14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  29
Page 2 of 2 FirstFirst 1 2
Results 21 to 29 of 29
Thread: Oil Filter Drain M-8
  1. #21
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    I must be the exception to the rule.....just changed oil and filter and had very little mess. Just laid a rag under the filter while I unscrewed it and tilted it back once it came loose. No oil mess and minimal drip after. I thought the process was relatively easy.
    Not a huge fan of the looks of where that relo kit puts the filter but certainly can see it would be easier to change.
    Dave
    14 HD Tri Glide
    H.O.G. Member
  2. #22
    300+ Posts
    Dec 2014
    florissant
    i bought the erst trough and it works better and is cheaper than the HD one. i then notched the erst one so it goes in farther, punch two holes and let it drain.
    hardheaded
  3. #23
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    I had the DK Dual Cool system on my '14 TGU, and I LOVED it... really made oil changes a breeze, and really increased the value that I got from it when I traded it on the new '17 M8 TGU. Solved the oil change mess by getting the prepaid maintenance plan for the first 20K miles. After that, I will probably go back to the DK system.
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  4. #24
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool Worked OK
    I changed my oil on my 2017 Tri yesterday using the HD filter drain kit made for the M-8. I used a small dish towel under the filter pushed flat against the filter housing used a long skinny screw driver to get it in there loosen the filter just a tad as to not leak. Slid the funnel up in til it clicked in place drilled a hole in the top and bottom of the filter and let it drain , backed off the filter into the funnel let it set for awhile and removed the filter and funnel with no oil mess at all. Thought I would share this info. Doc
    Thanks to Bill G for the tip !!
    2019 Red and Silver Tri Glide
  5. #25
    450+ Posts Bill G's Avatar
    Mar 2015
    Bakersfield California USA
    Quote Originally Posted by hddocfl View Post
    That is exactly what I do Doc, I normally put one hole in the filter at the bottom but I think I might try two like you did next time.
    Ride Safe,
    Bill G
    Through Jesus Christ, I a sinner am saved. Not by my doing but through his doing by his sacrifice and Blood Shed on the Cross. His gift to all mankind that will only believe and accept him by Faith. Through his Death and Resurrection I am Saved by Grace and someday I will be with our Lord in Heaven forever.
  6. DKCustoms postbit
  7. #26
    300+ Posts 67wizard's Avatar
    Aug 2015
    Nv.
    I put a rag under the filter then turn the filter just a little.
    I put a rubber glove around the filter then remove it
    with very little spill 98% of the oil is in the glove. Just
    wipe what did leak and then replace with new filter.
    CMA member, VietNam 66-67
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  8. #27
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool
    The M-8 oil filter is a little tight compared previous years Not much room in that area to get at the filter. Doc
  9. #28
    2250+ Posts
    Oct 2011
    Ocala, Florida
    Attachment 45031​Bought this gizmo after my 2nd messy oil change on our 2012 Tglide. Also built a 5" ramp for the right rear wheel to drive up on to assure all the gunk gets expelled at oil change time. Oil changes much easier and cleaner now. Using K&N oil filter makes things so many times easier also. Don't make the mistake I did back in '88 and forget to lube the new oil filter gasket or you next oil change will be a lesson in frustration.
    PC
    Beware of liberals posing as Americans.
  10. #29
    1000+ Posts
    Aug 2016
    Des Moines IA US
    Was at the dealer the other day and we was talking about the oil filter and the mess, he told me to go to a auto parts store and buy pig mat, cut enough off and lay it under the filter and take it off and tip it up as fast as you can, I guess the pig mat absorbs what oil does spill and no mess, will try it the next time I change oil, just did it awhile ago so not due yet. I had a little spillage the way I did it with a cut out of a milk jug, works good on my road king but not as good with the triglide because of the lowers I guess, not enough room to work around in there.
    All for now Trampas
  1. Drain plug
    By howardg in forum Honda Trikes
    Last Post: 05-03-2017, 08:08 AM
  2. Harley oil drain plug !
    By Rollin Thunder in forum Harley Tri Glide
    Last Post: 02-17-2017, 12:56 AM
  3. Battery drain need help
    By skipg in forum Honda Trikes
    Last Post: 10-14-2014, 01:35 PM
  4. Battery drain?
    By Harry2u in forum Honda Trikes
    Last Post: 08-16-2013, 08:08 PM
  5. CSC Gearbox Drain plug
    By pearlhawk in forum Honda Trikes
    Last Post: 10-27-2011, 08:55 AM
