Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  44
Page 4 of 4 FirstFirst 1 2 3 4
Results 61 to 71 of 71
Thread: Heel shifter?
  1. #61
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Quote Originally Posted by TriTn View Post
    My extended lever came in this morning. I put it on and lowered it a notch. Rode it a little and with a little time, I'm sure I will like the extra room. Only thing is the one I ordered has poor quality chrome. I can see what looks like copper through some imperfections. Oh, the pinch bolt was smaller than stock, not as beefy.
    ETA: I still want that longer peg for the toe shift lever like Bill G shows in post #5.
    21-1665 Cats paw extended shift peg is what I have.
    Name:  left floor board.jpg
  2. #62
    200+ Posts
    Sep 2017
    SE Tn
    For those thinking about the extended lever. If your trike has the parking brake pedal by the floor board, with the 8.5 inch lever, the peg ends up directly above the pedal. If you set the lever too low it kinda gets in the way of getting to the pedal.
    I was thinking, if I wanted to get rid of the heel shift, I think I would just take the peg off and leave the lever there to keep my boot off the primary. (Oh, this was said in post #41.)
  3. #63
    100+ Posts nevtat's Avatar
    Aug 2010
    Las Vegas, NV
    Who says you can't teach an old dog ... after reading more posts I decided to re-install the heel shifter lever. I've removed it on my other 2-wheel Harleys (4) over the years and never had an issue with finding neutral. When the engine isn't up to normal temp., a soft tap of the heel shifter finds neutral like magic! When the engine is hot, as in it's 105 degrees in Las Vegas and I'm riding in stop and go traffic, the heel shifter isn't much good - yet. I ordered and extended heel lever and will try it again. (The stock levers don't leave enough room on the boards for my size 13 boats.)[/QUOTE]
    My new setup. Checked the inside lever pinch bolt, very tight.Name:  Stormyshifter.jpg
  4. #64
    2500+ Posts GARYD's Avatar
    Oct 2011
    GLEN ELLYN, IL. USA
    ??? What can I say. I have absolutely no problem with mine and I have the lever as low as it will go. I barely have to lift my heal to use it.
    I have the extended floor boards. Maybe that helps?
    IBA#61162
    PATRIOT GUARD
    USMC
  5. #65
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    If you decide to take the heel shifter off....I put a spacer on the inside of the spline and moved the front shifter to the outside position. So now with that added to the extended shift peg it's real easy to get to and shift - jc
  6. DKCustoms postbit
  7. #66
    200+ Posts
    Sep 2017
    SE Tn
    Quote Originally Posted by GARYD View Post
    Do you have the foot operated parking brake?
    ETA: The edit button disappeared on my above post. I wanted to add YMMV
  8. #67
    20+ Posts rick1201's Avatar
    Jun 2012
    Millsboro, De
    Never thought I would get used to up shifting with the heel of my foot. It didn't take long to get used to. Would not be without one now.
    Richard
  9. #68
    Oct 2011
    GLEN ELLYN, IL. USA
    Yes, 2014TG
    No problem stepping on the brake.
    IBA#61162
    PATRIOT GUARD
    USMC
  10. #69
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Quote Originally Posted by jc1300 View Post
    +1. I did the same and like it.
    It is what it is.
    16 Tri Glide vivid black
  11. #70
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Looks like the heel wins
    Never leave home with out it
    I almost hacked 1 on my Streetbob, but NAH traded it for my 15 Freewheeler that I rode 4 a year and traded it for my 17M8 that is 1 year old and 14k miles of upshifting with my heel
  12. #71
    150+ Posts Triglide1950's Avatar
    Sep 2017
    Chanhassen, Minnesota
    I have never really used heel shifters. A couple of weeks ago I took off the heel shifter on my 2015 Triglide, and replaced it with the chrome shaft cover. I found it also gave me more space to move my foot on the floor board.
  1. Want to install Heel Toe Shifter
    By robval87 in forum Honda Trikes
    Last Post: 03-27-2023, 03:12 PM
  2. Heel Toe shifter Not for Me!!
    By Lone Wolf Top in forum Honda Trikes
    Last Post: 12-29-2013, 08:46 PM
  3. toe/heel shifter
    By electricjaws in forum Honda Trikes
    Last Post: 10-28-2013, 05:41 AM
  4. HEEL/TOE SHIFTER & floorboards
    By Chief in forum Accessories
    Last Post: 07-08-2011, 10:15 AM
  5. Heel/toe shifter advice
    By xfootdoc in forum Honda Trikes
    Last Post: 06-06-2011, 01:03 PM
