Likes Likes:  5
Results 1 to 14 of 14
Thread: External breather question
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Default External breather question
    I am in the process of putting a DK unit on my 16 Tri with stock AC. I have seen the pics and have the AC figured out. Trying to figure put just where to route and locate the filter. Directions say the black hose should not touch the exhaust or engine. Just how close can the hose be without an issue?
    Anybody got any pics of just how you routed the hose from the bottom of the AC to where ever you put the filter (or catch can)? Thanks
    It is what it is.
    16 Tri Glide vivid black
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by graygoat View Post
    I am in the process of putting a DK unit on my 16 Tri with stock AC. I have seen the pics and have the AC figured out. Trying to figure put just where to route and locate the filter. Directions say the black hose should not touch the exhaust or engine. Just how close can the hose be without an issue? Anybody got any pics of just how you routed the hose from the bottom of the AC to where ever you put the filter (or catch can). Thanks
    It can be within 1/4", you just don't want it touching the exhaust or the fins of the engine. If it is the rubber hose (not braided) it can touch the engine cases with no issues.
    The ways to route are endless, here are a few pics, and below that, a video.
    In this pic you can see the black hose going between the front cylinder and the front exhaust, then turn down along the side of the regulator and then behind the oil cooler.
    In this pic you can see the hose coming from below the air cleaner, along the side of the engine and above the transmission, headed toward the back of the bike.
    www.DKCustom.com
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Thanks, Kevin. Duane returned my call this am and we discussed the options. I ran it from the stock AC to the rear, along the tranny and over the frame cross member. The filter hangs right at the bottom of the cross member (near the rear tie down eye). Seems to be out of the way but I can get at it when ever I wash the bike.
    Thanks for the help!
    It is what it is.
    2250+ Posts
    Oct 2011
    Ocala, Florida
    If you're going to run a really short hose I can see why there's a need to have a filter at the end of that hose. But with a hose that runs back as far as the swing arm is there really any chance of sucking up anything before the next blast of crankcase vapor blasts it back out? With the constant rise and fall of the pistons there has to be some small amount of blow by that escapes no matter how good of a seal we might have, do we really need to worry about anything being sucked back in? A small catch tube of some sort should do the trick, shouldn't it?
    PC
    Beware of liberals posing as Americans.
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Sounds like you chose a great location. If you want to email me any photo's, I would appreciate it, and have them for the next person that asks a similar question. Kevin@DKCustomProducts.com
    Quote Originally Posted by Phu Cat View Post
    PC
    The filter is not necessary to keep anything from being sucked in. The breathers only expel, the umbrella valves keep any air from going back in. Even when the umbrella valves are malfunctioning/worn out, so little air goes back in that with any hose longer than 6 inches, nothing will make it back into the engine.
    The filter is there so that any residual oil mist will be absorbed by the filter, rather than dripping on the ground. Typically a filter will absorb 3000-5000 miles of blow-by before it can't absorb anymore. They are easily cleaned (without removing them) by simply spraying some cleaner on them while washing the bike, letting it sit for a few minutes, then spraying it off with a hose. Then it is ready to absorb another 3000-5000 miles of blow-by.
    www.DKCustom.com
  6. DKCustoms postbit
  7. #6
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Hey Kevin, I am not good at getting camera pics done and emailed (or posted). If a phone pics work for you, I could text them to your cell phone. If that works for you, pm me a cell number. Would be happy to do that.
    It is what it is.
  8. #7
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    That would be great. You can text them to the company text phone at 662-420-4891
    Thank you!!!
    www.DKCustom.com
  9. #8
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Thank you!!!
    OK, I will try that, let me know what you think. If you think they are worth posting, feel free to go ahead.
    thanks
    It is what it is.
  10. #9
    4750+ Posts
    Mar 2015
    Texas
    Just curious as to what kind of cleaner. A brake cleaner? Or a water soluble kind so what?
    The only reason some people are still alive is it's illegal to shoot them.
    American Legion Rider
  11. #10
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by hogcowboy View Post
    I just use whatever I'm washing the bike with. Simple Green or S100 usually.
    www.DKCustom.com
  12. #11
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    Default EBS Filter Cleaning
    I just use whatever I'm washing the bike with. Simple Green or S100 usually.Kevin
    Took mine off and hit it with the same K&N Filter Cleaner used on my AC. Two filters; one cleaner.
  13. #12
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by prariepilot View Post
    That'll work too!
    www.DKCustom.com
  14. #13
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Great idea
    Thanks for posting
  15. #14
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    That'll work too!
    +2... me too!
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  1. ***DK Custom Products introduces the External Air Port***
    By DK Custom Products in forum DK Custom Products
    Last Post: 02-08-2017, 05:08 PM
  2. External breather system
    By Lawless in forum Harley Tri Glide
    Last Post: 12-12-2016, 04:20 PM
  3. external breathers
    By gerald martin in forum General Discussion
    Last Post: 02-04-2016, 05:59 PM
  4. Oil from breather
    By roadrumble in forum Harley Trike Conversions
    Last Post: 01-29-2012, 08:37 AM
