I've got a metallic rattle noise coming from under the trike on left side near clutch or drive shaft area on my 06 Honda 1300 vtx Motortrike. The mechanic I took it to says he had another 1300 trike making the same noise but is not sure the trike manufacturer.
He had replaced the clutch basket, u joint and finally replaced engine with a salvaged engine and the noise got a little better but never went away. My trike likes to slightly pull to the right, nothing too bad.
He doesn't want to tear into mine not being familiar with trikes but has only seen this on my trike and the other one. I wonder if this is an alignment problem with the kit as if you turn right the noise goes away if if go straight ahead or turn left the noise increases.
It's annoying if you wear a half helmet but can't hear it in a full helmet. Nothing seems loose and the bike is level. Has anyone had this problem? I bought this used and the dealer who was up north never installed the unit for the speedo for recalibration I had to buy it and install it locally. What else did they forget?
