have a 2015 freewheeler with a bumper on the rear. i want to move my license plate from the left side to the center of the trunk area. any ideas on doing this? either on the bumper or the trunk. help will be much appreciated.............
Duct tape?
My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
Check with Kevin at D K . Attached to trunk , DK has a led license plate light , I mounted above plate holder .
Oops!! Wrong file , Daytona bike week .
will look into that,thanks alot slaw
Check with Kevin at D K . Attached to trunk , DK has a led license plate light , I mounted above plate holder .[/QUOTE]
Here's a before & after of mine. I mounted a pc of alum 1"x 1" angle the length of my plate under my bumper using 3M two sided automotive tape. I then pop riveted 3 alum 3/8 rivets for a tight & secure install.I drilled holes in the bracket for the plate and frame before I mounted it. To light the plate I installed Custom Dynamic white tag LEDS, part # TBO1C.....$19.95 pr. I ran the wiring under the body to under the seat and tapped into the right side tailight. Good Luck!
[/SIGPIC]paddle faster, I think I here banjos
thank you,nice post
Here's a before & after of mine. I mounted a pc of alum 1"x 1" angle the length of my plate under my bumper using 3M two sided automotive tape. I then pop riveted 3 alum 3/8 rivets for a tight & secure install.I drilled holes in the bracket for the plate and frame before I mounted it. To light the plate I installed Custom Dynamic white tag LEDS, part # TBO1C.....$19.95 pr. I ran the wiring under the body to under the seat and tapped into the right side tailight. Good Luck![/QUOTE]
What lights you got on the back of your trike?
