Likes Likes:  36
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 47 of 47
Thread: Stock Air Box Back On Re-Did, Re-Rout EBS Catch Can Set Up
  1. #41
    500+ Posts
    Apr 2016
    Vero Beach, Florida
    Quote Originally Posted by hddocfl View Post
    In my own findings I have felt no suction on the vent hoses or the breather bolts that I can feel anyway. I did take a glass of water and stuck my vent hose in it with the stock A/C mod that we are talking about here and only get a small amount of air bubbles in the water, The water does not go down in the glass as to indicate a suction that is measurable that can be see. I would recommend to anyone not sure of this to not do it. I feel it is the right way to go and may later add a catch can but have seen no reason to add one now. Thanks Doc
    BTW This mod can be undone in minutes back to stock , only showing a hole in the bottom of the plastic A/C housing.
    Doc, This discussion reminds me of some challenging issues we hardcore astronomers have been wrestling with in terms of taming air currents in large-mirrored Newtonian telescopes (28"-45"). I admire your willingness to try and test certain hypotheses. What we have been finding in the astronomy world is that the answers to thermal gremlins are not as readily forthcoming as one would hope for and I have been interacting with some very high level engineers and other scientists over the years. We seem to continue to take bites at the apple and seem to move a step forward and then find that at times that we have taken a step and a half back and had to rely on other solutions or return to our starting point. As long as the equipment is not irreparably harmed, it does not seem like too big a deal to experiment. However, as a former scientist myself in another life (25 years ago), I remember times when I was fairly confident of what results I could expect and was sometimes quite surprised that my suppositions did not bear fruit.
    I think it is fascinating to play with this machinery. I am doing it with two trikes and a race car and find that what seems obvious is not always the correct solution. Please don't ask me about seating choices I will maintain a certain amount of mild skepticism as I watch the solutions continue to come forward for improved performance. As many of us would relate, there is no such thing as a perfect machine.
  2. #42
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool
    Quote Originally Posted by Capt.Bob View Post
    Good one Capt. Glad we can share. Doc
    2019 Red and Silver Tri Glide
  3. #43
    20+ Posts
    May 2019
    Las Cruces
    Default My DIY Engine Oil Vapor Venting System
    I just finished my engine oil venting system.
Size:  113.7 KBName:  17.jpg
Size:  113.0 KBName:  19.jpg
Size:  82.0 KBName:  20.jpg
Size:  112.3 KBName:  21.jpg
  4. #44
    20+ Posts
    May 2019
    Las Cruces
    Default Just a little different MOD
    OK I did your mod,
    Like your mod. My air box is different so my mod is just a little different. Only needed two hose connectors and hose. I did made a change to the routing of the hoses by filing to new places for the OEM hoses to be routed down the sides of the air box (rather then across the top) using the hose connectors and hose to the OEM tee at the bottom air box where I drilled a hole to exit hose.
Size:  102.5 KBName:  23.jpg
Size:  100.3 KBName:  21.jpg
    Will install a small catch can when I get it. Will I have to re-route the hose that laies on the engine housing because of heat melting it?
  5. #45
    300+ Posts
    florissant
    What size hose did you use ?
    hardheaded
  7. #46
    20+ Posts
    May 2019
    Las Cruces
    7/32” ID x 6 FT windshield washer hose / vacuum tubing by Prestone
  8. #47
    20+ Posts
    May 2019
    Las Cruces
    Quote Originally Posted by Mr.T View Post
    Installed catch can.
Size:  84.2 KBName:  IMG_1179.JPG
Size:  113.8 KBName:  IMG_1182.JPG
Size:  108.4 KBName:  IMG_1183.JPG
  1. Replies: 21
    Last Post: 03-21-2017, 07:45 PM
  2. Replies: 6
    Last Post: 01-14-2017, 02:31 AM
  3. Stock Mufflers Back On Freewheeler And I Am Ok With That
    Last Post: 06-29-2016, 06:45 PM
  4. Wards Parts Werks FCS back in stock!
    By MDF48 in forum Harley Tri Glide
    Last Post: 06-29-2016, 08:04 AM
  5. Stock air filter back on....
    By krooozn in forum Honda Trikes
    Last Post: 05-16-2011, 11:58 AM
