Wider stance for more stability.
    The "biggy" is the rear end is off set to match the Wings drive shaft output. No severe drive shaft angles therefore, no U-joint, shaft failures and low maintenance!
    Optional weight bearing foot fairings mean you can remove your rider pegs and rest you feet on the fairings for a much more comfortable ride.
    I studied and tested all the major conversions for almost 4yrs before picking the Hannigan!
    Picking a good conversion business is also a decision that takes some study.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  11. #11
    80+ Posts Wingrider55's Avatar
    Oct 2015
    Kingston, Illinois
    I bought the Roadsmith two years ago manly because they use a lot of standard automotive parts in there drive line and there great customer service. I road a lot of different brands before I made my purchase and decided on the Roadsmith. I had mine installed at the factory in White Bear Lake Minnesota, dropped it off at 8:30am and picked it up the next day at 10:00am.
  12. #12
    150+ Posts jredman's Avatar
    Jan 2014
    Leander, Texas, USA
    http://www.motortrike.com/trikeHonda1800Razor.aspx
    It does increase ground clearance. I have the Razor and it does raise the entire back end. I do it to go over speed bumps so I do not scrape. And I did it to change the rear tires. Had to go up to 88 lbs to get enough clearance to get the wheels and tires installed.
    Jim's Motor Trike (YouTube)
    http://www.youtube.com/c/JimMotorTrikeRazor
  13. #13
    Dec 2011
    New Caney, Tx
    88#... LOL I've never had mine over about 60# cause it rode like a truck then. I'll try your suggestion when I'm next on the farm rode. Thanks
  14. #14
    Jan 2014
    Leander, Texas, USA
    I do ride at 30lbs and maybe 50lbs two up and pulling a trailer. Super for going over speed bumps too. <grin> I do go back to 30 lbs after the speed bumps.
  1. Razor Motor Trike Kit Questions?
    By netminder in forum Honda Trikes
    Last Post: 08-23-2022, 07:29 PM
  2. Motor Trike Razor Manual
    By alwrmcusn in forum Honda Trikes
    Last Post: 04-13-2019, 06:14 PM
  3. Motor Trike Razor looking for opinion's
    By WOTS in forum Honda Trikes
    Last Post: 03-06-2017, 03:28 PM
  4. Motor Trike Razor (or IRS) Owners
    By tndragonrider in forum Honda Trikes
    Last Post: 06-15-2016, 01:39 PM
  5. Motor Trike Razor - 1800GW
    By wehrme in forum Motor Trike
    Last Post: 08-28-2014, 12:25 PM
