Likes Likes:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 33 of 33
Thread: No power, in reverse
  1. #21
    Jun 2008
    Lovington, NM, U.S.A.
    The pics of the reverse actuator.
    The yellow arrow points to the nut you'd want to turn to release the system, take all reverse fuses out before trying to power up and start the bike. You want to turn the bottom one, not the top one.
    Red circle shows close up of nut.
    Retired trike builder
  2. #22
    100+ Posts M2102's Avatar
    Oct 2016
    Pontiac, Illinois
    Quote Originally Posted by trike lady View Post
    I can't thank you enough trike lady for you patients and showing me where to look and what to do. I will be getting a new 70 amp fuse to replace the one that has no power and fingers crossed that it will power up. I will let you know how it goes.the pictures didn't come up on my phone or kindle and have been able to bring them up from other sites. thank goodness for the main computer.
    Thanks again for everything
    Mike
  3. #23
    Oct 2016
    Pontiac, Illinois
    Trike lady i wanted to let you know that it is up and running. A friend suggested last night to try a ground jumper to see if that works. It did. As soon as i touched it to a ground i heard a click on opposite side of trike. I now have all lights on, everything works, goes into reverse and backs up and disengages as it should. That was first thing i tried, didn't try the actuatorm bolt. I'm happy and so is my wife. I can see a moonshine lunch run possobly this weekend.
    Thank you for all your suggestions and if i hear of someone with same issues i know where to have them start.
  4. #24
    2250+ Posts
    Oct 2011
    Ocala, Florida
    Just curious, which ground wire was bad? That ground on my bike may be getting dirty also.
    Thanks, PC
    Beware of liberals posing as Americans.
  5. #25
    Jun 2008
    You're welcome and glad to hear the problem was found.
    There is a ground point under the gas tank. That is the one that sometimes creates problems.
    I has been my pleasure to assist you.
    Have a great day.
  6. #26
    Oct 2016
    Pontiac, Illinois
    Thanks for everything. The ground under the tank may have to wait a bit. But eventually will get to it.
  7. #27
    Oct 2016
    Pontiac, Illinois
    Quote Originally Posted by Phu Cat View Post
    Thanks, PC
    As for the exact one my guess is the battery ground. Put ground in another location then everything is back to normal.
  8. #28
    2250+ Posts
    Oct 2011
    Ocala, Florida
    Am I reading you right 2102? You connected a separate jumper wire from your battery and connected it to somewhere else on the bikes frame?
    PC
  9. #29
    Oct 2016
    Pontiac, Illinois
    Yep. That's what I did.
  10. #30
    Jun 2008
    I learned something new today from this and will remember it.
    Thank you.
  11. #31
    350+ Posts 3W-lonerider's Avatar
    Feb 2008
    Shippensburg, Pa
    it would be interesting to know how big of a ground wire you used.
    I would seriously repair the original ground wire before riding to far.
    if you used to thin of a wire and everything is going threw that wire for ground you will melt and burn that wire creating more problems than you have now. cause everything that wire is running along side of new ground wire will melt right with it.
    I'm hoping you used something about the same size as the ground cable. that's on the battery now.
    the ground coming off the battery should go down and bolt to the back of the engine..
    if you remove and clean the ground cable on the back of the engine, clean the surface areas then put it back on that should be your issue right there.
  12. #32
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Thank you.
    Thats the power of forums , Hundreds of people willing to help one another with a problem, Passing on ideas ... And eventually the problem is solved , Ready to be passed on again..
    2019 Tri-Glide.......
  13. #33
    Oct 2016
    Pontiac, Illinois
    I'm going to parts store later today to get an automotive ground strap to replace what I used. Haven't ride anywhere yet been raining so far all day.
  1. V&H Power Duals and Manual Reverse
    By Ride4Him in forum Harley Trike Conversions
    Last Post: 03-14-2013, 11:42 PM
  2. need more power
    By clo in forum Honda Trikes
    Last Post: 05-08-2012, 02:41 PM
  3. Harley Reverse Trike - Morgan Threewheeler to Return with Harley Power
    By SBStormy in forum Harley Trike Conversions
    Last Post: 11-08-2010, 07:43 AM
